10 Pages V « < 3 4 5 6 7 > »
> the sinister urge, no more DSM... (and slowly getting pictures fixed in old posts)
RJMII
post Jun 16 2009, 06:41 PM
Post #81
Jim McIntosh
My brakes are installed, adjusted, and bled! New master cylinder is in place. (19mm unit to go with the 911SC front brakes)
Deck lids are somewhat in place, so we can roll it around in the shop and have it look like a car again.
The front bumper now has a huge hole in it...
RJMII
post Jun 16 2009, 06:47 PM
Post #82
Jim McIntosh
where it's sitting right now. =o) on the ground!
RJMII
post Jun 16 2009, 06:51 PM
Post #83
Jim McIntosh
While I was working on the brakes I came across an issue of the rotor acting warped.
It didn't seem warped unless it was on the car, installed properly.
My bud at www.pmbperformance.com gave me a couple of pointers and got me headed in the right direction; the brakes are all installed now and working properly.
thanks again, Eric!
RJMII
post Jun 16 2009, 06:52 PM
Post #84
Jim McIntosh
One last shameless plug for PMB... lol
My new clutch cable!! woot!
ghuff
post Jun 16 2009, 08:39 PM
Post #85
This is certainly not what I expected down here.
This thread is full of total fucking win.
(IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/pray.gif)
PS im trying to acll you back, just retarded busy at work
neo914-6
post Jun 17 2009, 02:12 AM
Post #86
neo life
QUOTE(RJMII @ Jun 16 2009, 05:51 PM) *
thanks again, Eric!
care to share the pointer or are they "secrets" (IMG:style_emoticons/default/ph34r.gif) (IMG:style_emoticons/default/biggrin.gif)
I have a rub on one spot on the rotor and it's new or turned, along with rebuilt PMB v calipers. I can adjust the caliper for more clearance but don't think that's the proper fix plus I don't have that type of caliper...
RJMII
post Jun 17 2009, 03:00 AM
Post #87
Jim McIntosh
you see how I've got the rotor mounted backwards? I was testing with the dial indicator how far out of whack my rotor was... .009"
I turned it around, and there was some interference where the welds on the hubs were for the stud reinforcement. The welds were causing my rotors to not seat properly, and made it scuff.
RJMII
post Jun 18 2009, 05:27 PM
Post #88
Jim McIntosh
removing spot welds and peeling off that 76 bumper-ness; whatever that part is called where the bumper cover hangs onto the body.
Look at the previous owner's artwork... pleh.
RJMII
post Jun 18 2009, 05:28 PM
Post #89
Jim McIntosh
I had to put the bumper on to see just how bad the artwork stuck out.. more pleh.
RJMII
post Jun 18 2009, 05:29 PM
Post #90
Jim McIntosh
Yes, the hammer is holding the bumper on. Just the hammer, gravity, the front valance, and that @#$%# bondo. =o)
RJMII
post Jun 19 2009, 10:43 PM
Post #91
Jim McIntosh
I got some of that bondo chiseled off... time to figure out how to get that corner to expand.
JRust
post Jun 19 2009, 11:11 PM
Post #92
Dude I would seriously consider replacing that front corner. How far back does the damage go? Look like the fender has a good 1/2" there in front. I know you have a parts car. How is that piece on it?
RJMII
post Jun 20 2009, 10:31 AM
Post #93
Jim McIntosh
The one on the parts car is in a whole lot better condition than that one. Since I've got the parts car there... I'm going to go ahead and pound on this one a little. I am sure I can't screw it up more than the PO did. . .
and when it doesn't turn out right, I've got the part... out in a field... behind a bunch of other cars... on the parts car.
RJMII
post Jun 20 2009, 11:17 PM
Post #94
Jim McIntosh
got a little done on the car today. Changed the clutch cable, hooked up the speedometer cable, ran vacuum/boost lines from the back of the car to the front of the car for the ECU and the fuel pressure regulator, ran a power wire from the back of the car to the front of the car, mounted the radiator, and called it good for the day.
RJMII
post Jun 20 2009, 11:18 PM
Post #95
Jim McIntosh
oh, I also finished installing all of the new fuel lines under the fuel tank, and installed the fuel tank. I had to remove the roof and both deck lids to get to the areas I was working.
... and the back pad to fish the lines through the center tunnel... working on finding pictures for the day (If I have any)
RJMII
post Jun 22 2009, 09:02 PM
Post #96
Jim McIntosh
making holes...
RJMII
post Jun 22 2009, 09:03 PM
Post #97
Jim McIntosh
from the inside
RJMII
post Jun 22 2009, 09:04 PM
Post #98
Jim McIntosh
bigger holes
RJMII
post Jun 22 2009, 09:05 PM
Post #99
Jim McIntosh
from the inside
RJMII
post Jun 22 2009, 09:10 PM
Post #100
Jim McIntosh
My wife got a picture of my dad and I getting the car ready to push back into the shop.
It was such a nice day today that I rolled the car out to work on it.
19 User(s) are reading this topic (19 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 1st February 2025 - 09:44 AM
