Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
OK, I have finaly started the process of tear-down!
My plan is to remove and replace: The Oil Return Tubes The Trailing Arms Powder coat everything Maybe Muellers Bearings toooooooo! Can I powder coat the Heat Exchangers or should I just paint them? Woohoo, we will see! I will post more photos as I progress! Jeff Attached image(s) ![]() |
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
So what did it take to pull your hubs, I am quite stuck at this point(but harvesting them from a 911)
Is there a tool or what? |
Jeffs9146 |
I remove the bearing retainer plate, set the arms on the edge of the table and start pounding with the following tools!!
Jeffs9146 |
Tool #2
Jeffs9146 |
Tool #3
Jeffs9146 |
I realize this is the Mickey Mouse way to do it but I couldn't find my Bearing tap extension so I had to improvise!! I wouldn't want to use the bearings after removal anyway! (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif)
Jeff |
Jeffs9146 |
Just in case you are trying to do this while it is still in the car, there is a certain order you need to remove things!
After removing the Wheels, brakes and rotor then: 1. Remove the Axels 2. Tap hub out 3. Remove Bearing retainer plate 4. Tap out bearing out Jeff |
Jeff Bonanno |
il dottore ![]() ![]() Group: Members Posts: 421 Joined: 30-April 03 From: San Diego, CA Member No.: 636 ![]() |
-- tap --
taptaptap thwap! SMACK! SMA...CLANK - awfuck. |
Jeffs9146 |
QUOTE awfuck That comes when it finaly falls out and on your foot!! Jeff Attached thumbnail(s) ![]() |
fiid |
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California ![]() |
QUOTE(Jeff Bonanno @ Feb 13 2004, 12:55 PM) -- tap -- taptaptap thwap! SMACK! SMA...CLANK - awfuck. (IMG:style_emoticons/default/chairfall.gif) (IMG:style_emoticons/default/chairfall.gif) (IMG:style_emoticons/default/chairfall.gif) (IMG:style_emoticons/default/lol2.gif) (IMG:style_emoticons/default/lol2.gif) ROTFLMAO |
echocanyons |
Jeffs9146 |
5 lb minimum!!
QUOTE -- tap -- taptaptap thwap! SMACK! SMA...CLANK - awfuck. What he means is hit it harddddddddd!! with a 5 pounder! Jeff |
Jeffs9146 |
OK, I did it all by my self!!!! Filled the ovaled hole and reamed it! OUCH! (IMG:style_emoticons/default/ohmy.gif)
Jeffs9146 |
Things are still progressing! I have most of the parts powder coated and ready to reasemble! I am still cleaning the motor and I just found out my alternator was bad so I guess I wont make it for the 27th breakfast!! Oh well, maybe the next one!!
Jeffs9146 |
OK I am making some progress! I am not going to be able to attend the WCC because I have to get this going and then move to the new home in Discovery Bay!!
The suspension is done and just needs some detailing and reassembling. Attached thumbnail(s) ![]() |
Jeffs9146 |
Now the engine just needs to be cleaned and reassembled!! Look at the intake ports!! They look new!!
Jeffs9146 |
lskj
Jeffs9146 |
lskjlk Last one!
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
looks good Jeff.....are you selling the /6 or keeping it?
not that I have personal experiance......but you might be interested to know that out on Vasco Rd they installed some automatic speed limit signs that tell you what your current speed is......I "heard" that they flip out and flash 0 and 70 when passed while going a little over 130 (IMG:style_emoticons/default/smile.gif) |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(Mueller @ May 17 2004, 03:38 PM) I "heard" that they flip out and flash 0 and 70 when passed while going a little over 130 (IMG:style_emoticons/default/smile.gif) the "flash" is the camera taking a picture of your license plate (IMG:style_emoticons/default/wink.gif) |
Jeffs9146 |
Yep, I saw those last week when I was doing the inspection on my new place!! I didn't test the 130 mph thing though....every time I go up there I see at least 3 Highway Patrol pulling someone over!! That is one hell of a fun road at top speed though!!
QUOTE are you selling the /6 or keeping it? I plan on keeping it unless I find one already done well and I can make a quick buck selling this one! The house is my focus right now!! You'll have to come out and hang on the dock some time Mueller, we are almost neighbors! Jeff |
Lo-Fi Version | Time is now: 29th June 2024 - 02:26 AM |
