10 Pages V « < 4 5 6 7 8 > »
> VOX Subaru Swap build
VOX
post Jun 12 2009, 08:38 PM
Post #101
yay summer, finally getting back to the car.
first off lookie what i found huge black window, both the male and female.
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5439.jpg)
retrofiting bumpers! pretty easy took a note card to the 72 parts car lined it up with the edges and marked it accordingly, then brought it over and drilled it out with a 21/62 drill bit. just a little bit bigger then the bolt. worked great for the rear, fronts needed some adjusting.
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5444.jpg)
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5445.jpg)
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5447.jpg)
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5449.jpg)
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5442.jpg)
front retrofitting.
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5450.jpg)
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5451.jpg)
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5453.jpg)
and here we got bored.
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5454.jpg)
RiqueMar
post Jun 12 2009, 09:10 PM
Post #102
Enrique Allen Mar
Hell yeah man, it's all about the old bumpers, and I know you're gonna go blacked out, right?
Awesome, I know how you feel living only a few miles away when you say, "Yay summer" we really have it lucky with this California weather and being able to work outside till like...... 8:30
VOX
post Jun 12 2009, 09:20 PM
Post #103
yea gonna paint the bumpers black, hahaha were definitely spoiled here in ca with nice weather, its actually pretty weird that its so cloudy this week. as for that drive we can go up and down the coast once were both done. maybe hit up a canyon or something.
we cut out the front trunk for the radiator. thinking of cutting out the circles underneath as well.
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5455.jpg)
VOX
post Jun 14 2009, 06:27 PM
Post #104
so i was removing the gas tank and there are 3 wires connected to it, seems like its for the fuel level sender. anyways is there a way to unplug it? i dont want to go snipping the wires if i dont have to.
914forme
post Jun 18 2009, 06:34 PM
Post #105
They pull straight up, you can pry them up gently if they are corroded.
VOX
post Jul 28 2009, 10:30 PM
Post #106
had to removed the expansion pack before removing the plug.
been slacking off but finally put in my order for the KEP adapter plate. trying to decide how i want to cut the inner fender for the radiator exhaust. either cut up the red sections and drilling holes in the center section looks like that part is reinforced. or just cut up the entire section in green like what i see most people do.
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5497.jpg)
McMark
post Jul 28 2009, 11:15 PM
Post #107
914 Freak!
The large reinforcements are for the 75/76 impact bumpers. You've backdated, so they're just dead weight now. Drill/cut right through them.
VOX
post Sep 1 2009, 11:16 PM
Post #108
just picked up the adapter plate, timing belt water pump seals are done. i need to modify the hard fuel lines but not quite sure how yet.
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_5505.jpg)
VOX
post Oct 5 2009, 12:45 AM
Post #109
damn aint that the truth
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_0038.jpg)
adpater plate on with flywheel oh yea and story, got the seals from dr. evil THANKS DR EVIL. put in the seals then the stub axles the engines all done timeing belt replaced rollers and bearings and seals as well as sparkplugs just need to pick up the spark plug wires and put everything back together and figure out how to run the fuel and coolant. started to install the adapter plate however we didnt have the clutch alignment tool looks like we'll have to finish it up next weekend.
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_0039.jpg)
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_0040.jpg)
shrinkwrap?
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_0041.jpg)
transmission was dirty so we took it to a self car wash to use their engine degreser however this particular place didnt have it so we went ahead and sprayed it down with the pressurized soap.
(IMG:http://img.photobucket.com/albums/v325/EvoWizard/IMG_0042.jpg)
dlo914
post Oct 5 2009, 01:16 AM
Post #110
Whatchu' lookin' at?!?!
We also stripped down the intake manifold, cleaned it, and then painted it w/ some high temp red paint. I'll take a pic of it tomorrow or sometime this week.
oldschool
post Oct 20 2009, 01:23 AM
Post #111
QUOTE(dlo914 @ Oct 5 2009, 12:16 AM) *
dude you guy's are cooking man (IMG:style_emoticons/default/aktion035.gif) ....so I think I want the red car to be a subi pusher. let me know when I can stop by and get a close up view (IMG:style_emoticons/default/shades.gif)
dlo914
post Dec 20 2009, 04:49 AM
Post #112
Progress (IMG:style_emoticons/default/biggrin.gif)
(IMG:http://i62.photobucket.com/albums/h88/danlo830/photo1.jpg)
(IMG:http://i62.photobucket.com/albums/h88/danlo830/photo2.jpg)(IMG:http://i62.photobucket.com/albums/h88/danlo830/photo.jpg)
This will be the exact position our engine is gonna sit in the engine bay. At the moment only the tranny is attached to the body. We're gonna work on modding the small car engine mounts. We tried to mock up the engine bar w/ the mounts but the small car mounts overlapped by a guesstimate of 1/2-1". So we're gonna use 5/16 thick angle stock and create some sort of mount to adapt the small car mounts to the stock engine bar.
dlo914
post Dec 21 2009, 12:00 PM
Post #113
I got bored and rendered a image of what our project will look like when we're finished:
dlo914
post Dec 23 2009, 10:45 PM
Post #114
Engine+Tranny have been united w/ the body.
SECHSER
post Dec 24 2009, 12:29 AM
Post #115
sAweet! i've heard you guys talking about this project, and this is the first time i've every seen this thread. looks like some great progress man.. ! (IMG:style_emoticons/default/aktion035.gif)
dlo914
post Dec 24 2009, 02:40 PM
Post #116
QUOTE(SECHSER @ Dec 23 2009, 10:29 PM) *
SOT...are you selling your panel bus? I thought i saw an ad on craigslist of one same year, color, and condition like yours.
dlo914
post Dec 24 2009, 02:43 PM
Post #117
We got the motor mount mocked n tacked and then we took it to the local muffler shop and they professionally welded it for $25.
dlo914
post Dec 30 2009, 12:34 AM
Post #118
Bump...
TravisNeff
post Dec 30 2009, 09:22 AM
Post #119
Is that the mount from smallcar?
DBCooper
post Dec 30 2009, 10:53 AM
Post #120
14's in the 13's with ATTITUDE
QUOTE(Travis Neff @ Dec 30 2009, 07:22 AM) *
The two side pieces are. I intended to use it as well, but then chose to keep the exhaust crossing in the front for the turbo plumbing, so needed to use a different mount.
- Lo-Fi Version Time is now: 19th April 2025 - 01:33 PM
