Thursday, 3 April 2025 |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,171 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Andy, your example shows the pink code bar, is that what I should be looking for? The "code" in pink is needed to show you what you need to type. I have to wrap it in a "code" block because otherwise what i type would show the actual video and not what you need to type. Makes sense? (IMG:style_emoticons/default/biggrin.gif) ONLY type the words in the white section of the "code" block. You start by typing the word youtube with the brackets around, then you type the youtube video identifier C6b54bZepoA the you type the word youtube with the brackets around but precede youtube with a forward slash. Just like shown in the white portion of the "code" example below. It's really as easy as just typing this out: CODE [youtube]C6b54bZepoA[/youtube] |
phillstek |
Member ![]() ![]() Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None ![]() |
(b)lHq9s1Sw7xA(b)
phillstek |
(b)lHq9s1Sw7xA(b) Nope ... not (b) ... Look at the example above your post ... (IMG:style_emoticons/default/shades.gif) |
phillstek |
(b)lHq9s1Sw7xA(b) Nope ... not (b) ... Look at the example above your post ... (IMG:style_emoticons/default/shades.gif) I'll try again https://www.youtube.com/watch?v=lHq9s1Sw7xA |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I think you're missing a letter
I think you're missing a letter (IMG:style_emoticons/default/agree.gif) Youtube tells me that lHq9s1Sw7xA is not a valid video tag ... (IMG:style_emoticons/default/idea.gif) |
Jeffs9146 |
Got it!! (IMG:style_emoticons/default/piratenanner.gif)
McMark |
It's a bit tricky. Nice work! |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I do seem to have problems when the code ends with "=related" (or ends with = anything), I've tried doing it with and without the "=related" ending and still have problems.
What am I doing wrong in this case? Example: (youtube)XYZ(/youtube) no problem (youtube)XYZ=related(/youtube) problem |
I do seem to have problems when the code ends with "=related" (or ends with = anything), I've tried doing it with and without the "=related" ending and still have problems. What am I doing wrong in this case? Example: (youtube)XYZ(/youtube) no problem (youtube)XYZ=related(/youtube) problem Embedding youtube videos here only works with the youtube ID tag. You can't add any additional parameters, like "related". That won't work. You need to strip off anything that is not part of the actual ID tag. (IMG:style_emoticons/default/shades.gif) |
phillstek |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,913 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Trying Google videos
http://video.google.com/videoplay?docid=-344275451296655274# [google]344275451296655274#[/google] (IMG:style_emoticons/default/confused24.gif) |
McMark |
Nope. (IMG:style_emoticons/default/tongue.gif)
rick 918-S |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
o.k. im struggling.
youtube is not what it used to be. Now i cant get it to work.... what do i type to make this one work???? http://www.youtube.com/watch?feature=endsc...YZT_B0&NR=1 |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 124,351 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
I have a bit part in this Video & I have all the Important Helmets
https://www.youtube.com/watch?v=C_goFIeOWPw ![]() |
Let me try (youtube)<! (IMG:style_emoticons/default/stromberg.gif) ! width="420" height="315" src="http://www.youtube.com/embed/C_goFIeOWPw?rel=0" frameborder="0" allowfullscreen></! (IMG:style_emoticons/default/stromberg.gif) !>(youtube) Nope, like this (without any of the other crap, just the video ID inside opening and closing youtube brackets: CODE [youtube]C_goFIeOWPw[/youtube] https://www.youtube.com/watch?v=C_goFIeOWPw |
jsayre914 |
o.k. im struggling. youtube is not what it used to be. Now i cant get it to work.... what do i type to make this one work???? http://www.youtube.com/watch?feature=endsc...YZT_B0&NR=1 what part of this vide is the id tag, im good at doin this, but i cant find the i.d. on this one i tried every combo (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 3rd April 2025 - 03:17 PM |
