1970 Neun vierzehn |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 ![]() |
Correct center caps for these..............
Attached image(s) ![]() ![]() ![]() |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
There is a guy on ebay that makes billet versions. $89? I think. Also advertised on the Samba.
A&PGirl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None ![]() |
![]() The pieces circled for '72-'74 specific columns. A cheaper #3 made to the same quality of the other 2 parts would be nice too. |
A&PGirl |
-Front Turn Signal Housings
-Tail light housings -Headlight housings -All the late e-brake stuff -Side shift rods Metal body parts: -R & L front fenders -R & L front wheel housings -R & L Hinge pillar (914 501 903 10 & 914 501 904 10) -Front cross panels for early & late (914 502 031 12 & 914 502 031 13) -Front panel between gas tank & trunk space for early & late (914 501 051 11) -Front R & L headlight housing (914 502 041 11 & 914 502 042 11) -Front Trunk floorpan -' R & L Corner plate': frt floorpan reinforcement for a-arms (914 507 041 10 & 914 507 042 10) -R & L 'separator for wheel housing cross panel front' early & late (914 501 115 10 & 914 501 116 10) -Reinforcement for front axles (914 501 059 00, 914 501 057 00 & 914 501 164 10) |
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
There is a guy on ebay that makes billet versions. $89? I think. Also advertised on the Samba. I know those as well; good, better than nothing, but not quite right, The shape is wrong. I second some new center caps George; everyone with any of the factory alloys probably needs at least one; I need 4 and would probably buy 8 |
[quote name='MDG' date='Jul 5 2009, 05:53 PM' post='1188713']
[/quote] I know those as well; good, better than nothing, but not quite right, The shape is wrong. I second some new center caps George; everyone with any of the factory alloys probably needs at least one; I need 4 and would probably buy 8 [/quote] (IMG:style_emoticons/default/agree.gif) |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Does anyone make the rubber circular plugs that go in the front panel behind the front bumper?
tod914 |
I'd go for the caps too. Couple sets.
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
tod914 |
NLA Paul.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,911 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
There is a guy on ebay that makes billet versions. $89? I think. Also advertised on the Samba. I know those as well; good, better than nothing, but not quite right, The shape is wrong. I second some new center caps George; everyone with any of the factory alloys probably needs at least one; I need 4 and would probably buy 8 we have some new ones. Will be in the special to be mass mailed in the middle of July. Nice new product for us. |
kart54 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 544 Joined: 27-January 05 From: Ventura, California Member No.: 3,520 ![]() |
I don't need them because I bought most of the good stock that was available when I found out they were NLA, but the hose that runs from the airflow meter to the throttle body on the 1.7 fuel injection. If you run SCCA or Vintage as a road racer in a class that requires stock pieces on the inlet side of things then you need this. Most of them I have seen have been cracked in the bellows portion of the hose due to age and vibration. People have resorted to fixing them with Shoe Goo or Black silicone.
The last new one was sold by Porsche in Germany to a mechanic in Ventura, CA 3 years ago and went on a customer's car. I tracked it down trying to buy it. I bought a number of good used ones to have in the race spares box. (thanks to Cap'n krusty and Nate Breitling among others) Kart54 SCCA G prod road racing Porsche 914 |
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
Chrome bumper plugs. I'm easy! Oh yeah, the throttle body seal for a 1.7.
Pat |
MDG |
Excellent news on the center caps, George! Sheesh, my seconding of Paul's center cap idea worked so well I'll give it another shot . . .
I second Pat's chrome bumper plugs too. |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,289 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
How about a pre-made Hell-Hole Patch
T.C. ![]() |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Excellent news on the center caps, George! Sheesh, my seconding of Paul's center cap idea worked so well I'll give it another shot . . . I second Pat's chrome bumper plugs too. Try a decent plumbing shop. Stainless steel sink plugs... Before you skoff...go take a look. RIch |
Pat Garvey |
Excellent news on the center caps, George! Sheesh, my seconding of Paul's center cap idea worked so well I'll give it another shot . . . I second Pat's chrome bumper plugs too. Try a decent plumbing shop. Stainless steel sink plugs... Before you skoff...go take a look. RIch OK, so I took a look. I'll wait for George. |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Trunk lock cylinders....
Most of the ones I 've seen are pitted and worn- including the two I have. Ken |
Van914 |
Van914 ![]() ![]() ![]() Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest ![]() ![]() |
George,
How about a passanger side mirror with a convex lens. I bought your reproduction last year and I mounted it yesterday. Looks great. I just wish it had the lens. Thanks Van |
Lo-Fi Version | Time is now: 24th June 2024 - 07:31 AM |
