6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
Is this a close up of the hole? largest rust hole ever..... that hole with buff right out. Kyle Its a place to through money into and watch it disappear, dark and scary..............It was just a photo of the rear deck lid with some sanding done on it ..I dont know what happened,,,,,, O well |
Solo914 |
Member ![]() ![]() Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None ![]() |
Is this a close up of the hole? largest rust hole ever..... that hole with buff right out. Kyle Its a place to through money into and watch it disappear, dark and scary..............It was just a photo of the rear deck lid with some sanding done on it ..I dont know what happened,,,,,, O well That joke works with, Classic cars, Boats, rvs......wives...... Kyle |
6freak |
well i got 3 otta 4
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,442 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
another neat spot for foam / rust is in the corner of the rear fender just above the tailight. sometimes it just pops out . might want to look.
6freak |
Same side or both??I will be look`n to get all of it out
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
Its on both sides. I'd take it out too.
veltror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None ![]() |
My rust hole is just a little bigger (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif)
Attached image(s) ![]() |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
In order to really find out how bad this is, you'll have to take off the rear wheel and remove the oil tank!
There's no other way to get into that corner from the back. The picture you posted of your engine bay is useless as this is *not* the backside of where the hole is ... (IMG:style_emoticons/default/smash.gif) Andy |
sixnotfour |
(IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/popcorn[1].gif) http://www.pbase.com/9146gt/my9146gt_quart...nel_rust_repair And there's the perfect picture to illustrate why the oil tank needs to be removed to inspect and repair that area! (IMG:style_emoticons/default/poke.gif) Andy Attached image(s) ![]() |
6freak |
In order to really find out how bad this is, you'll have to take off the rear wheel and remove the oil tank! There's no other way to get into that corner from the back. The picture you posted of your engine bay is useless as this is *not* the backside of where the hole is ... (IMG:style_emoticons/default/smash.gif) Andy With all due respect Mr Andy if you truly looked at the pix you would see the oil tank was remove and the pix of the engine bay was just to show its not a big rust issue.I was lucky to be able to post those for I`m not a PC wiz hell i posted one thats just blank LOL ..But I`m still trying still learn`n and still screw`n up.As we say in the AX world ,seat time, seat time, seat time will make you better (IMG:style_emoticons/default/smile.gif) anyway went to the shop yesterday and there is no update to report (IMG:style_emoticons/default/biggrin.gif) |
if you truly looked at the pix you would see the oil tank was removed All i saw was duct tape and the lower oil return line still seems to be connected to something. So i *assumed* you disconnected the hoses and taped up the inlets for the oil tank with duct tape. I'm glad i was wrong ... (IMG:style_emoticons/default/thumb3d.gif) Andy |
6freak |
My rust hole is just a little bigger (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) WOW i thought i had problems bummer Dude |
6freak |
if you truly looked at the pix you would see the oil tank was removed All i saw was duct tape and the lower oil return line still seems to be connected to something. So i *assumed* you disconnected the hoses and taped up the inlets for the oil tank with duct tape. I'm glad i was wrong ... (IMG:style_emoticons/default/thumb3d.gif) Andy It was a PITA tell i got the right tool witch i still have and if anyone needs it i will loan it out ...the tape is just too help keep the junk out of the engine bay when the grinding starts |
Lo-Fi Version | Time is now: 30th June 2024 - 11:59 PM |
