73 2.0L Progress Thread, Engine Teardown |
dlee6204 |
Dec 3 2009, 05:00 PM
QUOTE I have really enjoyed reading this thread. You make everything look easy! I have the exact same car, color included. Mine has been repainted the original Marathon Blue. My rear wheel bearings also need to be replaced, but I have been putting it off until I remove the engine for rebuilding. What kind of radio did you install. Is it one that fits the dash without mods? Thanks Bryan! The radio I used was just a spare Kenwood CD headunit that I had lying around. Once the stock radio faceplate is removed, there is a standard size hole in the dash that most stereos will fit in. Mine slipped right in and it only took less than an hour to get everything working. I still have to add basket-weave material around it to make it look better. I'll post pictures later on that shows more of the interior. Originally I wanted to install a stock stereo but with a little budget I just installed the CD unit for the time being. |
dlee6204 |
Dec 5 2009, 08:13 AM
So I did something SAWEET to my car last night. I installed White LED Strips in the gauges to get rid of the yellow halogen bulbs. It came out looking great.
(I apologize for the blurry pictures) I took the gauges apart, painted the interior housing a more reflective color, and installed a strip of LED's and wired it out the back. The difference is staggering. The parts... After I finished the speedo. This shows a big difference. I might be able to see my gauges now... (IMG:style_emoticons/default/w00t.gif) Complete assembly. I also painted the rings on all three gauges as well as the mounting plate. Now I just have to do the center console gauges. |
dlee6204 |
Dec 5 2009, 12:54 PM
hi4head |
Dec 5 2009, 02:08 PM
Member Group: Members Posts: 69 Joined: 4-April 06 From: Lexington, NC Member No.: 5,819 Region Association: None |
Way to go Doug!!
Thing look great and you sure look like you've been busy. Stop by the house sometime when you're home for the weekend. Chris |
jonferns |
Dec 5 2009, 09:39 PM
It's coming along great Doug. Please keep the pics coming.
dlee6204 |
Dec 6 2009, 10:21 PM
dlee6204 |
Dec 6 2009, 10:25 PM
dlee6204 |
Dec 6 2009, 10:26 PM
dlee6204 |
Dec 10 2009, 01:41 PM
I started restoring a set of good taillights I had lying around. I finished up the passenger side and installed it. The old one was badly cracked all over and being held together by the gasket. (IMG:style_emoticons/default/huh.gif)
Before work After I painted the innards and the housing. I cleaned all the contacts and installed a new gasket between the lens and housing. Finished |
dlee6204 |
Dec 10 2009, 01:44 PM
And sometimes its the small things that bring satisfaction. I painted my heater level knob (IMG:style_emoticons/default/biggrin.gif) Last weekend I also got the illumination for the heater knob working too!
dlee6204 |
Dec 10 2009, 01:48 PM
dlee6204 |
Dec 10 2009, 01:56 PM
And I did a little "upgrade" to the rear trunk. I added a second light. To me, it made sense to have one on both sides. This setup helps light up the entire trunk also lights up both sides of the engine compartment instead of one.
I painted the top part of the reflective lens and housing with a reflective paint. This keeps the light reflected down in the engine compartment. |
Gint |
Dec 10 2009, 04:45 PM
Mike Ginter Group: Admin Posts: 16,094 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Those Fuchs look great! And you maintained something like a factory finish it would appear. Are the petals brushed? Did you remove the anodizing?
dlee6204 |
Dec 10 2009, 06:23 PM
Those Fuchs look great! And you maintained something like a factory finish it would appear. Are the petals brushed? Did you remove the anodizing? QUOTE Those Fuchs look great! And you maintained something like a factory finish it would appear. Are the petals brushed? Did you remove the anodizing? Thanks! The petals do have a brushed texture. I started by sanding the entire wheel with 150 grit i believe, then i stepped up to 400. After that I used steel wool on the metal finish areas to give it a very light brushed look. I then masked and painted the black. Then I painted clear over everything. They came out looking better than expected and I'm very pleased with them. The wheels were in such good shape that I debated whether to polish the entire wheels or paint the insides black. I decided that I liked the black look better. |
Cevan |
Dec 10 2009, 06:56 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Those wheels came out great! Nice work. (IMG:style_emoticons/default/beer.gif)
dlee6204 |
Dec 11 2009, 09:58 PM
dlee6204 |
Dec 11 2009, 10:10 PM
Currently the fresh air fan doesn't work so I plan on replacing it. I pulled a good working unit off a parts car and did a little work to it. First, the gaskets on the opening/closing valves were completely toast. With the fan on and valves closed, there was an ample amount of air coming out of the ducting. To fix this, I replaced these foam gaskets with a new foam ring that I cut out of a 1/4" sheet of foam we had lying around. Now, the valves keep out the air when they are in the closed position.
Here is a picture of the old gaskets in place. You can see where part of it was missing around the edge. Here is the new gasket I made compared to the old one. And here it is in the ducting. |
dlee6204 |
Dec 11 2009, 10:14 PM
Here is the fan assembly ready to be installed in the car.
I'm starting to have a pile of parts building up. (IMG:style_emoticons/default/biggrin.gif) I need to start installing them on my car! |
dlee6204 |
Dec 13 2009, 10:24 PM
So I put the 914 on jack stands this weekend to get some stuff done on it. I started by removing the gas tank and going through the air ducting up front. The air valves weren't in sync with the dash controls so i adjusted them. In the process, I broke one of the cables and that was a real pain to replace. I also replaced the fan and it still doesn't work so I need to make sure all the contacts are clean and attached in the dash.
I moved onto the rear end. Recently I've been having a progressive noise coming from the driver's side rear so I wanted to figure out why. I also wanted to fix the negative camber issue and replace the driveshafts while I was in there. After taking off the caliper and rotor, I notice the hub was way too loose in the bearing. I was able to wiggle it back and forth and then it popped out! (IMG:style_emoticons/default/WTF.gif) (I previously replaced this bearing.) I figured that was the source of the noise so I moved onto the camber issue. I replaced the trailing arm with a spare and it still had too much negative camber so I knew it wasn't a bent trailing arm. I ended up putting in approximately 1 cm of spacers to solve the camber issue. I also put in a new wheel bearing (a different brand than the first) in the second trailing arm so now I should be good to go. The driveshafts were replaced in the process. |
dlee6204 |
Dec 13 2009, 10:29 PM
Hopefully you guys don't think thats ALL I did this weekend (IMG:style_emoticons/default/biggrin.gif) I painted my lugnuts to match the wheels.
When searching through the loads of parts we have around here I found an original leather steering wheel. SAWEET. I cleaned up the wheel, painted the metal horn button part, and re-glued the horn pad. I think I will install this on my car and sell the old one. |
Lo-Fi Version | Time is now: 22nd November 2024 - 06:51 AM |
