Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Yea I have had a 2.0L engine for many years. Low compression SSI 009 40IDF. and I was never able to run less than a 130 Main jet.
ran a 1911 cc motor for awhile and it was so screwed out of tune it needed a 135 main. (absolutely un-tunable). my 2098cc with high compression 10.3:1 and 40 IDF's only requires a 135 main. the 2316-210 is going to start with a 140 and we'll go from there. The engine size in this thread is what 2.4L ?????? not sure how that is obtained with a 78.5mm crank. Reading main jet richness is tough because the idle jets will significantly mask what's going on. I have a wide band A/F meter and I know exactly what going on when. These things are accurate enough and quick enough to watch the carb tranisition through all the circuits. Guess I get my dander up when people are repeating what they read on the net with little or no real experience tuning. |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I guess after rebuilding three motors you are the Guru.
I wish you were into aircooled cars way back when I got my first one...you would have set me straight.... Never use an 009 an a type 4 motor. BTDT...its just not the right advance curve. The 050 is closer and works alot better. I stick with the stock 2.0 distributor and never have issues. Just dont run the vacuum advance, its not needed. the distributor is a big part of having a tunable motor... 3 people, myself included are repeating real world experience running dual webers. I had a stroked 2.4 with 98mm cylinders, its an old combo that was around back when Mahle made aluminum 98 mm cylinders for the type 4 motor....it was pretty common 15 or so years back. Works out to 2368 (circa 2.4) and ran on 40mm webers to meet SCCA rules at the time. Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 10:11 AM |
