10 Pages V < 1 2 3 4 5 > »
> Hold The Phone! I'm working on MY CAR!, Prepping for paint....
McMark
post Apr 10 2009, 11:48 AM
Post #41
914 Freak!
Post a new thread and I'll go into it.
FourBlades
post Apr 10 2009, 07:38 PM
Post #42
From Wreck to Rockin
QUOTE(ConeDodger @ Apr 10 2009, 07:35 AM) *
This FourBlades guy John just has to be stopped! Look at the fuchin' progress people are making when he inspires them! I vote we ban him for threatening and harrassing jackstands! (IMG:style_emoticons/default/lol-2.gif)
I guess I better not post any progress anymore or mention how I just got new
seats from Craig at Camp914, or how I put in all new brake lines, just bought
my first set of tires for my car, etc. etc.
(IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/biggrin.gif)
dbgriffith75
post Apr 11 2009, 06:55 AM
Post #43
TheGrif
(IMG:style_emoticons/default/blink.gif)
All I can say is... WOW!
[Okay I can say a bit more than that.]
It's amazing the progress you've made! If I'd of gotten as busy as you when I started my resto, I probably would've had it done and sold by the time my shoulder went out. But then, I didn't know jack f--king squat about Porsche's when I started my resto either.
But seriously, awesome work dude. Things are looking good- keep the pics coming! (IMG:style_emoticons/default/aktion035.gif)
McMark
post Apr 11 2009, 09:15 PM
Post #44
914 Freak!
Finished up the patch that I was halfway done with (see above). Now I just have some misc. DAPO screw holes in the firewall and then the engine shelf. Then the welding is done..... (IMG:style_emoticons/default/unsure.gif) Well, until I dig into the other side hell hole. (IMG:style_emoticons/default/hissyfit.gif)
JRust
post Apr 11 2009, 09:33 PM
Post #45
Looking good dude! Keep up the good work (IMG:style_emoticons/default/dance.gif)
Rusty
post Apr 11 2009, 09:39 PM
Post #46
Wanted: Engine case GA003709
Looks awesome... hang in there!
jcambo7
post Apr 12 2009, 05:30 PM
Post #47
r_towle
post Apr 12 2009, 07:55 PM
Post #48
Custom Member
Its a customers car...
Rich
McMark
post Apr 13 2009, 10:48 AM
Post #49
914 Freak!
Only if someone buys it before I'm done. (IMG:style_emoticons/default/happy11.gif)
McMark
post Jul 8 2009, 07:05 PM
Post #50
914 Freak!
More work... months later. (IMG:style_emoticons/default/dry.gif) Engine shelf is in and all the holes in the firewall are welded up.
I'm waffling between
1. being thorough and cleaning everything in the engine bay, stripping the paint, and having it all done up nice.
2. being quick and just spray painting everything and dealing with real paint later.
I should probably pick #2... right? (IMG:style_emoticons/default/confused24.gif)
markb
post Jul 8 2009, 07:29 PM
Post #51
914less :(
Depends, do you know what color it's going to be? Do you want the car on the road in this decade?
(IMG:style_emoticons/default/av-943.gif)
Choose #2. (IMG:style_emoticons/default/biggrin.gif)
greenie
post Jul 8 2009, 07:58 PM
Post #52
QUOTE(McMark @ Jul 8 2009, 04:05 PM) *
Maybe create #1.5
Sears sells cheap sandblasters ( under $50.00 ), then off to your local paint supply store, they can special mix up rattle cans for you with the exact color, not super cheap but it will look very nice in the engine compartment.
Keep up the great work!
r_towle
post Jul 8 2009, 09:14 PM
Post #53
Custom Member
QUOTE(McMark @ Jul 8 2009, 09:05 PM) *
No, because you will want to show how thorough a job you did when you sell it...
It is a customers car...you are just borrowing right now...
Rich
pete-stevers
post Jul 8 2009, 10:23 PM
Post #54
saved from fire!
If you think you are not going to mod that compartement further, take the time do a good prep, primer and then paint...
if not then resort to option two...
ConeDodger
post Jul 9 2009, 08:57 AM
Post #55
Apex killer!
Do it right. We both know that you spend hours practicing dance moves in that big new shop of yours... Give up. You are never going to play Patrick Swaze's part in Dirty Dancing 2! Take that time you normally practice and put it into your car... (IMG:style_emoticons/default/poke.gif)
McMark
post Nov 28 2009, 11:11 PM
Post #56
914 Freak!
I finally finished the one thing that started off this whole madness. (IMG:style_emoticons/default/lol-2.gif)
The new rear trunk pivots are in. I bought stock reproductions, then TIG welded the nut boss to the 'frame'. The welds that came on the parts were obviously crap. One of my TIG welds came out better than the other. (IMG:style_emoticons/default/dry.gif) Once the welds cooled, I used some sandpaper on glass to smooth out the face, since the hinge will pivot on that face, and any 'boogers' will cause wear and could cause future damage.
Then I drilled the holes for the rosette welds and painted the back side of the bracket (since you won't be able to get paint back there later). To weld them in I attach the hinges to the lid with the bolts in the middle of their adjustment, and set everything into place. The I line up the gaps as much as possible and use masking tape along the gaps to help hold everything in place. Then using shims I brace the lid up to the correct vertical height. Getting this part right is THE MOST IMPORTANT, since you won't be able to adjust it later. Then ZAP! (IMG:style_emoticons/default/welder.gif) I used power C and wire feed 5.5 on my Lincoln WeldPak 100 with bi-mix gas for the welding.
Now I can make the final gap adjustments as necessary.
JRust
post Nov 29 2009, 12:38 AM
Post #57
Excellent Mark! Definately nice to spend a little time on your own car. Car is looking good (IMG:style_emoticons/default/shades.gif)
McMark
post Mar 31 2010, 08:44 PM
Post #58
914 Freak!
Time to update the ol' progress thread. Some of these things have been done for a little while, but I just finished up the brakes today.
I got a full set of PMB calipers and a quick-convert five lug setup. I'm now running boxster 'snowflake' 16" wheels all around.
I got the battery tray welded in, and all the holes in the firewall closed up.
I also pulled my pedal cluster for a rebuild. When I went to bleed the brakes awhile back, the front seal finally gave out, so it leaked all the brake fluid in the reservoir out into the footwell, and from there it dripped out onto the ground (notice the kitty litter). So I needed to pull the cluster just to clean everything up. So why not blast it, powdercoat it, and fill it with bronze bushings. (IMG:style_emoticons/default/cool.gif)
Oh, and I ordered rebuild kits for my carbs today. They're be here Friday.
Mike Bellis
post Mar 31 2010, 10:55 PM
Post #59
Resident Electrician
This car going to make it to WCR 2010?
McMark
post Mar 31 2010, 11:01 PM
Post #60
914 Freak!
I'm tryin'! If it is, it'll most certainly be in a thrown together state. (IMG:style_emoticons/default/wacko.gif)
- Lo-Fi Version Time is now: 27th December 2024 - 01:44 PM
