Injector numbers, 031, 031A |
sunfloweryellow914 |
Feb 29 2004, 10:42 AM
Newbie Group: Members Posts: 49 Joined: 21-February 04 From: Decatur, GA Member No.: 1,691 |
What is the difference between 031 and 031A green injectors? Can you use both kinds on the same engine?
Feb 29 2004, 12:33 PM
Do they have different flow rates?
Part Pricer |
Feb 29 2004, 12:37 PM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
I really can't help you with the particular specs on the injectors. There is a big price difference between the two, so I'm sure that it is something significant. What I do know is:
039 906 031 - 1973 and 1974 2.0L engines 039 906 031a - 1975 and 1976 2.0L engines |
Feb 29 2004, 12:47 PM
914 Idiot Group: Members Posts: 15,066 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I think the "A" suffix parts are used on 75-76, not 74-75 2.0 cars.
As far as I can tell, there is no difference in electrical resistance or flow rate between the two. Which I am pretty sure means that I simply haven't looked at the right things. I wouldn't feel bad about using the "wrong" ones, but I would not want to mix and match on the same engine. --DD |
Lo-Fi Version | Time is now: 2nd January 2025 - 10:14 AM |
