2 Pages V < 1 2
> How to make your CB carb linkage NOT SUCK!
Mark Henry
post Jan 20 2009, 10:30 AM
Post #21
that's what I do!
I like the triad for one main reason that I can see right off the bat...see how the link arm is almost straight 90 degrees to the carb throttle shaft. That gives you no side loading on the carb throttle shaft.
What I don't like is it looks a bit flimsy.
Yours looks good Aaron, but the 90 degrees to the throttle shaft is very important to making it smooth and to stop premature wear of the shaft bearings.
Elliot Cannon
post Jan 20 2009, 12:59 PM
Post #22
Group: Retired Members
Nice project Aaron. Looks like something even I could do. Hey! shouldn't you be looking for a job?
PeeGreen 914
post Jan 20 2009, 01:17 PM
Post #23
QUOTE(Mark Henry @ Jan 20 2009, 08:30 AM) *
(IMG:style_emoticons/default/confused24.gif) flimsy? Didn't apear to be when I had one. Very solid actually.
Aaron's system looks very nice and cost effective (IMG:style_emoticons/default/beerchug.gif)
Mark Henry
post Jan 20 2009, 01:35 PM
Post #24
that's what I do!
QUOTE(Phoenix 914-6GT @ Jan 20 2009, 02:17 PM) *
I said "looks" I can't tell the metal thickness from the pic.
Why I'd be saying that is it does look a lot like the el-cheapo Type 1 linkage at first glance.
Aaron Cox
post Jan 20 2009, 09:36 PM
Post #25
Professional Lawn Dart
Mark,
Are you suggesting that the drop links should be vertical or as colinear as possible with the carb shafts? The position can be adjusted very easy. (they have allen set screws to set the distance from the carb)
I might be min-interpreting what you are asking about.
Kevin,
So you deal with play (up to a half inch) when the motor isnt fully warmed up or super warm?
Swapping out springs would be easy.... but I like to account for the play, versus letting it flop around until warm.
(IMG:style_emoticons/default/wavey.gif)
t collins
post Jan 21 2009, 05:29 AM
Post #26
Aaron whats the McMaster part number for the heim joint you used?
Thanks,
IronHillRestorations
post Jan 21 2009, 08:41 AM
Post #27
I. I. R. C.
Good work Aaron!!
Brett W
post Jan 21 2009, 08:54 AM
Post #28
The Bugpack bell crank works better than the CB cross bar. You have to modify it to remove the slop, but it is a better choice. I have had both and now I only use the Bugpack bell crank setup.
Looks like you did a good job with your mods. I hope it will work right longer than the original design.
Mark Henry
post Jan 21 2009, 09:16 AM
Post #29
that's what I do!
QUOTE(Aaron Cox @ Jan 20 2009, 10:36 PM) *
Mark,
Yes, the droplinks should not push in/out on the end of the throttle shaft.
Think of setting the endplay on a crank, you don't want it push/pulling it in that way as it causes wear.
This is one of the reasons I also like the bellcrank type, BTW I make my own.
Aaron Cox
post Jan 21 2009, 07:43 PM
Post #30
Ahh, The arms are too long is what you are saying... so it is putting a load in the direction of the shaft. Got it...
Look at the triad again, As it goes through the travel, it will put a side load on the shaft also.....
Eric_Shea
post Jan 21 2009, 10:49 PM
Post #31
PMB Performance
Is it 2009 and... did Aaron Cox just post a fuching "How-To" article???
Watch for the flaming, flying, flesh eating sculls!!! Armageddon is upon us!! (IMG:style_emoticons/default/w00t.gif)
Way-ta-go smartboy. (IMG:style_emoticons/default/smilie_pokal.gif)
Aaron Cox
post Jan 22 2009, 08:00 PM
Post #32
Ayup... The end is nigh!
See what else i can modify for fun... LOL
jcb29
post Jan 25 2012, 03:43 PM
Post #33
Bugpac has several linkage products. Which one are you refering to? I also have a 2.0 with dual Webbers and am looking for a better allignment or linkage system.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 4th January 2025 - 10:48 PM
