> wire colors for emergency brake light and oil idiot light
buck toenges
post Aug 16 2008, 07:23 AM
I am hooking up a quad gauge for my 3.2 and I need to know which wire is my emergency brake light and my oil idiot light? I assume the idiot light wire is green and my brake light is blk w/blue. I don't think the stock idiot light wire will work with the 3.2 I'm a newbie with electrics, well I'm a newbie about most things but electrical right now.
Can I tell which wire is the brake light by apply hand brake with a testing light on the wire? I assume when the hand brake switch is activated I'll get some power out of the wire. I think I need to add a wire from the two poled pressure sensor to get an idiot light. I don't think I have one with the motronic dme.
Thanks,,
Buck
914Sixer
post Aug 16 2008, 07:55 AM
Black/blue is always the dash lights. The year of the car is need because early cars have some wiring differences.
buck toenges
post Aug 16 2008, 08:16 AM
Car is '72
Thanks,
Buck
Todd Enlund
post Aug 16 2008, 10:42 AM
Resident Photoshop Guru
Pelican doesn't have a diagram for a '72... here's the '71:
http://www.pelicanparts.com/914/parts/Elec...rical_1971b.htm
Looks like brown/white and black/white for the brake light, and the oil light is green/red and red/white.
Now, tell me about that D.VII?
post Aug 16 2008, 01:43 PM
Resident German
QUOTE(buck toenges @ Aug 16 2008, 05:23 AM) *
Will work just fine!
The stock idiot light wire is green/red. The 3.2L uses the same color coding for the oil idiot light, oil pressure gauge and oil temp gauge, so that should be easy to figure out.
The 3.2L has a dual sending unit with the oil idiot light wire and the oil pressure gauge wire. You'll know if you mixed the two up as one is just a switch (on/off - the idiot light) while the other has a range.
(IMG:style_emoticons/default/bye1.gif) Andy
- Lo-Fi Version Time is now: 2nd January 2025 - 03:36 PM
