Latched Front Trunk, Need help opening the front trunk after the cable broke |
924GTS |
Jun 29 2009, 09:56 PM
Newbie Group: Members Posts: 9 Joined: 18-February 05 From: Lewiston, ID Member No.: 3,626 |
OK, I've bee working on my 914 and I went to open the front trunk this afternooon and It would appears that the cable has broken. I have been searching the forums for a solution, but I haven't yet been able to find out how to open it. It can't be that uncommon of a problem. Could someone please lend a hand or point me twards the post taht discusses how to open it?
tod914 |
Jun 29 2009, 10:13 PM
If the cable snapped by the pull handle, you should be able to get some vise grips on the snapped cable to open it. If it's from the latch side, not sure how you approach that. I'm not sure what if any access you would have by the bumper.
tradisrad |
Jun 29 2009, 10:15 PM
you can remove the front bumper and get to the latch and easily open it.
924GTS |
Jun 29 2009, 10:19 PM
Thank you!!! Now all I have to do is go get some tools, I uh placed them in the trunk before I closed it.
924GTS |
Jun 29 2009, 10:59 PM
Please forgive the SAQ. Bumper off, and I am staring at three nuts that look to be welded to the sheet metal. Are they welded in place? Do I try to drill them out? Inquiring minds want to know.
jaxdream |
Jun 29 2009, 11:33 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Great you're about there , in the middle there is a little rubber plug that you carefully pry out , screwdriver , scratch awl , slide a slotted screwdriver in and lever the latch open. The factory provided this arrangement just in case the cable broke , this is for the front trunk . (IMG:style_emoticons/default/piratenanner.gif)
Jaxdream |
Jun 29 2009, 11:38 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Now,
When you finally get it open...look at the routing of the cable. the fix for the 356 and the boxster is to add an extra piece of piano wire that is a backup...so you dont need to remove the bumper. Run the wire out a hole into the drivers side fender...just make a loop on the end and leave it there just in case. Rich |
924GTS |
Jun 29 2009, 11:40 PM
You guys are awsome! Thank you very much!
Lo-Fi Version | Time is now: 26th September 2024 - 05:32 PM |
