jc914 |
Member ![]() ![]() Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States ![]() |
I finally finished my major tune up I all need is to do is a valve adjustment. I finally got my new CHT gauge and oil pressure gauge working
http://www.914world.com/bbs2/index.php?sho...89991&st=60 I was able to bring down the oil temp from 250 to 220... (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/smilie_pokal.gif) I have read all the post on CHT temp. I know the range is like 275-375. My question: Is this the same (temp range) for all cars (914s) and different engines. I ask because from what I have read 2.0 Efi run hotter than the others. So if the oil is hotter and engine runs hotter then the CHT gauge should be higher????????????? |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
A 1.7 will produce less heat...less HP than a 2.0 liter.
How the head cooling works will affect the overall temp. More HP produces more heat. Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 04:35 AM |
