PNW transmission rebuild clinic planning thread, Weekend of Sept 12th! Party!! |
Dr Evil |
Sep 4 2009, 11:14 PM
Send me your transmission! Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
It looks like Todd and I need to come on Fri since there will be so many of you there (IMG:style_emoticons/default/smile.gif) I already have your monies so if you decide you dont like me on Fri night, too bad (IMG:style_emoticons/default/tongue.gif) Just kidding. (IMG:style_emoticons/default/wink.gif)
914werke |
Sep 4 2009, 11:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,251 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Doc will you cover conversion of a tail to side shift box?
914werke |
Sep 4 2009, 11:30 PM
I would say the area by my house is not really for younger riders. Most of the trails round here are close to expert. I ride my beta trials bike on a lot of them. They just lead off into the woods. for miles. I don't have any trails on my property. Unless someone went with him to show him which trails to take, he could easily find himself at the bottom of a mean rocky hill.... Trailers not a problem. See you friday. Thanks then Ill prolly leave him home (IMG:style_emoticons/default/biggrin.gif) |
Dr Evil |
Sep 5 2009, 12:44 AM
my928s4 |
Sep 5 2009, 08:30 AM
Member Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest |
More than about 1/16" play is too much. You can pnly get a pic of the input bearing under 1st gear (the small one). The rest will require disassembly so dont bother. You most likely need an input shaft bearing. Its good others are bringing core boxes to part as I think I may run out of parts (IMG:style_emoticons/default/smile.gif) The whole PNW will be shifting like a dream after this! This is about the best shot I could get, not sure it shows much though. |
Dr Evil |
Sep 5 2009, 01:57 PM
That shot actually tells us a lot! You have the aftermarket steel caged version of that bearing. This is a great thing as they are much stronger. There has been a large increase in the incidence of broken output shaft bearings, but you need to be able to pull some parts that I will help you with to see it. No worries.
PanelBilly |
Sep 5 2009, 04:29 PM
914 Guru Group: Members Posts: 5,825 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Any of you guy willing to haul my tranny and a folding table down so I can drive my new SL? I can haul a load of ribs in the car, but not the tranny and table too.
Parts are in Auburn and I need to gather up all the tranny stuff, but I could have it ready early in the week. |
Dr Evil |
Sep 5 2009, 04:38 PM
Dude, it is for RIBS! Please (IMG:style_emoticons/default/smile.gif)
Jakeodoule |
Sep 5 2009, 04:49 PM
Member Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
Leave the table, Bring the ribs, trani and SL.
I've got at least 6 work stations no problem. can maybe come up with 2 or 3 more. I was just think if anybody had a good table and could bring it they should. |
my928s4 |
Sep 5 2009, 06:28 PM
my928s4 |
Sep 5 2009, 06:46 PM
Here is a pic of the case, would not believe how long it has taken to get like that .. must have leaked from every orifice for 20 years and then some underseal just to top it of.
Wonder if I should pick this up on the way down and see if it has a better gearbox than mine .... 1974 project on Craigslist |
Dr Evil |
Sep 5 2009, 07:55 PM
The roughness in the center of the gear is normal, it is the factory way they are. The roughness of the Reverse (flat) teeth however is due to habitually grinding R (IMG:style_emoticons/default/wink.gif)
$700 for a car. I hate you Westerners. That car would be double here or more. |
914werke |
Sep 7 2009, 05:15 PM
Another question: is there a benefit to using the 911.xxx.xxx 901 case w/the extra boss at the bottom (ala tail shift) vs the 914. case ?
Dr Evil |
Sep 7 2009, 05:47 PM
No, none at all. It may actually be a detriment as the vent is in the wrong spot and might interfere with placement in a 914.
helios |
Sep 8 2009, 09:46 AM
Member Group: Members Posts: 234 Joined: 15-May 08 From: Bellingham Wa Member No.: 9,055 Region Association: Pacific Northwest |
Is the count on the 1st page of this thread accurate Dr.? I'll be heading down to spectate. I may bring the 914 if weather looks decent. Still need to get the wipers operational.... (IMG:style_emoticons/default/headbang.gif) Jake, could you PM directions. I'll be tenting it. |
JRust |
Sep 8 2009, 11:49 AM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Drained both boxes & pressure washed them. They cleaned up pretty darn good. I did notice my box for my LE has had the tranny ears welded back on. I'd like to replace it with one that hasn't been broken if there is an extra there. I am bringing a spare tranny for parts. It has the rear cone but is broken by the speedo hole. So looking for one spare tail cone for a side shifter.
Everything is ready to go. Spare tranny apart in a box. "H" gear is in a box in the box. Foldup table is ready. Now I just need to coordinate with anyone wanting to caravan up friday night (IMG:style_emoticons/default/biggrin.gif) |
J P Stein |
Sep 8 2009, 12:01 PM
Drained both boxes & pressure washed them. They cleaned up pretty darn good. I did notice my box for my LE has had the tranny ears welded back on. I'd like to replace it with one that hasn't been broken if there is an extra there. I am bringing a spare tranny for parts. It has the rear cone but is broken by the speedo hole. So looking for one spare tail cone for a side shifter. Everything is ready to go. Spare tranny apart in a box. "H" gear is in a box in the box. Foldup table is ready. Now I just need to coordinate with anyone wanting to caravan up friday night (IMG:style_emoticons/default/biggrin.gif) I'll bring a couple for your perusal......cheep, too. |
thompson-mfr |
Sep 8 2009, 01:14 PM
Thompson, Ryan Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
How many people are actually driving their 914 to the event? I am planning on it!
thompson-mfr |
Sep 8 2009, 01:36 PM
montoya 73 2.0 |
Sep 8 2009, 01:54 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
Everything is ready to go. Spare tranny apart in a box. "H" gear is in a box in the box. Foldup table is ready. Now I just need to coordinate with anyone wanting to caravan up friday night (IMG:style_emoticons/default/biggrin.gif) Jamie, I will be coming up around 5:30 - 6ish around your way. Give me a call / text or PM me the address. This is going to be a kick ass weekend! |
Lo-Fi Version | Time is now: 5th July 2024 - 10:39 AM |
