32 Pages V « < 6 7 8 9 10 > »
> Starting a 1971 IMSA 914 Restoration, A privateer run 914 with Sebring and Daytona history
FourBlades
post Nov 26 2010, 08:45 AM
Post #141
From Wreck to Rockin
That thought had occurred to me.
(IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif)
I may actually have to use metal to build this jig so it does not warp.
I spent a lot of time derusting, treating, and etching primering the innards of the
tunnel. I also welded in a new accelerator tube before closing it up. These guys
loved to drill big holes everywhere so I have been welding up the ones I will not
need. Fortunately, I have the same size hole saw they used so I can make
patches for their holes easily.
John
Hontec
post Nov 26 2010, 09:58 AM
Post #142
I see things.....
Region Association: Europe
QUOTE(trojanhorsepower @ Nov 26 2010, 02:28 AM) *
Ask Hontec if you can borrow his. (IMG:style_emoticons/default/biggrin.gif)
No problem, although the trip might be somewhat challenging.... (IMG:style_emoticons/default/biggrin.gif)
maf914
post Nov 27 2010, 07:34 AM
Post #143
Not a Guru!
QUOTE(FourBlades @ Nov 26 2010, 06:45 AM) *
John
John,
I am curious how the car suffered so much rust damage. Was it left in the open after its racing carrer ended? Salt climate? I always imagine old race cars stored in garages or warehouses, but the IMSA racer must have been somewhere wet. (IMG:style_emoticons/default/idea.gif)
But, great project and great thread. Good luck and keep it going. (IMG:style_emoticons/default/welder.gif)
FourBlades
post Nov 27 2010, 08:49 AM
Post #144
Eventually it was stored in a barn, but the front end must have been wet at some
Point for a long time. All the nooks and crannies were full of leaves and snail shells.
I must have found 100 snail shells in the car. When I opened up the longs to fix
A rust hole they were full of leaves.
The back end of the car is in good shape for a 914.
John
carr914
post Nov 27 2010, 01:07 PM
Post #145
Racer from Birth
QUOTE(maf914 @ Nov 27 2010, 08:34 AM) *
When I found it was in a Barn (really) with some other rusty cars ( Ferrari, Alfa, Renault). The guy was a real car guy and former racer, so I think he just had a thing for cool old cars that just happened to be rusty.
Prior to that it was in Miami ( lots of salt air) and didn't look like anything had happened since it last came off the track. I think it must have been stored outside, maybe under a carport.
The more that I see of it, the more I wish I had kept, but John has the skills to weld (IMG:style_emoticons/default/welder.gif) that I don't have
T.C.
FourBlades
post Nov 29 2010, 07:15 PM
Post #146
Built a jig out of scrap tubing to locate the front suspension points.
The jig is welded to the longs and floor pans. It is reinforced with some angle
iron to keep it from bending vertically.
I measured the suspension location points and they look like they are pretty
good. The jig was built using plates bolted to the suspension points. I left
the front cross member in because it does a good job of maintaining the
relative locations of 4 of the suspension points.
I welded the plates connecting to the suspension points last to minimize
any of the other welding warping it and moving their locations.
John
FourBlades
post Nov 29 2010, 07:27 PM
Post #147
It is not pretty but I think it will do the job. It will only be in place about a week
or two.
Started cutting out the middle of the car up to the new floor pans.
Cut out the head light bucket that was badly rusted. Started cleaning up the
metal underneath to see what shape it was in.
The piece Terry (914xprs) sent me is in great shape with just a little surface rust.
He cut it perfectly up to where the replacement floors start.
The plan is to remove the center of the old car and replace it with the new piece.
I need to trim the car up to the pinch welds and the remove the opposite pieces
from the replacement.
This is major transplant surgery but it will restore the car to good metal in some
critical areas.
John
McMark
post Nov 29 2010, 07:47 PM
Post #148
914 Freak!
Doing these huge panels can be so daunting before starting. But it really is satisfying to bring a trashed chassis back from the brink of death, and in retrospect it's never really that big of a job. (Isn't everything easier in retrospect?)
(IMG:style_emoticons/default/first.gif)
FourBlades
post Nov 29 2010, 07:52 PM
Post #149
Mark,
Yeah, its easy!
Why don't you fly out this weekend and help me put it in? (IMG:style_emoticons/default/biggrin.gif)
Actually, for you, I am sure it would be easy after building the limo... (IMG:style_emoticons/default/welder.gif)
I must admit I spent a lot of time pondering how much to transplant before figuring
it would be best to do as much as possible in one chunk.
John
Hontec
post Nov 30 2010, 04:39 AM
Post #150
I see things.....
John
Are you going to replace parts along the original spotweld seams or are you going to cut up the old chassis to fit in the new part as it is?
Randall
FourBlades
post Nov 30 2010, 06:28 AM
Post #151
Randall,
I am going to replace it along the spot weld seams down the sides.
This should help with lining up the new piece accurately.
The two bulkheads and floors will get joined in the middle of the panels.
John
Hontec
post Nov 30 2010, 08:01 AM
Post #152
I see things.....
QUOTE(FourBlades @ Nov 30 2010, 01:28 PM) *
Randall,
John
That is indeed the best way, I was going to say if you would weld in the new piece like it lays on top of the old one, which would mean you'd have to cut out half of the inner fender along a long straight line, My advise would be to not cut in a straight line but make it stepped, gives a hell of a lot more shear strength..
FourBlades
post Nov 30 2010, 09:50 AM
Post #153
That would make a lot of sense. I am not a big fan of long butt welds in the middle
of panels when it comes to structural strength.
I am going to be adding some tubing from the front shock towers to the front
suspension points, and tie these tubes together across the front of the car similar
to how Jeff Hail did in his "Bringing out the dead" thread. I would be worried about
the strength of the front of the car after all this surgery without these tubes.
This picture was "borrowed" from Jeff's thread.
John
Hontec
post Nov 30 2010, 10:51 AM
Post #154
I see things.....
Good idea!! form and fuction.......looks really good...
FourBlades
post Nov 30 2010, 08:18 PM
Post #155
Spent 2 hours peeling off one side of the donor organ. This is the first time I used
the Blair Rotabroach. These things kick ass. I won't go back to anything else.
They are much more aggressive cutting and stay sharp better than any of the
other spot weld bits I have tried.
Still a lot of work left before the transplant can happen.
John
Eric_Shea
post Nov 30 2010, 10:37 PM
Post #156
PMB Performance
That's a good "pick". Prep is everything. (IMG:style_emoticons/default/smilie_pokal.gif)
PeeGreen 914
post Nov 30 2010, 11:03 PM
Post #157
Nice work (IMG:style_emoticons/default/smile.gif)
arkitect
post Dec 1 2010, 08:57 PM
Post #158
John,
Just found your build thread, cool project, you do good work.
I am always amazed at the innovative ways you come up with of turning a 914 upside down. Keep the picts coming.
Dave
ChrisFoley
post Dec 1 2010, 09:23 PM
Post #159
I am Tangerine Racing
You'll have a fuel cell and oil cooler to install as soon as you get the trunk reconstructed and the chassis flipped upright again John.
Here's what it looks like mocked up. The tubular braces will be ready shortly.
Everything appears to fit together just fine.
I have most of your fuel plumbing together now and the cooler/shroud shipped today.
We plumbed a similar oil cooler installation over the last couple days for a 3.2L conversion, so I have many details already worked out.
watsonrx13
post Dec 2 2010, 06:59 AM
Post #160
Great job John... (IMG:style_emoticons/default/aktion035.gif)
BTW what size Blair Rotabroach bit did you use?
-- Rob
- Lo-Fi Version Time is now: 27th April 2025 - 03:25 PM
