bleeding the brakes, the vacuum pump method |
75914-L20C |
May 29 2009, 08:13 PM
It isn't what you drive, but how you drive that counts. Group: Members Posts: 57 Joined: 29-November 05 From: MN, USA Member No.: 5,204 Region Association: Upper MidWest |
Yeah, the 914 is small enough and has a short enough wheel base that you can work both the brake pedal and the bleed screw by yourself. You need to be a bit of a contortionist (IMG:style_emoticons/default/blink.gif) to have a hand on the bleed screw wrench and get a hand or foot on the brake pedal, but it can be done. The worst is the passenger rear, where you need to use a broom handle as an extension to push on the brake pedal. Pete Klager '75 914 1.8L |
May 30 2009, 12:02 AM
Custom Member Group: Members Posts: 24,638 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
get speed bleeders. You will like them. Rich if you say so. i will ,are they idiot proof?. i checked out the web site , what size fits a 914 more importantly how do they work? small ball inside that prevents air from entering. You fill the reservoir...put a hose on the bleeder and into a jar. open bleeder pump pedal slowly, full strokes, until you get solid fluid out of each bleeder. Rich |
nycchef |
May 30 2009, 06:30 AM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
[small ball inside that prevents air from entering.
You fill the reservoir...put a hose on the bleeder and into a jar. open bleeder pump pedal slowly, full strokes, until you get solid fluid out of each bleeder. Rich [/quote] damn rich this is too much, now i need a jar! just kidding ordered the bleeders last night. be about a week so i'm gonna do a traditional 2 person bleed tomorrow |
nycchef |
May 30 2009, 09:16 PM
o.k the speed bleeders are in the mail. i was going to bleed the brakes with a helper ( my reluctant wife) tomorrow. here is my question if i bleed them now and then put on the speed bleeders will i have to go thru the whole process again or should i wait, install the bleeders and then put my wife thru this. (IMG:style_emoticons/default/confused24.gif)
BK911 |
May 30 2009, 09:34 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Check out this thread:
http://forums.pelicanparts.com/showthread....ghlight=bleeder Written by one of the smartest guys I know. (IMG:style_emoticons/default/biggrin.gif) |
jt914-6 |
May 30 2009, 09:57 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
That is a good way to do it if you have a compressor/regulator handy at home. At the track you'd need it there too or a air tank/regulator. My '74 doesn't have the overflow hose. It's like it never had one. Where the hose is supposed to be, it is flat and smooth like it was made that way. Does anyone else have a resevoir made like this????
At least the pressure bleeder/spray bottle type is more portable than an compressor when not at home. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:26 PM |
