dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
Here are a few pictures of some of the work I got done today.
I started by cutting out some more of the bad stuff. ![]() And then I made and tacked in one of the two pieces that will repair the "inner" longitudinal. ![]() After I get done fixing the inner portion of the longitudinal I will weld in the lower wheelhouse panel and then the jackpoint and finish with the fender. After I get that side completely done, I will have to focus on replacing the floorpan and on the lower edge of the firewall where it meets the floor. So much work and so little time. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) |
dlee6204 |
dlee6204 |
My next job was to work on installing the wheelhouse piece.
Here is after I cut out the suspension mount. ![]() More ![]() Different angle ![]() And then after I got as much of the surface rust off with the wire wheel, I coated everything with rust encapsulator. ![]() Here is everything just begging to be welded in. ![]() And this is all I got done today. Tomorrow my goal is to finish the wheelhouse and jackpoint pieces. |
dlee6204 |
(IMG:style_emoticons/default/welder.gif) Well I got it welded in. The car no longer sags! All the door gaps and measurements are what they should be! (IMG:style_emoticons/default/smilie_pokal.gif) I still need to clean up the old suspension mount and then install it but at least progress is being made!
I start a new job this week so progress will slow a bit but I will still keep at it! Here is a list of stuff that still needs to be fixed: Suspension mount, Rear firewall "lip", floor pan, clutch tube, and then a little rust near the front suspension mount. I will probably end up installing an Engman stiffening kit later this summer but right now that is not priority. ![]() |
type11969 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States ![]() |
Doug-
Your updates are an inspiration for me to get working on my teener again. Nice work! -Chris |
jc914 |
Member ![]() ![]() Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States ![]() |
NICE JOB keep us posted (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/popcorn[1].gif)
dlee6204 |
Well I have been pretty busy the past week or two so only a little progress has been made. The suspension mount I had was beyond worth repairing so I am waiting for that part to arrive. Meanwhile I started working on the floor area.
I cut most of the old floor out ![]() I also removed all the floor tar and found some more areas of rust. ![]() Here is a spot I will need to repair ![]() |
dlee6204 |
dlee6204 |
Well I was trimming for the floor and I found some more rust in the driver's side long. I wasn't sure how bad the rust was and now I know. I will have to replace this area as well before the floor goes in. Luckily I have a four day weekend coming up so I will have plenty of time to work on the car!
![]() Here is the new floor held up in place ![]() The center tunnel lines are luckily all solid. The clutch tube broke at some point and the PO did some handy work which I will correct before the new floor goes in. ![]() |
Cupomeat |
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region ![]() |
Wow, great job, and you handle all this with such little drama! (IMG:style_emoticons/default/smilie_pokal.gif)
Great work, thanks and you are inspiring me to finally get a welder of my own and work up to a project like this. |
dlee6204 |
Thanks for commenting! It keeps me motivated!
I took the gas tank out tonight. The rust that was in the passenger foot area extends under the gas tank and into the front wheel-well. The gas tank was also repaired on the bottom at some point and you can hear some rust rattling on the inside. I will most likely just replace it with another tank I have lying around. ![]() ![]() ![]() |
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
Doug, You are moving along really well, fast work. (IMG:style_emoticons/default/smilie_pokal.gif) It is really satisfying when you weld in your new floor. Keep up the pictures. John |
dlee6204 |
Thanks John! (IMG:style_emoticons/default/beerchug.gif)
I did a little more tonight. I got tired of cutting more and more out of the car so I repaired a piece on the tunnel. ![]() ![]() I also cut some more rust out in the passenger corner ![]() And I also cut the seat mounts from the old floor pan and got them ready to use. ![]() |
dlee6204 |
Well I made some big progress this weekend. I first repaired the driver's side long
![]() ![]() I then fabricated a crossmember for the driver's side ![]() And I added a piece for the e-brake switch ![]() sitting in place ![]() And last but not least... I got the floor put in! (IMG:style_emoticons/default/piratenanner.gif) It is just tacked in place but I have to say I was pleased at how nicely it went in and how everything lined up. I had to do a lot of little things before putting it in like cleaning all the mating surfaces and fixing the clutch tube so that took some time. ![]() This week I will work on finishing the firewall, rust spots around the center tunnel, adding the crossmember and the seat hinges. I am also waiting on some parts to get here so more progress to come. Enjoy! |
saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,011 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Well I made some big progress this weekend. I first repaired the driver's side long ![]() ![]() I then fabricated a crossmember for the driver's side ![]() And I added a piece for the e-brake switch ![]() sitting in place ![]() And last but not least... I got the floor put in! (IMG:style_emoticons/default/piratenanner.gif) It is just tacked in place but I have to say I was pleased at how nicely it went in and how everything lined up. I had to do a lot of little things before putting it in like cleaning all the mating surfaces and fixing the clutch tube so that took some time. ![]() This week I will work on finishing the firewall, rust spots around the center tunnel, adding the crossmember and the seat hinges. I am also waiting on some parts to get here so more progress to come. Enjoy! |
saigon71 |
Looks good Doug - great work! I will be tearing into mine in a few weeks. Question, is rust encapsulator the same as POR-15? I am trying to figure out the best stuff to paint with after welding in new panels.
dlee6204 |
I got some more work done. (IMG:style_emoticons/default/biggrin.gif) I received a box today with the suspension console, e-brake mount and cover in it. I went ahead and cleaned up the suspension mount and welded that on. (IMG:style_emoticons/default/welder.gif) Finally my car is able to roll again!
![]() ![]() ![]() ![]() A lot of stuff on the to-do list is just welding and cleanup. I have to finish welding in the floor, crossmember, firewall, e-brake stuff, and both rear fenders not to mention the small rust in the passenger footwell and the front weather strip channel that needs to be repaired. I have also been trying to find a local powder coating place for all the engine tins so hopefully I will have something lined up within the next week. So much to do and so little time. |
dlee6204 |
Wow so its been a while since I have last updated this. I have been extremely busy so I haven't made too much progress on the car. I did tack the seat mounts in place and clean up the ebrake cover and mount so those are ready to be welded in. I also have been making some more progress on the engine. I stripped down the engine and replaced the pushrod tubes and seals and have painted the tin instead of getting them powder coated. I of course adjusted the valves and all that good stuff and now I am just working on reassembling everything! I also forked out the cash to get a new engine harness from Jeff Bowlsby (IMG:style_emoticons/default/biggrin.gif) so hopefully I will have a nice looking and running engine after all is done.
To boost your memory, here is a picture of the engine the day I removed it. ![]() Here are some of the tin after they were painted. ![]() |
dlee6204 |
dlee6204 |
Lo-Fi Version | Time is now: 2nd April 2025 - 02:06 AM |
