82 Pages V « < 45 46 47 48 49 > »
> The Project Anklebiter Build Thread., 8/29 Lid latches and glamor shots...
plymouth37
post Apr 17 2012, 09:02 PM
Post #921
QUOTE(malcolm2 @ Apr 17 2012, 08:56 PM) *
Hey... PM sent. I can certainly use that trunk floor.
Thnks,
Clark
It is all yours, give me a day or two to box it up!
KELTY360
post Apr 17 2012, 10:22 PM
Post #922
914 Neferati
QUOTE(plymouth37 @ Apr 17 2012, 07:02 PM) *
Thnks,
Clark
@malcolm2 - have Dana autograph that piece from the world famous Anklebiter - it will be worth big bucks some day!
PeeGreen 914
post Apr 18 2012, 09:04 AM
Post #923
QUOTE(KELTY360 @ Apr 17 2012, 09:22 PM) *
Thnks,
Clark
Yeah,
Once my CF rear lid is painted you will have to sign it for me Dana (IMG:style_emoticons/default/biggrin.gif)
malcolm2
post Apr 18 2012, 07:56 PM
Post #924
QUOTE(plymouth37 @ Apr 17 2012, 10:02 PM) *
Thnks,
Clark
Awesome, Autograph is welcome. I'll do my best to keep it whole. I PM'd my number, just call and let's work out the details.
Clark
Mr. 5150
post Apr 18 2012, 08:45 PM
Post #925
Flip'n sweet I can see your not afriad to start from scratch! I love builders who believe limits are for the limited.
plymouth37
post Apr 22 2012, 04:59 PM
Post #926
I finished hooking up the coolant hoses, it took a 1991 Nissan Sentra hose, half a 2001 Suburban hose and an un-identified hose I found at AutoZone to get everything connected. I am almost done hooking up all of the connections needed for the car to run. Both coolant hoses will be heat wrapped to keep heat from effecting the fuel system once I get to final assembly. Once I am done with the mechanicals I will pull the chassis apart and go into paint.
I also worked on fitting the pieces of the front nose.
majkos
post Apr 22 2012, 06:22 PM
Post #927
Go,Dana,Go! (IMG:style_emoticons/default/aktion035.gif)
nein14
post May 15 2012, 01:18 PM
Post #928
Fantastic work when will you be in Pa?
plymouth37
post May 15 2012, 06:00 PM
Post #929
QUOTE(nein14 @ May 15 2012, 01:18 PM) *
We are moving out at the end of July, classes start in the middle of August.
Glad to have the site back, thanks Andy!
plymouth37
post May 16 2012, 07:32 PM
Post #930
I got a little bit of work done last weekend, I am trying to finish up the handful of welding jobs left on the tub.
I focused my efforts on the tunnel, I started by bracing the clutch tube.
There wasn't anything wrong with it but it is the kind of job you have to do if you have the shifter out and the welder handy.
Next I welded in a bracket to hold the Wilwood brake proportioning valve I bought from JWest.
I figure a little adjustability in the brake bias will probably be nice once the test driving portion of the build comes around.
It will also make dialing in future brake upgrades a snap.
Finally I mounted the JWest brake tee to the firewall with a little bracket, making it possible to eliminate the stock brake regulating unit.
plymouth37
post May 18 2012, 10:28 PM
Post #931
I cut the stock shifter end off of the original shift linkage then welded it to the JWest shift rod.
Then I mocked up the shift rod bushing on the firewall.
Next I mounted the Rennshift shifter with a custom shift knob I rigged up.
My stock shift knob was in really rough shape so I mounted the starter button from a Honda S2000 into it.
The button will be functional and the lettering lights up when it is armed.
poorsche914
post May 19 2012, 07:12 AM
Post #932
T4 Supercharged
QUOTE(plymouth37 @ May 19 2012, 12:28 AM) *
That is cool (IMG:style_emoticons/default/aktion035.gif)
Ferg
post May 19 2012, 07:56 AM
Post #933
I thought the button was going to flip up and you were going to have an ejector seat (IMG:style_emoticons/default/w00t.gif)
plymouth37
post May 29 2012, 10:28 PM
Post #934
I was up at our cabin over the holiday weekend so no hands on work got done.
I did manage to design a hinge system that allows the nose to clear the doors as it opens though.
Here is an illustration of how it will operate. Hopefully I can get it built this weekend.
nomore9one4
post May 30 2012, 08:00 AM
Post #935
Member of the Eastcoast Thread Killers Club
QUOTE(plymouth37 @ May 29 2012, 09:28 PM) *
Built this weekend? lol..I could have a team of engineers and not build that in six months! You've got some mad skills (IMG:style_emoticons/default/smile.gif)
Scott S
post May 30 2012, 10:30 AM
Post #936
Small Member
I am pretty sure Dana could have finished my -6 conversion (that I am into right at 2 years) in an afternoon.....
Fantastic project sir!
plymouth37
post Jun 3 2012, 08:24 PM
Post #937
I got the major elements of the nose hinge done today.
I started out by fabricating the components needed to build the hinges I designed last weekend. I used nylon spacers to serve as a bearing, I also drilled out the centers of them to adapt the standard tubing to the metric hardware. The cotter pins allow the entire nose to be removed in a couple minutes at most.
Here is a shot of the nose closed, notice the perfect door gap, my biggest concern with this project was properly aligning the nose and I think I pulled it off.
Here is the hinge system with the nose closed, I will be adding hydraulic struts to the system next. Ultimately you will never see this view because the hood will be welded to the fenders.
The nose partially open.
The nose fully open.
wingnut86
post Jun 3 2012, 09:00 PM
Post #938
...boola la boo boola boo...
Wow.
OK, I'm officially jealous...
(IMG:style_emoticons/default/hissyfit.gif)
What a Hot Ride (IMG:style_emoticons/default/beer.gif)
Dasnowman
post Jun 3 2012, 11:24 PM
Post #939
You miss 100% of shots you don't take!
QUOTE(Zundfolge @ Jun 12 2008, 01:53 PM) *
For color, I'd love to see you just polish up the metal a bit and remove some of the tooling marks, then just clear coat it ... kind of like the Renegade Hybrids Subie (would be very 550 spyder-esque).
Then paint all the fiberglass parts a nice metallic silver ... or black.
QUOTE(plymouth37 @ Jun 12 2008, 02:04 PM) *
QUOTE(Zundfolge @ Jun 12 2008, 12:53 PM) *
For color, I'd love to see you just polish up the metal a bit and remove some of the tooling marks, then just clear coat it ... kind of like the Renegade Hybrids Subie.
This is the Renegade Hybrids Subie! (IMG:style_emoticons/default/biggrin.gif)
QUOTE(Zundfolge @ Jun 12 2008, 02:05 PM) *
QUOTE(ericread @ Jun 12 2008, 02:09 PM) *
No, I don't think that's the same one...
QUOTE(plymouth37 @ Jun 12 2008, 02:14 PM) *
QUOTE(ericread @ Jun 12 2008, 01:09 PM) *
My bad, sorry. (IMG:style_emoticons/default/biggrin.gif)
OMG I know this was old but I just spit out my vodka and coke out my nose!
sixnotfour
post Jun 4 2012, 12:27 AM
Post #940
Looks great (IMG:style_emoticons/default/beerchug.gif) how about these remote operated ?
http://www.firgelliauto.com/default.php?cPath=110
- Lo-Fi Version Time is now: 20th April 2025 - 06:56 AM
