914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,182 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Uh (IMG:style_emoticons/default/sad.gif) what if you find that turning your inner adjusters (w/gear in place)
provides no effect IE does not move the inner pad closer to the disc? |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,763 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Seriously you guys didnt get the inners adjusted ?
one or both ? |
914werke |
yup..brand new calipers. No workie on BOTH inside adjusters & yes it has adjustment gearz installed on both sides (now).
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,299 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Sorry Rich, only 6 years late on a reply but, I was looking for this for another customer and just saw this.
If we look at the first picture in this thread: (IMG:http://www.914world.com/bbs2/uploads/post-1110-1228603821.jpg) ...you can see the basic relationship of what's in the "inboard" 1/2 of the caliper. When you spin the adjuster and nothing happens, this means the adjuster shaft is spun up "tight" inside the mechanism in the piston. When it is too tight, it's like a frozen fastener. In turning it, you will be turning the entire mechanism inside the piston shell. This happens if they've sat for a while. If the mechanism inside the shell is spinning, no adjusting will occur. To remedy this, you'll need to overcome the lock by spinning the adjuster gear in a "clockwise" direction at very high speeds with little or no ramp up. This means an air wrench. By turning the gear clockwise, you will turn the adjuster counter-clockwise and with a few short bursts, the velocity and inertia of the adjuster should overcome the mass of the piston and mechanism and release itself. I know we're 6 years late but, hopefully that will help others. (IMG:style_emoticons/default/biggrin.gif) |
tomrev |
Member ![]() ![]() Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None ![]() |
I have to smile; in desperation, I used the same vice grip special, after scratching my head wondering how else to do it, back when I first had to do this. Necessity is a mother...
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,674 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
Great right-up Eric. And good timing.
Even though I did adjust them after putting your new rear calipers on my '73, I'm going to check clearance again as I'm still having a hell of a time getting a firm pedal after NUMEROUS bleeding procedures. Everything is basically new or rebuilt including your 19mm MC, and cleaned rear "proportioning valve" or whatever the correct name is. (IMG:style_emoticons/default/smile.gif) Wonder if some of the horrible spongy brake is too much rear clearance. This is my next project! |
MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,530 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
To remedy this, you'll need to overcome the lock by spinning the adjuster gear in a "clockwise" direction at very high speeds with little or no ramp up. This means an air wrench. By turning the gear clockwise, you will turn the adjuster counter-clockwise and with a few short bursts, the velocity and inertia of the adjuster should overcome the mass of the piston and mechanism and release itself. OK, Now, what's the technique for getting an outer adjuster unfrozen? Same idea except in a counterclockwise direction? I'm currently in a "need to know" situation. |
Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,215 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
The how to restore / modify 914 book mentions removing the pin retainer before adjusting. Is that necessary? Thx.
Eric_Shea |
I like to leave them in. We're talking about the pad springs. The reason being; that's the way the car will be run. I tend not to use feeler gauges for the .004" though. It may be easier to use the feeler gauges if you remove the springs. I run a full rotation while adjusting the outer and the inner separately. I back the adjusters off just enough so there's no rubbing.
Amphicar770 |
Hi Eric,
So, tonight I went to adjust the rears on the rebuilt calipers I received from you. Both sides are missing the gear mechanism? Is this something I should have removed from the cores before returning them? Thx. Mike |
Eric_Shea |
Amphicar770 |
My bad. Next time I should actually read the instructions. (IMG:style_emoticons/default/chair.gif) Yes, I suppose I do need those. If you have, please PM me as to how I can get them from you. Thanks |
Fatboy007 |
Member ![]() ![]() Group: Members Posts: 62 Joined: 23-May 17 From: San Diego, ca. Member No.: 21,124 Region Association: Southern California ![]() |
Fantastic article thank you for the help!
jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,163 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
Dumb question probably. I need to adjust the hand brake. It's a factory six and as far as I know, it has the original calipers, beautifully restored by Eric a couple of years ago. Are they the same, and the procedure the same, as this DYI?
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,804 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
jfort |
thanks, mepstein, for the quick reply. as the restored calipers were installed in 2015, I am hoping for no frozen parts and a quick/easy adjustment
thanks, mepstein, for the quick reply. as the restored calipers were installed in 2015, I am hoping for no frozen parts and a quick/easy adjustment I'm 99% sure that all the ebrake hardware is the same as the 914-4 parts. Only the caliper castings, pistons and some seals are different. Maybe the bolts that hold the caliper halves are different but I'm not sure. |
914werke |
@Eric_Shea So every few yrs its seems I have to revisit this thread (IMG:style_emoticons/default/smile.gif)
Lets try this scenario: Install new R. brakes new pads & set venting clearance. Drive the car over a period of a .5 yr and at that interval need to adjust calipers due to wear (about .5 gone). Go through process as described prior & continue driving. Another 6 months of driving passes & its time for service including replacement of rear pads. By this time the caliper pistons are extended well out of their bores. Logically by reversing the direction of the adjuster's I should be able to retract the pistons into the calipers bores so I can fit the new pads with their increased/ original thickness BUT instead the calipers DONT WANT TO RETURN? Testing the adjuster action in the opposite direction seems to operate as intended (pushing OUT the piston further) What am I missing? Should not this process work for both inner & outer adjusters? |
I think you will have to manually push in the pistons as you screw in the adjuster.
Eric_Shea |
Pressure may be needed to retract extended pistons when installing new pads. We always apply thumb pressure upon assembly when pulling pistons into the bore.
Lo-Fi Version | Time is now: 2nd April 2025 - 01:38 AM |
