Oil pump, Stock or after market? |
72914S |
Feb 26 2004, 07:23 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
The melling pump I put in leaks bad.(I know now, machine for an o-ring). What if any benefits of using the melling over stock. Engine is a 2.0 w/ 96mm arias flat tops,mild cam,stock D jet, larger valves,HD valve springs.Everything internal was polished and or balanced.Flywheel was taken down to 14#.
Brad Roberts |
Feb 26 2004, 07:27 PM
Unless you plan to race the car.. a stock pump works just fine (it worked fine for 30+ years)
Buy a new stock one (I think they are still available) and call it done. B |
72914S |
Feb 26 2004, 07:35 PM
Thanks Brad, just needed a guru`s thoughts.
Brad Roberts |
Feb 26 2004, 07:40 PM
Oh.. you needed a guru's thoughts..
My thoughts for today: I'm tired of cold and rainy. I wish one of the V8 cars I'm working would burn to the ground. Ca. gas prices are STUPID right now. They feed us bullshit about refinery's closing for maitenance.. yeah so... they have done this for 80 years and it NEVER efected the gas prices before. They are F-ing us good. B |
Matt Romanowski |
Feb 26 2004, 07:50 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Not sure I'm a guru, but I like this line, "I think a 200 pound dog is a big f@#*%@! dog."
I've never had trouble with Melling pumps. I wonder what I'm doing wrong? Matt |
Brad Roberts |
Feb 26 2004, 07:52 PM
If you dont know they need to be modified to work properly... the drive gear puts pressure against the front cover and it begins to leak.
B |
DuckRyder |
Feb 26 2004, 08:05 PM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
Be sure you are sitting down when you price the stock one. It's over $200.00
72914S |
Feb 26 2004, 09:14 PM
Got a new one in the box already,it was in one of my parts cars. DUMMY me tried the melling first(also new).This was before I knew.
Lo-Fi Version | Time is now: 26th December 2024 - 06:31 AM |
