URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,294 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Work continues on the rear trunk but that front end just has to GO!
This is the so called "IMSA" front end which is supposed to be used with big wide front flares. When not used with flares A LOT of filler must be used at the front of the fenders. As you will see...... Attached image(s) ![]() |
URY914 |
The body man filled in the gap between the edge of the front end and the highlight eyebrow. And that is where the rust started.......
URY914 |
So lets start taking it apart shall we???...
URY914 |
URY914 |
URY914 |
That is about 5/16" worth of bondo (IMG:style_emoticons/default/w00t.gif)
Applied in three separate "lifts" or layers Attached image(s) ![]() |
URY914 |
It was not bolted on using the factory bumper bolts. There was a popped riveted piece of aluminum and than it was fiberglassed and bondo'd on.
URY914 |
URY914 |
Driver's side = same shit.......
URY914 |
The joys of previous owners.
Let me say again, Rouser who I bought the car from did not do this. Attached image(s) ![]() |
URY914 |
URY914 |
Attached image(s) ![]() ![]() |
URY914 |
FOR SALE
URY914 |
URY914 |
Here is another example of quality work.
The inside of the side marker hole.... Attached image(s) ![]() |
URY914 |
And the outside after grinding off 1/4" of bondo.....
URY914 |
Now I have a lot of bondo removal to do and I need to weld up the side marker holes and some rust holes. (IMG:style_emoticons/default/welder.gif)
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
Ahhh, nothing like a good, meaty restoration thread with lots of pictures of bondo, rivets, and DAPO work. (IMG:style_emoticons/default/popcorn[1].gif) Can't wait for the fix. (IMG:style_emoticons/default/welder.gif) Glad to see you are restoring that car. The triad sounded great when I was over there. What color is it going to be? John |
URY914 |
What color is it going to be? John Excellent question. I've torn between the red which would match my race car and be the same color scheme that I've owned since 1979 and the original Olympic Blue you see hiding under the red. What say you friends???? (IMG:style_emoticons/default/confused24.gif) |
RiqueMar |
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California ![]() ![]() |
I know how you feel with the Bondo. A parts car we had just before we purchased mine had a very wide set of flares....... made out of bondo. Can you picture it? Imagine a 914 with flares in the back..... but the entire flare is made of bondo. (IMG:style_emoticons/default/chair.gif)
Bad PO, Bad! |
Lo-Fi Version | Time is now: 25th June 2024 - 05:28 PM |
