Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Most Excellent!
silver74insocal |
Senior Member ![]() ![]() ![]() Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California ![]() |
Paging Eric Shea, Mr. Shea Please pick up the courtesy phone. Eric I picked up these Aluminum 911S calipers this morning (rfuerst got a set too) and I set you an eMail to determine re-build costs T.C. thats "shakedown street" underneath the 2 nd and 4th pictures TC you ole dead head! (IMG:style_emoticons/default/laugh.gif) i know cuz i had that sticker on the dash of a 72 pontiac..and the europe 72 one on my bong..high school daze (IMG:style_emoticons/default/wacko.gif) |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,800 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Congratulations! Damn thats going to look really good. I'm starting to get a flared front fender fetish. Please post more pictures and enable me!
Lou W |
"Here Kitty Kitty" my ass...... ![]() ![]() ![]() ![]() Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain ![]() |
Very Nice Job (IMG:style_emoticons/default/beerchug.gif)
moparrob |
Senior Member ![]() ![]() ![]() Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None ![]() |
Eric,
Those harness guides are a great idea. I understand the concerns you had in trying to replicate their design so I came up with my own idea. You can buy these square U-bolts with a 3 5/8" inner dimension, perfect for my 3 inch belts. (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1291010753.1.jpg) I'm going to weld on some extra thick washers, chop off the excess and send them off to the powder coater. They come in various sizes - I just happened to choose 3/8 inch bolts. You can get 7/16 and 1/2 inch also. These particular ones are Stanley part #N244-996. Thanks for the inspiration. |
championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,681 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
Looking good! (IMG:style_emoticons/default/beerchug.gif)
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 124,582 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
bcheney |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States ![]() |
Now that's what I'm talkin about!
badm |
Member ![]() ![]() Group: Members Posts: 213 Joined: 10-May 09 From: Cape Cod Taxachusetts Member No.: 10,350 Region Association: North East States ![]() ![]() |
T.C. Nice to see it with paint. Now comes the fun part! Badm. (IMG:style_emoticons/default/popcorn[1].gif)
badm |
QUOTE Those harness guides are a great idea. I understand the concerns you had in trying to replicate their design so I came up with my own idea. You can buy these square U-bolts with a 3 5/8" inner dimension, perfect for my 3 inch belts. I'm going to weld on some extra thick washers, chop off the excess and send them off to the powder coater. They come in various sizes - I just happened to choose 3/8 inch bolts. You can get 7/16 and 1/2 inch also. These particular ones are Stanley part #N244-996. Thanks for the inspiration. Please don't!!!!!!!! There is a reason that soft steel and corse threads are not used on seat belts mounts, do you want to trust your life to something to made to hold a 2x4 down????? Badm. (IMG:style_emoticons/default/blink.gif) |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
Please don't!!!!!!!! There is a reason that soft steel and corse threads are not used on seat belts mounts, do you want to trust your life to something to made to hold a 2x4 down? The square U-bolts (3/8" thread, mfg unspecified) shown on the McMaster site list a working (not ultimate) strength of 1000 lbs. Each. Anything like this will, I suspect, be ultimately limited to the strength of the firewall if that's what the're bolted to. (If they're part of the cage, you're probably using s different technique for the belt guides to start with.) Back-of-the-envelope - 2000 lb strength, 100 lb torso, 10g impact. I think 3/8" is too small for my comfort, but 7/16" might be OK. I'd want to see the specs. The rear axle and leaf spring mounts on my half-ton truck are in the half-inch range and I promise you they see more than 2000 lb loads on a regular basis. This is not a recommendation, just a suggestion to consider the loads. |
Hontec |
I see things..... ![]() ![]() Group: Members Posts: 261 Joined: 23-September 10 From: Netherlands Member No.: 12,210 Region Association: Europe ![]() |
Please don't!!!!!!!! There is a reason that soft steel and corse threads are not used on seat belts mounts, do you want to trust your life to something to made to hold a 2x4 down? The square U-bolts (3/8" thread, mfg unspecified) shown on the McMaster site list a working (not ultimate) strength of 1000 lbs. Each. Anything like this will, I suspect, be ultimately limited to the strength of the firewall if that's what the're bolted to. (If they're part of the cage, you're probably using s different technique for the belt guides to start with.) Back-of-the-envelope - 2000 lb strength, 100 lb torso, 10g impact. I think 3/8" is too small for my comfort, but 7/16" might be OK. I'd want to see the specs. The rear axle and leaf spring mounts on my half-ton truck are in the half-inch range and I promise you they see more than 2000 lb loads on a regular basis. This is not a recommendation, just a suggestion to consider the loads. I agree, I've been building race/ rallye/ dakar cars for many years and I would personally never attach my harness to that firewall, but like I said, that is my humble opinion....... consider a simple 50 kmh impact and the forces involved......you will be scared how much force your bodymass upon impact will generate and what it will do to a flimsy firewall..... These cars are not structural wonders to start with..........plus they are 35+ years old.... |
ArtechnikA |
Properly, those loops are belt _guide_ loops - not primary attachment points. This allows the belts to be mounted much closer to (or to) the floor. Mounted to the firewall near the floor puts most if that load in shear, while the guide loops pick up only a fraction in tension.
badm |
I was less commenting on the firewall, and more to the product he chose to use for his mount, if you install the proper type of mounts in the boxed portion of the firewall as done on the GT's it has quite a large amount of support. Be safe, thats all. Badm. (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/unsure.gif)
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,649 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Been a while since I checked this thread, man I sure love L20E on a 914!
moparrob |
Properly, those loops are belt _guide_ loops - not primary attachment points. This allows the belts to be mounted much closer to (or to) the floor. Mounted to the firewall near the floor puts most if that load in shear, while the guide loops pick up only a fraction in tension. (IMG:style_emoticons/default/agree.gif) |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,300 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE Orange you glad you didnt change your mind and go with Yellow What's that sposs ta mean weiner? (IMG:style_emoticons/default/mad.gif) |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,790 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
QUOTE What's that sposs ta mean weiner? uhuh yellows faster ? |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
Sweet!!
carr914 |
QUOTE Orange you glad you didnt change your mind and go with Yellow What's that sposs ta mean weiner? (IMG:style_emoticons/default/mad.gif) Actually, when the painter sent me the pictures from his cell phone, he asked me to eMail him back to make sure I got them. I said yeah I got the picture, but's what's with the Orange, I told you Green (IMG:style_emoticons/default/laugh.gif) . He called me back in a panic - I guess I shouldn't have done that to someone that had a Heart Attack 6 months ago. |
Lo-Fi Version | Time is now: 19th April 2025 - 12:25 PM |
