EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
QUOTE where did you get that battery bracket/stand/whatever you call it that's holding your battery in place? I could really use one like that! With an Optima battery, I had a flat piece with 2 teeth in the grooves at the base of the battery on both sides. The pieces bolt to the trunk floor. To close the trunk with a top in the back, you can make it if you don't go too high. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
In the rear trunk.....but it could go bout anywhere.
Attached thumbnail(s) ![]() |
okieflyr |
9fauxteen ![]() ![]() ![]() Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States ![]() |
![]() My gel cell is mounted on the the engine crossbar down loooow! |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
Front trunk..........had the room and to put a little weight up front.
Attached image(s) ![]() |
Maltese Falcon |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,730 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
PThompson509 |
Member ![]() ![]() Group: Members Posts: 132 Joined: 9-August 05 From: Santa Cruz, CA Member No.: 4,564 Region Association: Northern California ![]() |
I had to null-vote to get in because there was no "all of the above" option: (IMG:style_emoticons/default/beer.gif) http://volt914.blogspot.com (IMG:style_emoticons/default/agree.gif) That's what I'm doing too! (IMG:style_emoticons/default/piratenanner.gif) |
benalishhero |
Member ![]() ![]() Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States ![]() |
Original position in my '74 2.0
GreatPumpkin |
Member ![]() ![]() Group: Members Posts: 122 Joined: 28-October 07 From: Centerville OHIO Member No.: 8,272 Region Association: None ![]() |
here is mine
ghuff |
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region ![]() |
I have to do something about the battery situation in my 914 this weekend. I think I may run a deka battery where the yellow car has it's located.
Still use the targa, and since it is a sealed battery, stuff can be put in back. I had to cut my tray out and refuse to install a new one. That tray collects dust/dirt/debris that soaks moisture and will just rot out again from the back like mine was starting to, and you can not get under it to clean :| |
derepaskos |
Newbie ![]() Group: Members Posts: 14 Joined: 10-July 09 From: city folk Member No.: 10,551 Region Association: None ![]() |
Rear Trunk
thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,550 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
Mine is in the front and had I not put it there back in '89, I don't think my car would be structurally sound. I did install a new shelf, so maybe one day it will return to the rear - but only with a sealed battery!
Brent |
Every month is Oktober ![]() ![]() ![]() Group: Members Posts: 1,360 Joined: 16-December 04 From: North San Jose Member No.: 3,291 Region Association: Northern California ![]() |
I used to keep mine on some scrap wood on the floor of the garage. That was before I split with the wife. Now I don't know where she keeps it, but I can think of some places where she can put it.... Thank god I made off with all my 914 goodies. She just has my DVD's and Yearbooks. |
brp986s |
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 ![]() |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,555 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
PC680 in stock location. It is light and my tray is solid so I did not even consider moving it.
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
I forgot to update this thread, since the upgrade (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 02:54 PM |
