malaga_red75 |
'74 2.5L N/A Subie ![]() ![]() Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None ![]() |
coming out...
Attached thumbnail(s) ![]() |
malaga_red75 |
malaga_red75 |
malaga_red75 |
Alright,
So here is what I have been up too. I started the process of grinding down all the rust and paint on the floor pans and firewall to find out exactly what is good metal and what will need to be replaced. I took a quick brake of grinding and took about two days to re-fresh the gauge panel and the gauge bezels. I sanded them down to metal, primed, painted and clear coated. I am almost done with the sanding/grinding of the paint and other 'stuff' that has accumulated on the car. After I am done it will get some POR-15....yeah baby!!! I also got some more parts. I got the engine mounts from small car, the radiator (from a late 80's jetta, the same one that tonyakavw used in his second radiator setup). I also got a 16 gallon air compressor with a max 150psi from my friend who bought it for a fence he built and now has no use for it, so it is mine until further notice....hurray!!!!!!!! So, I do have a few questions and then I will post pics. -Can the POR-15 go directly onto the bare metal or do I need to add a coat of primer first?? -What type of sealer should I use to re-seal all of the joints where the previous white gooey material was or will the POR-15 be enough? That is all for now, I know I will think of more questions as soon as I finish posting. -Peter pics to follow... |
malaga_red75 |
down to metal
malaga_red75 |
malaga_red75 |
primed, painted, baking
malaga_red75 |
malaga_red75 |
malaga_red75 |
DONE!!!!
malaga_red75 |
Metal...lots o metal......and some rust (IMG:style_emoticons/default/mad.gif)
malaga_red75 |
malaga_red75 |
rust....
malaga_red75 |
The tools I am using...
Various sizes of wire brush (crimped) wheels 2 paint/rust remover wheels that big one is called a removal all brush or something like that...worked really well to get the first layer of bulky rust off small grinding wheels, a couple different styles, VERY useful for getting the tiny joints and areas where the wheels couldnt get too. Attached thumbnail(s) ![]() |
G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
nice job keep it up (IMG:style_emoticons/default/beerchug.gif)
malaga_red75 |
So, nothing has really changed on the car since my last post since I have been away at school, I have had no chance to work on the car. However, I have been ordering parts for a while and was able to make it home last weekend between water polo games and look at my new parts, and yes I took pictures. So here ya go......
--Stage one clutch kit from KEP-- --Flywheel from KEP-- --Adapter plate from KEP-- Attached thumbnail(s) ![]() ![]() ![]() |
malaga_red75 |
--radiator--
--fans-- --parts porn-- -Peter Attached thumbnail(s) ![]() ![]() |
malaga_red75 |
TonyAKAVW |
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None ![]() |
Excellent choice on the raditor (IMG:style_emoticons/default/smile.gif) And those fans look familar too. Those tools you are using for paint removal are identical to the ones I used. I'm actually amazed, you have literally the exact number and variety of tools as I do (except the small grinding stone bits).
Looking good! -Tony |
malaga_red75 |
Excellent choice on the raditor (IMG:style_emoticons/default/smile.gif) And those fans look familar too. Those tools you are using for paint removal are identical to the ones I used. I'm actually amazed, you have literally the exact number and variety of tools as I do (except the small grinding stone bits). Looking good! -Tony Thanks tony, yea the small bits werent as useful as i thought but did help with some of the small corner style areas. I have a question for you actually. Where did you get your expansion tank and what style did you get? |
Lo-Fi Version | Time is now: 19th April 2025 - 06:09 AM |
