Pissed off & need advise |
carr914 |
Mar 12 2009, 06:11 PM
Racer from Birth Group: Members Posts: 121,084 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I haven't measured it but if the holes are 2/3mm that space inbetween them seems to be more than that like maybe the 1mm Reid posted. Ok I couldn't stand it I measured my 75 and also discovered a couple of variances. The 4 in my build date has the bottom hole missing and the beginning # symbol has a left beginning bottom horizontal line hole missing. I guess the punches got stuck. Also posted above: The diagonal line has different spacing than the numbers. On both the 914 and a 72 bug the 4 is different between the date and vin. The top left leg on the 914 date (11/74) has 3 holes down and the vin has 4 holes down. All the 7's are the same. The measurements seem to be: height of the char. .278-.280 width .172- .175 vin width 2.550- gap to rt edge .297- between the date and vin .420 date width .980- gap to rt edge .297- down from top .232- vin and bottom .320 This was with calipers holding over the tracing so it could be a little off but not much. It's almost as if the safety stickers were hand punched. I don't know if it will help but I did a pencil tracing on both stickers. I can mail them if you want. I haven't measured it but if the holes are 2/3mm that space inbetween them seems to be more than that like maybe the 1mm Reid posted. No offense man, but if you're going to stand up and say that I'm wrong you might want to take a closer look at the numbers I posted. Also, as has already been noted in this thread the later stickers are different from the early ones, and the 4-cyl versions are different from the 6s...which is what T.C.'s got. Reid disclaimer: didn't get shit for sleep last night, so perhaps a bit (IMG:style_emoticons/default/mad.gif) I truly appreciate everybody's response and willingness to help. Please no dis-record between brothers on my account. I'd hate to take out the switch and take you to the time-out house (IMG:style_emoticons/default/biggrin.gif) T.C. |
orthobiz |
Mar 14 2009, 06:20 PM
Senior Member Group: Members Posts: 1,757 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
If I made a mistake like the shop did, I'd be accused of MALPRACTICE!
Paul |
carr914 |
Apr 8 2009, 02:29 PM
1970 Neun vierzehn |
Apr 8 2009, 02:58 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
TC,
That has turned out better than I woulda thunk. Hopefully, you'll post pics after you have affixed it to the door jamb. I'm wondering, were these stickers always placed exactly in the same place on every car? Paul |
Lo-Fi Version | Time is now: 28th September 2024 - 01:27 AM |
