3 Pages V < 1 2 3
> Wilhelm's build - Yet Another Machine (YAM), A build starting summer 2008, So how longs this gonna take?
Katmanken
post Mar 14 2009, 03:51 PM
Post #41
You haven't seen me if anybody asks...
That .25 inch makes the belt replacement doable...
Ken
3d914
post Mar 14 2009, 05:39 PM
Post #42
Very nice work!
Who's engine bar and motor mounts are those - did you fab? I'm curious why you didn't use the stock engine mounting locations.
I'm still undecided how to mount my V6.
Keep up the good work.
Wilhelm
post Mar 14 2009, 07:47 PM
Post #43
Hope to never have to change the belt. I got 132,000 miles out of the serpentine belt on the S10 Blazer. Does that make me lazy or frugal?
QUOTE(3d914 @ Mar 14 2009, 04:39 PM) *
I made the engine bar out of a piece of 2" square tube, .18" wall thickness IIRC. The aluminum motor mounts are standard GM items (they call them "stands") and the black round pieces are standard corvette motor isolators. While fixing some mild hell hole rust I thought the original mounts (especially the right side) looked weak and didn't want to risk ripping them out with the new motor. Also wanted to reinforce the inside of the frame rails as they were pitted from years of battery acid raining down on them. To take the original mounts out, I drilled the spot welds, and gave a thin chisel a few wacks between the frame rail and the mount. They came out shockingly easy and if I kept them would have, at a minimum, re-welded them.
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 14th December 2025 - 05:28 AM
