Need 1.8 stock engine pictures, Aux. Air Regulator and the Decel Valve |
michaelmoo |
Feb 6 2009, 07:54 AM
Member Group: Members Posts: 312 Joined: 21-May 04 From: Kennesaw, GA Member No.: 2,092 |
I need to get pictures of a 1.8 L-Jet engine to see the location of the Aux. Air Regulator and the Decel Valve and there mounting locations.
Thanks, Mike |
type47 |
Feb 6 2009, 09:24 AM
i'll look for pix but until then, i'll tell you the decel (at least on mine which is stock 74) is located on the passenger side of the engine compartment on the side wall under the hinge and the aux air is under the phlenum on a screw that holds the cooling tin to the case.
michaelmoo |
Feb 6 2009, 09:39 AM
Thanks. No wonder i couldn't find it. I was looking at the tin (engine is out) and couldn't find a location to mount the decel valve. I thought the aux air went under there. Should be on the 1/2 side of the engine, correct?
Pictures would still be great. |
zonedoubt |
Feb 6 2009, 03:54 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Thanks. No wonder i couldn't find it. I was looking at the tin (engine is out) and couldn't find a location to mount the decel valve. I thought the aux air went under there. Should be on the 1/2 side of the engine, correct? Pictures would still be great. I posted some here: http://www.914world.com/bbs2/index.php?sho...4&hl=engine The search function is your friend. (IMG:style_emoticons/default/type.gif) |
zx-niner |
Feb 7 2009, 12:15 AM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
Here are a couple of pictures from my 1974 1.8. Despite the well worn look, the engine ran sweetly and I think it was totally stock.
Decel Valve: Aux air regulator: |
Lo-Fi Version | Time is now: 26th June 2024 - 07:13 AM |
