VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,470 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Does anyone have the specs for the 917 shift knobs? I am talking about the ones that were laminated wood.
I am looking for: What wood was used in the lamination What are the dimensions How was it attached. I know someone already makes these, and I could just buy one. However, I am interested in learning how to use a wood lathe and my grandfather is going to give me his and all his tooling for it. Instead of just turning eggs until I get the idea of what I am doing, I figured this would be a more useful project to start with. Zach |
VaccaRabite |
Okay, we have some people saying that they are balsa/mahogany and some saying that they are maple/mahogany.
Can anyone point me to a source that says definativly what they ware made of? I can't see how balsa would deform when laminated with mahogany. Zach |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Purple heart and Cocobolo (IMG:style_emoticons/default/stirthepot.gif)
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,438 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
QUOTE 76911S Registered User Join Date: Jul 2004 Location: Columbus, Ohio Posts: 201 Hi all, I do still make them but they are sold exclusively here http://www.tremotorsports.com/product.cfm?Node=10299 Epoxy coating them would be fine but that was not the way the original ones where finished and the oils from our hands create a great patina after awhile. All the original 917, 907's & 908's used these and the ones I have seen all have a nice worn used look. You can't really say the originals where made with Birch or Balsa because the restoration gurus don't even know for sure what woods where used. I have sold knobs to both Carl Thompson & Dale Miller for use in restoration projects so these seem to be as close as anyone has found to original. All though, original is not always the best... Mark.. From messing with model airplanes as a kid, balsa wood is so soft it would probably split apart while machining and that would be really frustrating learnig curve. |
Jeff Hail |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 ![]() |
The 917 Shift Knob is actually made from turned Birch Plywood. How do I know his. Hans Metzger told me. Balsa would absorb moisture like a sponge and crack as it is very porous. The shift knob was never intended to be light weight. The purpose of the wood was because the linkage transmitted so much heat from the transmission into the drivers hand that wood was used as an insulator.
Attached image(s) ![]() ![]() |
dbu356 |
Member ![]() ![]() Group: Members Posts: 120 Joined: 2-May 04 From: Scottsdale, AZ Member No.: 2,013 ![]() |
I got 2 of them from Mark Cross when he was making them several years back...He may still be making them, I don't know. I'll take pictures and measurements of mine later today if you would like. The link to the 911S registry story is: http://www.early911sregistry.org/forum/sho...ight=shift+knob His email was (is?) macross860@columbus.rr.com David |
sixnotfour |
QUOTE I got 2 of them from Mark Cross when he was making them several years back...He may still be making them, I don't know. same person as my post, he sells exclusively to TRE, wich is in the post also. |
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
QUOTE I got 2 of them from Mark Cross when he was making them several years back...He may still be making them, I don't know. same person as my post, he sells exclusively to TRE, wich is in the post also. I got one of Mark Cross' knobs back when he sold them for like $35. Here is a pic. ![]() They weren't balsa. Here is his post from when he was selling them. It might say what he made them out of. I didn't review it. http://www.914world.com/bbs2/index.php?sho...&pid=248306 |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
How did you get it on he Rennshift? That looks great.
jasons |
How did you get it on he Rennshift? That looks great. You know, I was able to find a factory Porsche crush sleeve. I tried to use it, but it took more pressure than I was comfortable putting on that wood shift knob. If I would have split that knob putting it on the shifter, I would hate myself. So, I cheated and I just used duct tape to act as a bushing between the shifter and the knob. Wrapped the shifter with the duct tape, pressed the knob on. Its a dirty secret but it worked. Consider that a "Duct tape confession". |
PeeGreen 914 |
VaccaRabite |
On the TRE site they say to glue the knob on to the shifter arm.
Zach |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Although I saw this thread I never looked at it, to me who would want a knob made of balsa. Too soft and would look like crap in no time.
Also it has to be to hardwoods, as a softwood and a hardwood would be hard to machine and almost imposable to sand. The softwood will sand more than the hardwood making it rippled. Birch ply could be correct as the Germans loved to use Baltic birch ply. QUOTE Purple heart and Cocobolo Now that peeks my interest...and I have a huge board of purple heart. How about purple heart and black walnut or cherry (IMG:style_emoticons/default/idea.gif) Maybe purple heart and white ash (IMG:style_emoticons/default/idea.gif) |
scotty b |
Maybe purple heart and white ash (IMG:style_emoticons/default/idea.gif) [/quote] OOOOoooohhhhhhhh (IMG:style_emoticons/default/wub.gif) I'll take one please (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
I thought the big board was purple heart, but now that I've looked it's more likely Pernambuco and I do have some pieces of amazon rosewood
A good "type of exotic wood" site is this one: http://www.hobbithouseinc.com/personal/woodpics/ |
VaccaRabite |
Well, I bought enough mahogany and maple to make 3 or 4 knobs.
I could not find birch plywood - but I did not look too hard. So, I guess the idea of the "balsa" shift knob is just a well accepted myth? Zach |
dflesburg |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None ![]() |
Good grief, pay the $75 and be done.
VaccaRabite |
VaccaRabite |
Mahogany and maple glue up.
in trimmed specs are about 47mm tall x 50mm wide. Starting with 5 of them. I have enough mahogany for 1 more knob, and enough maple for 2 or three. But I am out of clamps and got tired of cutting disks. So, starting with 5. Pics! (IMG:http://farm4.static.flickr.com/3470/3223139205_d5838a0db9.jpg) (IMG:http://farm4.static.flickr.com/3495/3223996290_e19d48ea50.jpg) I'm at the in-laws this weekend due to the house flood, so I only brough hand tools with me. Was really relaxing to slow down and just use a coping saw for a while. I'll leave them in the clamps over night and start turning next week some time. Zach |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Finish your dang car already (IMG:style_emoticons/default/rolleyes.gif)
It bugs me when people tell you to take the easy way out, kind of misses the whole damn point. |
VaccaRabite |
Next weekend. I may be able to sell a few of these at Hershey to recover some of the money spent on the house this and next week. Sides, while I'm at the inlaws, not a lot of car work I can be doing. Zach |
Lo-Fi Version | Time is now: 20th June 2024 - 06:28 AM |
