pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
i would like to (Re)build up a six( motor) one day, based on a 3.0 or a 3.2
i would like to keep the stock injection on either(for emission reasons) what configurations would you incorporate in the build up |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
if you where building a six...., based on a 3.0 or 3.2 what would you do Sell it and buy a 3.6L ... (IMG:style_emoticons/default/laugh.gif) Andy |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
I agree with the doc on this one. I have all the parts I need (except the 3.2) (IMG:style_emoticons/default/biggrin.gif)
pete-stevers |
if you where building a six...., based on a 3.0 or 3.2 what would you do Sell it and buy a 3.6L ... (IMG:style_emoticons/default/laugh.gif) Andy i do hear that alot but i would like to do the build myself with a smaller bore(in need of a top end) and modifying with the help of machinest.... i am thinking of going with a 3.2 with motronic, and building it out but then again a potent engine can be built off a 3.0 and still use the cis |
if you where building a six...., based on a 3.0 or 3.2 what would you do Sell it and buy a 3.6L ... (IMG:style_emoticons/default/laugh.gif) Andy i do hear that alot but i would like to do the build myself with a smaller bore(in need of a top end) and modifying with the help of machinest.... i am thinking of going with a 3.2 with motronic, and building it out but then again a potent engine can be built off a 3.0 and still use the cis In that case, the 3.2L Motronic would be my next choice ... (IMG:style_emoticons/default/shades.gif) Andy |
LarryR |
Senior Member ![]() ![]() ![]() Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 ![]() |
3.2 the motronic is worth the price difference. However, prices seem to have dropped on 3.6's as of late so your really only talking maybe 1500 ish difference for an extra 70 hp
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
It really depends on what you want. I agree with the point on the 3.6, but that engine will cost alot more to convert.
With you up in the nordern latitudes, you could get by without any auxillary oil cooling for a 3.2 street car. 3.2 Motronic, stock is very cool, reach in turn the key, chipped, even better, no star trek stuff, bolt up-ability, hard to beat. |
LarryR |
It really depends on what you want. I agree with the point on the 3.6, but that engine will cost alot more to convert. With you up in the nordern latitudes, you could get by without any auxillary oil cooling for a 3.2 street car. 3.2 Motronic, stock is very cool, reach in turn the key, chipped, even better, no star trek stuff, bolt up-ability, hard to beat. I actually disagree with the no external cooler on the 3.2 as well as the additional conversion cost of 3.2 vs 3.6. Ok maybe a cam block off plate on the 3.6, the tube that goes where the on engine oil cooler goes, but that is about it... you can fab the coil mount bracket for free... |
Ok maybe a cam block off plate on the 3.6, the tube that goes where the on engine oil cooler goes, but that is about it... you can fab the coil mount bracket for free... The 3.6L does not have a engine mounted cooler ... The block off plate is for free and comes with the engine stock from the factory ... (IMG:style_emoticons/default/biggrin.gif) Andy |
LarryR |
Ok maybe a cam block off plate on the 3.6, the tube that goes where the on engine oil cooler goes, but that is about it... you can fab the coil mount bracket for free... The 3.6L does not have a engine mounted cooler ... The block off plate is for free and comes with the engine stock from the factory ... (IMG:style_emoticons/default/biggrin.gif) Andy I was talking about the one for the power steering side.... but point taken that modifying the on engine oil cooler to work in the 914 is a few bucks... and buying one ready to go is about 500. |
pete-stevers |
thanks guys. i agree the 3.2 is the best choice..but the question is how would you choose to RE- build the 3.2
and when you rebuild... with what components |
number6 |
Member ![]() ![]() Group: Members Posts: 352 Joined: 14-September 08 From: portland, or Member No.: 9,546 Region Association: Pacific Northwest ![]() |
thanks guys. i agree the 3.2 is the best choice..but the question is how would you choose to RE- build the 3.2 and when you rebuild... with what components Pete, you may want to poke around the Pelican 911 tech forum for the info you seek. Much discussion about the 3.2 over the years, covering all builds from stock specs to mild to turbo- & supercharged-wild. Lots of great advice, many straight from some of the best builders around. You may find the following of interest (covers converting the DME brain to EFI): http://wiki.diyefi.co.uk/Converting_a_Motr...x_to_Megasquirt Pre-built, plug-'n'-play Megasquirt Motronic boxes: http://shop.diyefi.co.uk/ If you have your heart set on DME, you may consider bolting up the complete 3.6 induction system (including ECU) to the 3.2, to benefit from the numerous improvements that the former offers. The 3.6 system on the used market is about the same price as the 3.2's - you just need to spend a few hundred extra for the adapters. Unless you have specific criteria for a rebuild, you'll do way better $-wise to shop for already-built motors, or low-mileage originals in good condition. With the latter route, you can probably get 3-4 (or more) motors for the cost of having 1 full rebuild done (w/o needing the induction sys for subsequent buys, the price will really go down!). 3.2s are easily sourced, so I say just find a good one, drive it w/o abandon, and when it goes, just pick up another. My philosophy, at least. I'm running a 3.2 w/o front-mounted oil cooler up here in the Pacific NW. That was one of the major selling points for me, to be able to get away w/o cutting up the front of the car. And the upgrade paths are numerous! -duc |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
I'm going a wacky route with my 3.0... just because.
I'm building a MFI motor that I doubt others would build. Basically, replicating a 2.7RS motor but in 3.0 form. That means: 36mm intakes JE 9.5:1's S-Cams etc... I want usable power for this application (911). Now, if I were to do it again, it might be similar but with PMO's or possibly even the PMO injector set-up. For some reason, anything over 3.0 doesn't interest me. Absolutely NOTHING against those motors, just a personal stopping point I guess plus, I love short strokers for 914's. (real short strokers) (IMG:style_emoticons/default/wink.gif) |
pete-stevers |
if one was purely hypothisizing
could one run a 3.2 intake set up ...on a short stroke 2.8/3.0 built on a turbo case w a 2.0 crank and if so what cams would make the engine streetable i still can't get this combo out of my head Eric you might like a short stroke... but i like a screamer (IMG:style_emoticons/default/piratenanner.gif) |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
(IMG:style_emoticons/default/blink.gif) All that sounds a bit... ummm... well you know (IMG:style_emoticons/default/happy11.gif)
I believe Fordahl used a 3.0l or 3.2l to create Leeds 2.8l and it really screams around. I still want to drive that car (IMG:style_emoticons/default/piratenanner.gif) |
seanery |
There was a 914 with a destroked 3.0 that ended up at 2.8 that I used to see at the tracks here in the midwest. I think it was one of the Kelly Moss prepped cars. It was typically one of the fastest cars on the track. It was absolutely a screamer! Now, it probably wouldn't have been as much fun on the street, though.
Eric_Shea |
QUOTE Eric you might like a short stroke... but i like a screamer Screamer that would be. I personally think S-Cams are the top end limit of "streetable". Compression ratio will also make a difference. I really don't consider my 2.5 streetable. I define streetable by useable torque below a certain RPM. This is exactly why the 2.5 is going in the 914 and the 3.0 will be largely stock S configuration. I think a 3.0 in S configuration should pull close to 240hp with a decent torque range. |
pete-stevers |
But then chappy has a great 3.1 and i hear they really spin too
i have no aversion to going bigger either, a 3.2 or .4 on a 3.0 block would be an ok compromise, but then you might as well destroke a 3.6( but i would like to avoid twin plugs) but really my main goal is to work with the 3.0 or 3.2 with stock induction so i can drive it on the street, and pass emissions once every two years so the s cam is out of the mix and i would like the motor to be happy all around....not to toppy |
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
Hi Steve, great job on the car BTW, I've been following your other thread. Nice colour choice too!
Do you have to pass emissions in BC for the 914? In Ontario anything over 25 years is exempt. of course with our government that could change without notice (IMG:style_emoticons/default/dry.gif) mike |
Lo-Fi Version | Time is now: 26th June 2024 - 05:00 AM |
