Brake Questions, How to drain all the fluid |
EdwardBlume |
Jun 21 2009, 12:41 AM
I'm taking the brakes / suspension off now....
Can I just drain the brake fluid via the bleeder pts, or do I need to blow them out using pressure? Will fluid stay in the lines? How much fluid is in the whole system? |
Gint |
Jun 21 2009, 08:34 AM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I'm taking the brakes / suspension off now.... Can I just drain the brake fluid via the bleeder pts, Yes QUOTE or do I need to blow them out using pressure? Depends on what you want to do. If you blow them out they won't drip all over the place. QUOTE Will fluid stay in the lines? How much fluid is in the whole system? No. See previous comment. They will drip and drain over time if left with fluid and not capped off somehow. QUOTE How much fluid is in the whole system? Don't have a clue. Not much though. |
zonedoubt |
Jun 21 2009, 09:34 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
GeorgeRud |
Jun 21 2009, 09:39 AM
The more you drain it, the more air you'll have to get out of the lines later. If you're just replacing calipers, I'd let a little drip out and just have to do a regular brake bleeding when you are done.
I've been using the Speed Bleeders with good success. You may also consider using some of the different branded brake fluids that are colored to know when the old fluid has been replaced if you're concerned about getting all the old fluid out. |
jt914-6 |
Jun 21 2009, 09:48 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
To get fluid out of the resevoir, get a large syringe and get it out with it. That would be at least that much you'd not have to deal with....I totally agree on using different color fluid each change. As has been said, you know when all the "old" fluid is gone....
pcar916 |
Jun 21 2009, 01:18 PM
If you want to keep the fluid in the system while working on it, get a pole or something and hold the pedal in about an inch or so, or halfway down. This will seal the inlet and keep fluid in the reservoir and MC until you're ready to bleed later. Then you can remove the calipers at will.
But if you're replacing with new calipers I wouldn't want to force old fluid through them. The best thing is to bleed before the calipers are replaced, then you have new fluid in the whole system. Bleeding then is limited to the calipers. The pedal half-held will retain the new fluid until you get the calipers on. I've never blown them out with air. You'll get much more movement out of the fluid bleeding under pressure than air under even higher pressure. Good Luck! |
Lo-Fi Version | Time is now: 26th September 2024 - 05:30 PM |
