maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Dan,
Thanks for sharing your technique, tack at the bottom and then cut and tack your way up and around. That is a really clever method. How did you ever come up with that? With this method you are centering the flare, fore and aft, relative to the existing wheel opening, correct? Is there any issue vertically, for example where the top of the flare blends with the top of the fender? |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,879 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
The top of the flare is below the top of the fender, so that's not a problem. I wish I had used this method. I clmped them in place and then cut out the entire unit. Then I needed to use cleo clamps to hold it in place while tacking.
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,649 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Yup, the biggest thing is getting the bottom edges all lined up perfectly. It really helps to have a couple of pairs of hands. I am usually doing it myself putting the smallest of tacs on so I could place the flare, cut, then eventually even cut through the original tac. With Steve there he was able to hold the flare while I cut and then tacked. Made things go faster that way.
Then Troy showed up and all hell broke loose. (IMG:style_emoticons/default/av-943.gif) |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
Yup, the biggest thing is getting the bottom edges all lined up perfectly. It really helps to have a couple of pairs of hands. I am usually doing it myself putting the smallest of tacs on so I could place the flare, cut, then eventually even cut through the original tac. With Steve there he was able to hold the flare while I cut and then tacked. Made things go faster that way. Then Troy showed up and all hell broke loose. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/happy11.gif) |
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,648 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
the bugger drank all my beer
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
And you where suprised? You need to spend more time with Troy. He is all about the barley pops. (IMG:style_emoticons/default/beer3.gif)
messix |
not me.... i'm all for the distilled libations!
pete-stevers |
here is a shot of the car with a bit of filler on it...
I should let you know, this is the first time i have EVER attempted body work of this magnitude.... the rear driver quarter has taken the most work this far! Attached image(s) ![]() ![]() |
pete-stevers |
once i got most of the shaping done, with many guide coats and much blocking, i decided to prime with a heavy ppg k201.
After letting it cure i will block and clean up any other imperfections.....and there are more than just a few (IMG:style_emoticons/default/headbang.gif) Attached image(s) ![]() ![]() ![]() |
effutuo101 |
Nice work! keep it up.
pete-stevers |
for all the taping and prep i could have almost painted the entire car...
i am re painting the targa, duck tail, front hood, bumpers,valences and the centers on the fuches as well. she will look like a different machine when i am done! |
Root_Werks |
Great job Steve! Man, from here, it looks like a million bucks! Keep the progress going and pictures coming.
(IMG:style_emoticons/default/boldblue.gif) |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
(IMG:style_emoticons/default/piratenanner.gif) Looks awesome Steve (IMG:style_emoticons/default/aktion035.gif)
pete-stevers |
(IMG:style_emoticons/default/piratenanner.gif) Looks awesome Steve (IMG:style_emoticons/default/aktion035.gif) thanks....but don't be deceived...there is still a lot of details that need to be taken care of on those quarters.. after this is all done i will be installing some more flourecents in this area of the shop!! i think that will alow me to see highs and lows with a bit more light bouncing around. |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,998 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Wow Steve! I love the learn as you go approach. I will be starting work on a tub next year and I will be stripping and cleaning up body work as I go too. I have all of the tools I have just never used them. You have inspired me!
PanelBilly |
How did the underside turn out? Are you planning on coating it with anything?
pete-stevers |
i sprayed the welds with etch coat, and k201, next i will shoot it flat black
opps after the k201 i will put a couple layers of under coat on the top side in case i ever run stickies |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Looking good Steve!
jc914 |
Member ![]() ![]() Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States ![]() |
Great job Steve it look perfect
pete-stevers |
pardon me..the primer was a PPG k38
the primer was not fully cured due to the cold but damn that stuff can cover, i blocked the two worst quarters today, they turned out way better than expected i will shoot one more coat of primer, block it and then color (IMG:style_emoticons/default/piratenanner.gif) outside it was minus 10, with a windchill of minus 18....i am damn thankful for the heater in the shop...to celebrate i had a beer, it was slushy. |
Lo-Fi Version | Time is now: 20th April 2025 - 02:35 AM |
