URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,294 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
How long before someone asks about the muffler....??? What's up with that Muffler? (IMG:style_emoticons/default/biggrin.gif) T.C. 3 hours for you to ask. (IMG:style_emoticons/default/biggrin.gif) |
URY914 |
This car has stainless steel heater boxes. (IMG:style_emoticons/default/biggrin.gif)
This car has been sprayed with undercoating. (IMG:style_emoticons/default/mad.gif) They even drilled and filled the longs. You can see the plugs they used to cover the holes in the door jambs. The bottom of the trunk is sprayed and the anti-roll bar. (IMG:style_emoticons/default/sad.gif) Do I need to cut off the old muffler heat shield from the rusted trunk floor and weld it on the new trunk?? (IMG:style_emoticons/default/confused24.gif) |
bcheney |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States ![]() |
Paul...I am soo relieved that you have joined the jackstand club....However, I bet you'll get fininshed with this project before I get my six conversion on the road!!! Damn you son!!!!
URY914 |
Thanks Brian,
It least we'll both be done before TC get his car painted (IMG:style_emoticons/default/lol-2.gif) |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,313 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
That's just wrong, the price on the sheet metal just doubled, I mean squared, I mean multiplied, I mean (IMG:style_emoticons/default/headbang.gif)
T.C. |
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
Glad to see you are working on the car. I remember it had a really good sound to it. How are you going to replace the floor pans? Are you gonna drop the engine and rotisserie it? John |
URY914 |
Sorry buddy, I knew your ears would be burnin'
URY914 |
Glad to see you are working on the car. I remember it had a really good sound to it. How are you going to replace the floor pans? Are you gonna drop the engine and rotisserie it? John I don't have a rotisserie so I'll have to figure something else out. Maybe I'll build some plywood rockers and put it up on it's side. No, that's a crazy idea. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/smile.gif) |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
C'mon Paul..
You lived in Florida long enough to know that if you DON'T apply undercoating, you have a car with a severe case of Florida Cancer..... And, undercoatings are handy to hide rampant cancer...... er I mean cosmetic blemishes..... All those years in Florida taught me to buy a used car with a faded paint job and aincient rustproofing rather than a shiny newly painted one with newly redone rustproofing... A little expanding foam or a foil patch, a sanding block, and an application of rustproofing and it's better than new.... (IMG:style_emoticons/default/blink.gif) |
URY914 |
The rusted sheet metal is now out. I bought this little die grinder to help get into those hard to reach spots to grind the welds down.
$23.99 at Northern Tool. I know, cheap tools never last. (IMG:style_emoticons/default/headbang.gif) Attached image(s) ![]() |
carr914 |
Did you get your Lizard Stickers for the front fenders?
T.C. |
URY914 |
URY914 |
Clean as a baby's bottom.
URY914 |
I also have a hole at the left side bumper bolt. A patch should work here easy enough.
URY914 |
After:
It gets hidden by the bumper so it isn't the prettiest weld in the land... (IMG:style_emoticons/default/welder.gif) Attached image(s) ![]() |
URY914 |
This is the inside. I filled in with seam sealer so no water gets between the old and new metal:
URY914 |
I've cut the new trunk floor to fit and have test fit it. I'll be drilling holes in it and will be "spot" welding it back in. The welds are really more like rosette welds, easier than trying to continuously weld up the edges. I'll cover the seams with sealer.
I have weekend planned. Of course I'll be watching the 24 Hours of LeMans as well. (IMG:style_emoticons/default/smilie_flagge6.gif) (IMG:style_emoticons/default/smilie_flagge24.gif) |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
When you get a chance...if that is a triad muffler...please video tape it from behind while its running..I would really like to hear that before I decide to buy it...I dont want a super loud one...but a bit louder than the bursch would be cool.
Rich |
URY914 |
Rich,
it is a Triad and it does sound good. People do comment on the sound and it is not load at all. |
Derek Seymour |
Member ![]() ![]() Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California ![]() |
When you get a chance...if that is a triad muffler...please video tape it from behind while its running..I would really like to hear that before I decide to buy it...I dont want a super loud one...but a bit louder than the bursch would be cool. Rich Have you seen this http://www.youtube.com/watch?v=NBf1cpu2A2k ? |
Lo-Fi Version | Time is now: 25th June 2024 - 04:59 PM |
