Pics of my 914 I picked up today. |
jcambo7 |
Apr 1 2009, 11:25 AM
Senior Member Group: Members Posts: 1,691 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
Hey James. You said you didn't think it had a Momo hub on there. That is what is on there. I am mailing the wheel out today. Oops... (IMG:style_emoticons/default/blink.gif) ...I thought it was a stock one. Looked stock to me. Guess it would help if I I knew what a Momo hub looked like (IMG:style_emoticons/default/headbang.gif) Well now I do. |
jcambo7 |
Apr 1 2009, 11:26 AM
Yes and the other is part of a brake caliper. Ah I c. Thanks Jon. (IMG:style_emoticons/default/drunk.gif) |
Sleepin |
Apr 1 2009, 11:27 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
The top one is your fuel pump.
So.Cal.914 |
Apr 1 2009, 11:28 AM
Sleepin |
Wow, this has to be the fastest growing thread in history.
jcambo7 |
Apr 1 2009, 11:29 AM
R these for the fuel tank?
jcambo7 |
Apr 1 2009, 11:30 AM
So.Cal.914 |
No...Tunnel inspection plates and e-brake cover?
The allen with the big washer holds down the pedal cover board |
Sleepin |
Apr 1 2009, 11:31 AM
Yes and the other is part of a brake caliper. And if that is aluminum keep looking for the rest of those calipers. Might be good. True! You might end up with a find like I had a little while ago! (IMG:style_emoticons/default/wink.gif) (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Jess%20914s/IMG00635.jpg) |
jcambo7 |
Wow, this has to be the fastest growing thread in history. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
jcambo7 |
Apr 1 2009, 11:33 AM
Yes and the other is part of a brake caliper. And if that is aluminum keep looking for the rest of those calipers. Might be good. True! You might end up with a find like I had a little while ago! (IMG:style_emoticons/default/wink.gif) (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Jess%20914s/IMG00635.jpg) And what find is that? |
dlo914 |
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
R these for the fuel tank? Top right part goes in the circled area: (IMG:http://i62.photobucket.com/albums/h88/danlo830/IMG_5379.jpg) |
ConeDodger |
Apex killer! Group: Members Posts: 23,825 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
R these for the fuel tank? The blue thing on the far left is a calculator. You should have thrown that away before you brought that 914 home! (IMG:style_emoticons/default/lol-2.gif) |
So.Cal.914 |
Apr 1 2009, 11:34 AM
Yes and the other is part of a brake caliper. And if that is aluminum keep looking for the rest of those calipers. Might be good. True! You might end up with a find like I had a little while ago! (IMG:style_emoticons/default/wink.gif) (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Jess%20914s/IMG00635.jpg) And what find is that? Alloy calipers. (IMG:style_emoticons/default/smile.gif) |
jcambo7 |
jcambo7 |
Apr 1 2009, 11:35 AM
R these for the fuel tank? The blue thing on the far left is a calculator. You should have thrown that away before you brought that 914 home! (IMG:style_emoticons/default/lol-2.gif) Doh! (IMG:style_emoticons/default/blink.gif) I knew I forgot a step in the 914 ownership manual! (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
dlo914 |
Apr 1 2009, 11:36 AM
R these for the fuel tank? The blue thing on the far left is a calculator. You should have thrown that away before you brought that 914 home! (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) Tell me about it! |
So.Cal.914 |
Apr 1 2009, 11:37 AM
No...Tunnel inspection plates and e-brake cover? The allen with the big washer holds down the pedal cover board Ah I c... They go inside the car. One in front of the center tunnel, one in the rear of the center tunnel and If that is indeed the e-brake cover it covers the e-brake mechanism so it does not get your fingers. |
So.Cal.914 |
Apr 1 2009, 11:38 AM
R these for the fuel tank? The blue thing on the far left is a calculator. You should have thrown that away before you brought that 914 home! (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) Tell me about it! (IMG:style_emoticons/default/av-943.gif) |
jcambo7 |
What r these?
Lo-Fi Version | Time is now: 25th November 2024 - 12:44 AM |
