32 Pages V « < 12 13 14 15 16 > »
> Starting a 1971 IMSA 914 Restoration, A privateer run 914 with Sebring and Daytona history
Socalandy
post Nov 23 2011, 10:44 AM
Post #261
Its got to be Yellow!!!
Looks great!! and when the missing parts and holes are fixed on my project it will be time to cut out my front trunk
FourBlades
post Nov 23 2011, 12:37 PM
Post #262
From Wreck to Rockin
Just do what I do before cutting anything:
Measure twice and pray three times.
John
cheshirecat
post Feb 10 2012, 02:47 AM
Post #263
(IMG:style_emoticons/default/cheer.gif) This is really exciting news, when I told my dad he showed up on google, I wasn't yet a member...so I was unaware of your project. My dad is Bob Zulkowski, and I spent many days wearing the race team shirt and dusting that car when it was being shown for display purposes. It woke me up early many mornings. I've never thought about what happened to all of dads old racecars as he is presently on a big boat in the virgin islands, but now I can't help but wonder where all of it's predecessors are as well!
Best of luck to you and your wallet...my first car was a 914 which I paid a cool 3 grand for back in 1986 so I'm a fan for sure. I look forward to seeing how it goes, and you can always ask if you have questions, I'm sure if he can remember (lol) he'd love to talk your ear off about this baby. I'll see if I can dig up any photos of it in better condition as well.
Cathy Z.
carr914
post Feb 10 2012, 04:43 AM
Post #264
Racer from Birth
Cathy (IMG:style_emoticons/default/welcome.png)
I know who you Dad is, but this car wasn't one of his - this a Priviteer car run out of South Florida, DiVella Racing
Series9
post Feb 10 2012, 06:08 AM
Post #265
Lesbians taste like chicken.
QUOTE(carr914 @ Feb 10 2012, 05:43 AM) *
I know who you Dad is...
That sounds dirty.... (IMG:style_emoticons/default/shades.gif)
Cairo94507
post Feb 10 2012, 07:47 AM
Post #266
Michael
Cheshirecat - Carthy- Holy crap! I knew your dad and Troy Powell pretty well and was a regular at Metal Craft with my first 914, ('73 2.0 in sepia brown that your dad did a smoked stripe on just like his six had) and my 2nd six. They worked on that car and ultimately did the 3.0 transplant on my 2nd 914-6 when the original 2.0 punched a rod through the side. I recall your dad's black '71 914-6 quite well and Troy's blue GT flared '70. I am glad to hear your dad is enjoying life on a boat in the tropics. That was always a fun shop to go and hang out.
gms
post Feb 10 2012, 09:15 AM
Post #267
QUOTE(cheshirecat @ Feb 10 2012, 02:47 AM) *
Cathy Z.
Welcome to the club Cathy!
I use to own your fathers car, it is now owned by Doug Wright.
Here is a link about the car:
http://www.914world.com/roadglue/forum/showthread.php?t=768
FourBlades
post Feb 10 2012, 09:46 AM
Post #268
QUOTE(cheshirecat @ Feb 10 2012, 01:47 AM) *
Cathy Z.
Cathy,
It seems like I have a different car from yours but I bet you all knew the folks who owned mine, Manuel Cueto and John Di Lella. Maybe you all have some period pictures that include both of our cars. Di Lella racing went on to race 911s after selling their 914. Maybe you all owned this car after John sold it? I would like to talk to you all about it sometime.
This is one of those projects you have to do yourself unless you are loaded because of the hours it takes. My friend Sean and I have spent 350 hours on the work so far and are only half done. We just chip away at it when we can. (IMG:style_emoticons/default/smile.gif)
John
FourBlades
post Feb 10 2012, 10:00 AM
Post #269
Fixing some holes using the HF shrinker/stretcher set. I wanted one of these tools for a while and as soon as I could think of a reason I needed them I picked up a set. I fixed some curved areas with them and they turned out well.
Found some graph paper card stock that makes great templates.
Used the stretcher on the lip to curve the piece. You have to stretch a little, check the fit, stretch a little, check the fit, hammer some to keep the lip flat, etc. Stretcher jaws leave some marks you can hammer flattter and sand if it matters.
Check the fit in the gas tank area. This was hopelessly rusted so I cut back to "better" metal.
Welded and partly ground down. Need to dremel the hard to reach areas. Leaning over to do this repair for two hours was probably the hardest part. Some parts had to be welded up from under the dash which was also fun.
I've been working on grinding down and cleaning up areas welded by Sean and I. I hate spending the time but I think it is worth it. I will clean up the welds I made to repair rust damage and try not to go down the slippery slope of over restoring.
Welds done by the original owners will be left in their original state. They never ground any welds as far as I can tell.
John
FourBlades
post Feb 10 2012, 10:46 AM
Post #270
Fixing the rusted out rain gutter using the shrinker/stretcher set.
Cut a piece for the patch.
Bend it using the brake I built. I wanted a small one for bending 16 gauge and made this out of scraps plus a few HD bought pieces.
Bend it to the right shape using the stretcher. This has a variable curve that takes a some trial and error to get right.
Hammer it a little to keep it flat.
Make some relief cuts and bend up the inner edge. I used the cut off rusty piece as a guide for the width.
Test fit.
Stand back and check the arc of the gutter. This is part way through adjusting the
arc. It was way too low at first and I am glad I realized I needed to check this
before welding. Most of the time you need to think about 3 steps ahead to avoid
screwing something up.
Tack the ends, then the middle, then in between little by little.
Weld up the relief cuts by clamping a thick copper piece behind the weld.
Grind it carefully, weld some imperfections, grind some more, then sand using 120.
Still more detail grinding to go.
John
cheshirecat
post Feb 13 2012, 03:17 PM
Post #271
I realized that after I posted when I saw a different shot, but you can't 'unpost'...at least I couldn't figure out how to!
FourBlades
post Mar 30 2012, 10:42 PM
Post #272
Been working on mounting the oil cooler and fuel cell.
I have the oil cooler mounted, thermostat mounted, and front tubes mocked up.
The fuel cell could be mounted in a framework of 1 inch angle iron represented by
the cardboard strips. It would be attached by the lip to the bulkhead using the
original aluminum angle used by the original builders for that purpose. It would
have two steel straps all the way around width wise to hold it in place.
I would put some additional short tubes under the halfway point of the lower tubes.
Getting everything to fit around these trunk tubes has been a real PIA but I think it
will be worth it. (IMG:style_emoticons/default/idea.gif)
The fuel cell will clear the oil cooler shroud this way. Once the cross tube is welded
in place it will not be possible to remove the oil cooler shroud anymore as is. I am
thinking of sectioning the shroud and holding it together with aluminum strips and
bolts or making a multiple piece one from metal sheet.
Also considering making the cross tube removable, although I have not seen any
good or easy solutions for that.
John
Cracker
post Mar 31 2012, 08:21 AM
Post #273
Just saw this thread, very impressive you'd take on such a project! Can't wait to see it completed and maybe run with it too.
FourBlades
post Mar 31 2012, 07:41 PM
Post #274
Hey thanks Cracker! I'd like to get to Road Atlanta at some point.
Started mocking up the fuel cell install.
Notched some stubby legs to support the cross tube. These will sit on welded pads.
Fuel cell fits in nicely.
Playing with the fuel pick up fittings and filters. With two of everything there are a
lot of fuel system parts. Will use an angle to attach the lip of the cell the bulkhead.
Will use square tubes across the top attached to straps going around the angle
irons on the bottom. That will provide something to mount the filters to.
Lot of head scratching went into getting this far.
John
racerbvd
post Apr 1 2012, 12:16 PM
Post #275
John,
You guys coming to the Dark Side DE next month??
FourBlades
post Apr 3 2012, 08:28 PM
Post #276
Byron,
I hate to miss it but too busy with many things.
I want to bring my blue 914 next time but it needs an oil cooler and roll hoop.
John
URY914
post Apr 3 2012, 08:56 PM
Post #277
John,
Don't know if you knew about this video but your car is shown at about the 12:21 mark and 14:46.
Sebring 12 Hours 1977...
http://www.youtube.com/watch?v=4kks-yGG_6g
DEC
post Apr 4 2012, 02:21 AM
Post #278
Region Association: Germany
Nice work
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/drunk.gif)
ChrisVCR
post Apr 4 2012, 08:05 AM
Post #279
Great build!
Series9
post Apr 4 2012, 08:42 AM
Post #280
I love this thread. (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 28th April 2025 - 09:33 PM
