6 conversion question wiring related |
LarryR |
Oct 11 2008, 07:12 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
I was wondering if the engine harness would plug from a 1974 cis 2.7 would plug straight into a 70 914 I am not even sure if the number of pin outs is the same. If there are any of you who have done this conversion that would chime in on the best route it would be greatly appreciated.
I was thinking otherwise I would just graft a 914 engine harness onto the 2.7. I guess that would be the easiest if the 2.7 wont work directly. However, that would be a little bit of grief since the 2.7 harness also has the cde harness on the engine harness. Thanks in advance, Larry |
ClayPerrine |
Oct 11 2008, 08:51 PM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I was wondering if the engine harness would plug from a 1974 cis 2.7 would plug straight into a 70 914 I am not even sure if the number of pin outs is the same. If there are any of you who have done this conversion that would chime in on the best route it would be greatly appreciated. I was thinking otherwise I would just graft a 914 engine harness onto the 2.7. I guess that would be the easiest if the 2.7 wont work directly. However, that would be a little bit of grief since the 2.7 harness also has the cde harness on the engine harness. Thanks in advance, Larry You will have to make some mods.. the 911 harness uses a 14 pin connector, and the 914 harness uses a 12 pin connector. If you were local, I could help. |
LarryR |
Oct 11 2008, 11:33 PM
You will have to make some mods.. the 911 harness uses a 14 pin connector, and the 914 harness uses a 12 pin connector. If you were local, I could help. Did you adapt the 911 harness to the 914 chasis or did you just take a 914 engine harness and make work on the 911 engine. I am pretty sure I could do the later unaided but I think the first option would be the cleaner install. Larry |
ClayPerrine |
Oct 12 2008, 07:42 PM
You will have to make some mods.. the 911 harness uses a 14 pin connector, and the 914 harness uses a 12 pin connector. If you were local, I could help. Did you adapt the 911 harness to the 914 chasis or did you just take a 914 engine harness and make work on the 911 engine. I am pretty sure I could do the later unaided but I think the first option would be the cleaner install. Larry For my car, I built a custom chassis harness to use a 914/6 relay board, a Getty dash, a J-West fuse box, a 911 steering column, and a bunch of other stuff. If I were doing just a straight conversion, I would take the 911 harness and make it work with the 914 relay board. Are you running the stock injection on the 911 engine or carbs? Carbs are easier for wiring, as you don't have to make up the warmup stuff for them. But the CIS would run better when working right. |
Lo-Fi Version | Time is now: 26th December 2024 - 12:47 PM |
