3 Pages V < 1 2 3
> 914 Rear Caliper Adjustment Procedure
914werke
post Nov 7 2020, 11:54 AM
Post #41
Ya no joy, is the process to then push them completely free, clean of any rust or crust & reinstall?
Van914
post Nov 6 2023, 05:53 PM
Post #42
Van914
Rich,
Having the same problem today on a PMB rebuilt set. Used wood and pushed the brake pedal to move the pistons and lube the seals. Outside pushed back in the inner piston is stuck and won’t retract.
Tried to open bleeder still no luck.
What did you do to fix?
davep
post Nov 6 2023, 06:37 PM
Post #43
914 Historian
You do realize that the rear pistons do not move freely like the front pistons?
The rears have the adjuster mechanisms, and the free axial movement is minimal. the adjusters HAVE to be used to move the pistons within the bores.
PatMc
post Nov 6 2023, 08:11 PM
Post #44
QUOTE(Van914 @ Nov 6 2023, 06:53 PM) *
Rich,
Is this a freshly installed set of calipers? I'm unclear on what you're doing with a piece of wood.
If fresh rebuilts, the pistons should be all the way retracted when they come out of the box...bolt them on the car and manually adjust them before putting any hydraulic pressure to them.
The adjuster mechanism is retained in the pistons with a circlip. If you apply hydraulic pressure first it can push the pistons off of the adjuster mechanism, and then the mechanism will simply spin in the piston rather than move the piston when you spin the adjuster.
If this happens, unbolt the caliper, open a bleeder, and use a C-clamp to try and squeeze the pistons back in...not too hard, just enough to pop them down over the adjuster machanism so the circlip snaps into place, then they should manually adjust like normal.
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 2nd April 2025 - 01:38 AM
