Pulling hubs into rear bearings...need some advice |
Derek Seymour |
Jul 17 2009, 01:34 PM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
Hey Mark did you use a torch as well or just the tool and the freezer trick?
My hubs were next to some tikka masala from Trader Joes, but I wasn't sure this would do help so I moved them into an empty ice tray across from the frozen chicken.. maybe I should get some Braunschweiger and throw that in.. since it's spreadable and all... |
computers4kids |
Jul 17 2009, 02:16 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Hey Mark did you use a torch as well or just the tool and the freezer trick? My hubs were next to some tikka masala from Trader Joes, but I wasn't sure this would do help so I moved them into an empty ice tray across from the frozen chicken.. maybe I should get some Braunschweiger and throw that in.. since it's spreadable and all... Use "swanson" pot pies only... (IMG:style_emoticons/default/biggrin.gif) Just freezing the bearings worked great for me. Just pull out one bearing at a time out of the freezer. Torching the hubs probably would help, but no personal experience. In my case the freezer was the trick. |
Justinp71 |
Jul 17 2009, 02:24 PM
Senior Member Group: Members Posts: 1,602 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I was also told that you should put some oil between the surfaces, because when the parts go back to the normal temps you'll trap some condensation in there...
Borderline |
Jul 17 2009, 02:34 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
Hey Mark did you use a torch as well or just the tool and the freezer trick? My hubs were next to some tikka masala from Trader Joes, but I wasn't sure this would do help so I moved them into an empty ice tray across from the frozen chicken.. maybe I should get some Braunschweiger and throw that in.. since it's spreadable and all... Use "swanson" pot pies only... (IMG:style_emoticons/default/biggrin.gif) Just freezing the bearings worked great for me. Just pull out one bearing at a time out of the freezer. Torching the hubs probably would help, but no personal experience. In my case the freezer was the trick. Did you thaw them out in the microwave before using? |
jmill |
Jul 17 2009, 03:28 PM
If your wife grows accustomed to hubs in the freezer and maybe grease rags in the washing machine it will make it easier when she comes home early to bust you with an engine case in the dishwasher. (IMG:style_emoticons/default/av-943.gif) The wife came home early when I was heating up a cam gear on the stove in a pot of 30 weight. I still have the pot in the garage. I never could get the oil stains out of it. Took a few days to get the smell out of the kitchen. |
Jul 17 2009, 08:05 PM
Custom Member Group: Members Posts: 24,645 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
you need the right type of oil....
IronHillRestorations |
Jul 18 2009, 12:55 PM
I. I. R. C. Group: Members Posts: 6,775 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I use a white scotchbrite disc on a roloc to polish the bearing and hub races, it helps.
Marie Calendar make the best chicken pot pies |
Lo-Fi Version | Time is now: 22nd November 2024 - 10:41 PM |
