T4 Oil Pump Comparisons, Stock . Schadek . Melling |
McMark |
Oct 17 2016, 12:00 PM
I can still get the 26mm. You gonna modify it yourself?
stevegm |
Oct 17 2016, 12:38 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
KeithVonLaws |
Oct 18 2016, 02:17 AM
Member Group: Members Posts: 57 Joined: 19-July 16 From: Napoleon , Ohio 43545 Member No.: 20,205 Region Association: North East States |
Mark Henry |
Oct 18 2016, 07:30 AM
Hell of a lot of coin for a cheap pump, you realize that site is out of New Zealand right? |
KeithVonLaws |
Oct 18 2016, 08:56 PM
Yes Ive seen these pumps for sale before and it is a lot. I have a 2.4 T4 that has a cast Iron pump. On the Front it Says Made in the USA and 8mm. I am Assuming it is a Melling pump... I want to upgrade but this one has been on the engine for a while and works. Im just doing it as preventative maintenance while the engine is out.
Thanks for any Advice |
Shivers |
Feb 12 2021, 09:37 AM
Senior Member Group: Members Posts: 2,490 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Just when you thought this thread was dead. Putting in a front oil cooler. Need a pump that will move enough oil. Been reading on the internet, and here, but I'd like to hear what the best fix is today. It's only a 2.0 L but other than the rods and oil pump, nothing else is stock . Can you help a brother out with a pump I can trust? Thanks
Highland |
Feb 12 2021, 10:48 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
So perhaps off topic, apologies; but is there any experience with these pumps sold on theSamba?
https://www.thesamba.com/vw/classifieds/det....php?id=2450773 |
Mark Henry |
Feb 12 2021, 11:05 AM
A full flow cover and modified engine mount. (IMG:http://www.914world.com/bbs2/uploads/post-4-1082313177.jpg) I will make the full flow engine mount (yellow part in pic) if anyone needs one, but a core is required. |
Montreal914 |
Feb 12 2021, 11:23 AM
Senior Member Group: Members Posts: 1,600 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I will be using a 30mm Shadek pump and a Gene Berg full flow cover with pressure relief (Mark Henry's recommendation (IMG:style_emoticons/default/smilie_pokal.gif) ).
I modified both engine mounts as minimally as possible, but I recommend Mark Henry's mounts. This will lead to my remote filter and thermostat sub assembly that will be bolted to the lower firewall on the driver side, then to the front cooler. |
peteyd |
Feb 12 2021, 11:47 AM
Senior Member Group: Members Posts: 708 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
So perhaps off topic, apologies; but is there any experience with these pumps sold on theSamba? https://www.thesamba.com/vw/classifieds/det....php?id=2450773 I was also curious about this pump. Apparently they have only been on the market for about 6 months. Has anyone spoken to the guy reselling? I believe his name is Tabari Andrade. Is he a member on here. Pete |
914Sixer |
Feb 12 2021, 02:21 PM
914 Guru Group: Members Posts: 8,921 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Tabari did my rockers. He also sells 10mm German Swivel Foot rocker and solid spacers. Advertises over on theSamba.com
Mark Henry |
Feb 12 2021, 03:25 PM
$330 is a lot of bones for a pump
I'd do the 30mm pump and Gene Berg pressure relief cover as in montreal914's 1st pic. You don't have to remote filter this set-up, you could just plug the cover (and not plug the pump return side) and the pressure relief feature still works. My 2.6 liter T4 powered bug has a 26mm and a regular steel FF cover. The reason I don't like aluminum covers is because the pump gears try to drill through them. You can really see this on old T1 covers, but I see this in stock T4 pumps as well. |
Shivers |
Feb 12 2021, 04:47 PM
Thank you.
barefoot |
Feb 12 2021, 06:14 PM
Senior Member Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I'm using the CB Maxi Pump 914/type 4
I did little port matching but wasn't much. I clearanced the cam bolts very slightly to insure working clearance. For my 2056. oil pressure stays about 50 at cruising speed and was inexpensive. Retains stock oil cooler. Oil temps stay below half gauge on combo oil temp gauge outside temperatures in the 80's. I haven't seen the need to run an aux oil cooler even though i've got everything needed to hook it up. https://www.cbperformance.com/product-p/1829.htm |
Shivers |
Feb 12 2021, 08:03 PM
I'm in the Sonoran Desert, gets really hot here. A couple weeks ago it was 90 here. Summer can be brutal. Thanks everyone, I have a plan
Mark- " I'd do the 30mm pump and Gene Berg pressure relief cover as in monI'd do the 30mm pump and Gene Berg pressure relief cover as in montreal914's treal914's " |
930cabman |
Jul 14 2021, 12:16 PM
Advanced Member Group: Members Posts: 3,214 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I'm using the CB Maxi Pump 914/type 4 I did little port matching but wasn't much. I clearanced the cam bolts very slightly to insure working clearance. For my 2056. oil pressure stays about 50 at cruising speed and was inexpensive. Retains stock oil cooler. Oil temps stay below half gauge on combo oil temp gauge outside temperatures in the 80's. I haven't seen the need to run an aux oil cooler even though i've got everything needed to hook it up. https://www.cbperformance.com/product-p/1829.htm This all sounds good, I will be going with the CB 1829 pump BTW, what did you use for pistons? heads? FI or carbs? Thanks |
Lo-Fi Version | Time is now: 26th June 2024 - 07:53 AM |
