Smog Pump Help Needed, Belt change |
Derek Seymour |
Mar 11 2009, 09:01 PM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
Does the belt attach to the fan to pump or the alternator to pump?
If on the fan are there two grooves on the cooling fan, one for the alternator belt and one for the smog pump? Or is there supposed to be a secondary pulley coming off the alternator shaft... if so I seem to be missing that. (IMG:style_emoticons/default/confused24.gif) Thanks for ANY help!!!!!! |
Cap'n Krusty |
Mar 11 2009, 09:31 PM
There's a secondary pulley assembly that comes off the crankshaft. It consists of a 3 point bracket and a pulley with a shaft that bolts to the fan hub through a rubber damper. NLA, but I have a couple of good used ones. The Cap'n
Derek Seymour |
Mar 11 2009, 09:35 PM
There's a secondary pulley assembly that comes off the crankshaft. It consists of a 3 point bracket and a pulley with a shaft that bolts to the fan hub through a rubber damper. NLA, but I have a couple of good used ones. The Cap'n AWESOME!!!! Could I buy one off of you? Looks like we are 30 minutes away would you be available this weekend, I could drive down and pick it up? THANKS!!!! |
arvcube |
May 7 2009, 06:27 PM
Member Group: Members Posts: 170 Joined: 25-September 07 From: poway, ca Member No.: 8,147 |
There's a secondary pulley assembly that comes off the crankshaft. It consists of a 3 point bracket and a pulley with a shaft that bolts to the fan hub through a rubber damper. NLA, but I have a couple of good used ones. The Cap'n could I get a pic of this assembly emailed to arvcube@aol.com or posted on this thread? do you still have any more of these? thanks, arvin |
ejm |
May 7 2009, 07:27 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,705 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
I have a couple of these also.....
arvcube |
May 7 2009, 10:05 PM
Lo-Fi Version | Time is now: 2nd January 2025 - 12:47 PM |
