Resurrecting EVIL ! |
Dr Evil |
Feb 17 2009, 08:37 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
If that fuel pump works I might could use it on the bus for the 4bbl (IMG:style_emoticons/default/wink.gif)
I should have a bunch of weekends that I can come down and drop off the car and work on the bus while you are doing the 914, etc (IMG:style_emoticons/default/smile.gif) I dont work a weekend for the next 2mo or so. |
scotty b |
Feb 17 2009, 08:42 PM
Bus is coming home this week. Glass guy called today and said he'll be down tomorrow. I'm running out of room at work (IMG:style_emoticons/default/sad.gif) I guess that's a good thing (IMG:style_emoticons/default/confused24.gif)
Dr Evil |
Feb 17 2009, 08:50 PM
Oh, so you are certain they will be able to install the glass AND that they havent shortened it too much?
scotty b |
Feb 17 2009, 08:57 PM
Oh, so you are certain they will be able to install the glass AND that they havent shortened it too much? NO. I have zero expectations on that windshiled or any other ever going in that bus unbroken and permanently (IMG:style_emoticons/default/dry.gif) |
shoguneagle |
Feb 17 2009, 09:35 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Glad to see the "Great and Most Evil Dr. Evil" is getting everything settled regarding his 914.
Steve Hurt |
Chevota79 |
Feb 18 2009, 01:09 AM
Member Group: Members Posts: 83 Joined: 11-September 07 From: Rocklin, CA Member No.: 8,113 Region Association: None |
HA. I was waiting for this to surface. I must have donated this car to you over 6 months ago. I could not even go 2 months with out some sort project and ended up buy a '72 driver.
Good Luck!! BTW I had nothing to do with all that special body work (IMG:style_emoticons/default/smile.gif) |
scotty b |
Feb 18 2009, 06:47 PM
Glad to know. I called someone a few interesting names in regards to ruining those rocker panels (IMG:style_emoticons/default/mad.gif) I can still use them, along with a set of rusty ones I have, to make one good set. |
Chevota79 |
Feb 18 2009, 06:56 PM
I actually got that car from a guy on this board with plans on restoring it but due to being in my senior year of college with no time I decided to let it go. It did look like there was quit a bit of custom bondo going on there. Actually kinda glad it is your problem now (IMG:style_emoticons/default/biggrin.gif)
I think his name was Richard Linsdal? BTW What was the deal with the home made flares? Didnt they have 1/2" solid rod inside the lip. |
Dr Evil |
Feb 18 2009, 07:00 PM
Keeping it in the family (IMG:style_emoticons/default/smile.gif)
Scotty, I am wanting some rockers that flare out at the bottom at the ends. I know you can do that (IMG:style_emoticons/default/smile.gif) |
scotty b |
Feb 18 2009, 07:17 PM
BTW What was the deal with the home made flares? Didnt they have 1/2" solid rod inside the lip. Ha, that was interesting. The original lip was cut completely off, then the fender was bent outwards and the lip was brazed back on with a slight extension....I think...... (IMG:style_emoticons/default/huh.gif) I'm not real sure what the goal was, it MIGHT have yielded an extra 1/4" of tire clearance. In addition there was a couple pounds of brass rod and a couple pounds of bondo added to make it look better. Ont he plus side the original lip could probably be reused on another car if someone had one that only the lip was butcherd on. I guess I'll save them for now. Mike do you want the antenna hole welded up? What about the windshield squirters ? Right now I'm going to get the interior cleaned up and painted and start stripping the hood. That will keep me busy until the other car gets here (IMG:style_emoticons/default/smile.gif) |
scotty b |
Feb 19 2009, 06:02 PM
Guys I don't give a damn what your paint rep says DO NOT PAINT OVER FLASH RUST !!! This is what happens. I stripped close to half of this hood with a razor blade. (IMG:style_emoticons/default/dry.gif) The larger pieces are just a few that came off that way. Two are upside down so you can see the rust attatched to the paint. (IMG:style_emoticons/default/barf.gif)
Dr Evil |
Feb 19 2009, 06:13 PM
Ik, I want the antenna hole welded as well as the side marker light holes please (IMG:style_emoticons/default/smile.gif)
scotty b |
Feb 19 2009, 06:27 PM
Ik, I want the antenna hole welded as well as the side marker light holes please (IMG:style_emoticons/default/smile.gif) Done. How about the windshield squirter holes (IMG:style_emoticons/default/confused24.gif) |
Dr Evil |
Feb 19 2009, 06:34 PM
I want the squirter holes, I use them for the windshield and have mine converted to power.
Justinp71 |
Feb 19 2009, 10:54 PM
Senior Member Group: Members Posts: 1,595 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Solo914 |
Feb 20 2009, 12:00 AM
Member Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None |
Guys I don't give a damn what your paint rep says DO NOT PAINT OVER FLASH RUST !!! This is what happens. I stripped close to half of this hood with a razor blade. (IMG:style_emoticons/default/dry.gif) The larger pieces are just a few that came off that way. Two are upside down so you can see the rust attatched to the paint. (IMG:style_emoticons/default/barf.gif) Alright, so whats your recommendation, wirebrush, rustmort(conversion), metal etch primer and then go from there??? Just curious, as it looks like I am taking on the painting of my dad 911sc as a side project. Kyle |
PeeGreen 914 |
Feb 20 2009, 12:15 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Elliot Cannon |
Feb 20 2009, 12:19 AM
I wonder if the Doc will still be interested in 914s when he is a rich Beverly Hills plastic surgeon?? (IMG:style_emoticons/default/lol-2.gif)
Spoke |
Feb 20 2009, 06:01 AM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Can't wait to see Scotty's magic on this one.
atomix8 |
Feb 20 2009, 02:30 PM
Member Group: Members Posts: 73 Joined: 10-September 07 From: Annapolis, MD Member No.: 8,105 Region Association: MidAtlantic Region |
Looking good Scotty... Can't wait to see Evil back on the road!
And for those who aren't from the east coast...I wasn't too surprised to find this behind my fiberglass: And that was the good side (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 11:55 AM |
