Can somebody tell me what this does?, flashing light |
914rhatt |
Sep 7 2008, 01:51 AM
Newbie Group: Members Posts: 23 Joined: 7-July 08 From: Tonopah, Nevada Member No.: 9,263 Region Association: Intermountain Region |
After you know where the button is, you don't need to jack up the front of the car or remove the splash shield. Just crank the steering wheel to the right, reach into the wheel well, find the master cylinder, and push the reset button. --DD LOLOLOL you crack me up....Reset button right next to the chrome manaform HUH... |
AJB |
Sep 7 2008, 07:47 AM
Member Group: Members Posts: 50 Joined: 18-November 07 From: United Kingdom Member No.: 8,350 Region Association: Europe |
I pulled away from a stop sign and noticed this light flashing. I drove right back home, but everything seemed fine. I turned it off and restarted it and now it doesn't flash any more. Isn't it a brake light? To be honest I think you went a bit far by removing the entire gauge just to stop the little light coming on! (IMG:style_emoticons/default/poke.gif) |
BarberDave |
Sep 7 2008, 08:31 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
That my friends is the little known indicator light for the secret, FLUX CAPACITOR, (only 4 built ) when the red light is lit that is a indicator you have HYPER DRIVE available to you. Good luck!!!!! Dave (IMG:style_emoticons/default/slap.gif) |
914rhatt |
Sep 7 2008, 09:46 AM
(IMG:style_emoticons/default/smilie_pokal.gif) That my friends is the little known indicator light for the secret, FLUX CAPACITOR, (only 4 built ) when the red light is lit that is a indicator you have HYPER DRIVE available to you. Good luck!!!!! Dave (IMG:style_emoticons/default/slap.gif) Mine had that when I used to drive it daily, I used the Hyper Drive through corners to beat the crap out of Mazda RX-7's...LOLOLYou guys are brutal... |
Sep 7 2008, 06:59 PM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
LOLOLOL you crack me up....Reset button right next to the chrome manaform HUH... I don't get the joke... (IMG:style_emoticons/default/confused24.gif) If you crank the steering wheel all the way to the right, there will be room in the left-front wheel well to look into the area where the brake master cylinder lives. Once you know where the reset button is on the M/C, you can just reach in through the wheel well and push the button, no problem! --DD |
Lo-Fi Version | Time is now: 5th January 2025 - 12:02 AM |
