| Scott S |
Jul 2 2009, 03:15 PM
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All -
Got a line on a rebuilt 2.7 out of a 1977 911S. It is 100% complete including the full CIS system. What kind of power loss would I experience if I stripped off the CIS and went with carbs? The motor is only 165hp to begin with... Thanks! Scott S |
| brant |
Jul 2 2009, 03:20 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,112 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Scott,
I heard about that motor seemed like a really good deal ! I don't know that you'd loose power you probably would loose mileage is all but I'm no CIS expert either. brant |
| Cupomeat |
Jul 2 2009, 03:21 PM
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
I cannot support the following with empirical evidence, BUT;
I would say that you would not lose any peak hp with the switch. You will probably lose a little driveability as the CIS gets you a feedback Lamba circuit (correct me if it doesn't have a O2 sensor) and is more flexible for all kinds of weather. Also, CIS has a large plate (Read: Restrictor) in the airflow which controls the amount of fuel in the fuel distributor and this has an impact on the pumping losses and efficiency of the engine. All in all, I'd think you could get about the same peak HP. That being said, I'd stick with the FI as it will be a better car to drive. |
| turboman808 |
Jul 2 2009, 03:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
From what I have seen on graphs you get peaks and valleys instead of a smooth power curve.
| carr914 |
Jul 2 2009, 04:43 PM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 129,525 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I would think that you would H.P. & Torque with the switch. 2.7s are fairly low compression motors (remember when they were built - Fuel availability & emissions) and the CIS is made to work with this compression. Without a Cam change to work with the carbs it will suffer. However you can make a 2.7 into a great motor. I expect my 2.7 to put out 225-240HP
T.C. |
| IronHillRestorations |
Jul 2 2009, 10:11 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,897 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Why not just keep the CIS?
| pcar916 |
Jul 2 2009, 11:13 PM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
When I bought my car it had a 2.7L motor built up to Bruce Andersen's 911 Performance Handbook spec's with 40 IDA carbs, headers, the proper cams, shuffle-pinned... everything except the Euro pistons. It had CIS. I wish I could give you numbers but never got that engine dyno'd. That said...
The car ran strong but I had to change jets often. Kind of a pain actually, and I'm sure I would have made more power with the proper pistons and more compression. How much is impossible to tell... But I wound up with a full set of jets and lots of experience balancing and jetting those carbs. Gave up all that when I traded away the motor for a 3.6L. Just make sure you have the 11 bladed fan, not the 5-bladed one, unless it's a track only car. I'm not near my books and don't remember what year those came on the 2.7 engine. That engine sounded great. |
| GeorgeRud |
Jul 2 2009, 11:29 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
If you don't have it, I would get Bruce Anderson's book and follow his advice on the 2.7 motor. I have one with the RS piston/cylinder set, E cams, and the Weber carbs. It runs very nice, and certainly has more power than the CIS system, which used a very mild cam (210 if Anderson is correct in his figures). A wilder cam will give you a higher peak hp, but at the expense of driveability.
I think that if you put on a modern, electronic fuel injection system (ie Bitz Racing with the Megasquirt controller), you could do better than the carbs as they are really not all that happy with today's gas formulations, and the EFI should have better control. If the engine is complete and working, you can always use it that way initially, and always modify it later if you wish. Even 165 hp in a 914 is a blast to drive. |
| ahdoman |
Jul 3 2009, 12:10 AM
It's phonetic...Ah-D-O-Man (Audioman) ![]() ![]() ![]() Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
If the CIS is intact and working stick with it. You won't be disappointed. The only problem will be fitting the engine in the car. I decided to cut a little "hatch" in my trunk to axcess some of the components and make way for other parts. You could probably make it fit without doing this but you'll have to get a new fitting for the fuel distributor and relocate one of the vacuum regulators. Here's what I finally ended up with. I am in the proecess of making the cover. The parts circled are what got in the way.
| carr914 |
Jul 3 2009, 06:15 AM
When I bought my car it had a 2.7L motor built up to Bruce Andersen's 911 Performance Handbook spec's with 40 IDA carbs, headers, the proper cams, shuffle-pinned... everything except the Euro pistons. It had CIS. You can't have carbs and CIS. The fact that you talked about the jets means you had carbs |
| pcar916 |
Jul 3 2009, 07:45 AM
When I bought my car it had a 2.7L motor built up to Bruce Andersen's 911 Performance Handbook spec's with 40 IDA carbs, headers, the proper cams, shuffle-pinned... everything except the Euro pistons. It had CIS. You can't have carbs and CIS. The fact that you talked about the jets means you had carbs That's correct. I should've said "... it had CIS pistons instead..." Thanks |
| Project 6 |
Jul 3 2009, 07:50 AM
large member ![]() ![]() Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
Wayne at Pelican claims to have installed a CIS motor w/o having to cut the trunk.
| J P Stein |
Jul 3 2009, 08:51 AM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I know a few folks that run Webers on an otherwise stock 2.7L.
You won't loose power...more likely you'll gain a few ponies and a hell of a lot of throttle response. Your gas mileage will suffer....if only because you'll play the Weber organ every chance you'll get. (IMG:style_emoticons/default/biggrin.gif) There are very few things in life more convoluted than the CIS intake tract. |
| Gint |
Jul 3 2009, 08:53 AM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,105 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I'd probably just use the CIS. But if you buy it and carb it Scotty I need all of the CIS gear. (IMG:style_emoticons/default/wink.gif)
| scotty |
Jul 3 2009, 10:28 AM
The Fun Never Stops ![]() ![]() ![]() Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
I know a few folks that run Webers on an otherwise stock 2.7L. You won't loose power...more likely you'll gain a few ponies and a hell of a lot of throttle response. Your gas mileage will suffer....if only because you'll play the Weber organ every chance you'll get. (IMG:style_emoticons/default/biggrin.gif) There are very few things in life more convoluted than the CIS intake tract. (IMG:style_emoticons/default/agree.gif) Totally! Warning: the Weber Organ is closely followed by an annoying Siren Song if you're not careful when you play. |
| naro914 |
Jul 4 2009, 10:56 AM
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
I have a 2.7 in Huey at the moment, with Webers. It's nice, but not exceptionally fast. Runs good from low to high rpm. But, John Forbes my mechanic said since it was set up for CIS, it's low compression and thus not the best for carbs. Whenever it needs to come out, we'll increase compression, change the carbs, and get more power but not crazy as I want to be able to keep it street.
| Mountain914 |
Jul 4 2009, 11:44 AM
Too much time in thin air! ![]() ![]() Group: Members Posts: 367 Joined: 22-May 03 From: Conifer, CO Member No.: 725 Region Association: Rocky Mountains |
Just want to throw this out there - since the title says how much HP loss.
It's my belief an engine will make the same power on any non forced-induction system providing it is tuned to take full advantage of the air/fuel mixture provided. I realize the path that the air/fuel take to enter, and the point(s) at which it enters also make a factor in detination within the cylinder. So what are we really talking about here ? Camshafts - provide the amount of intake (fuel and air) and how well the cylinder is evacuated (exhaust) - so a CIS engine has lower lift ? shorter duration ? (looking for comparison information). CIS - mechanical fuel injection that is not direct-port that will take aproximately the same path to the cylinders except for within the assemply itself (right?) Carb(s) - The main advantage to be had is the more direct path, thus "getting a good run at it" and the ability to easily change the air/fuel mixture ? Fuel Pressure / Pumps - Carb(s) take less pressure to run, hence need a return mechanism to return the unused fuel. Wouldn't the supply be a bit more dependable on injected vehicles ? Pistons (compression ratio) should be matched to the camshafts providing they don't hit the valves. I had a 2.0 carb'd car (delorto) and now run a 3.0 CIS. A daily run will take me over 4000+ foot change in elevation at high altitude - From 5000 to 9000 feet does a carb display that much difference (mine didn't - it ran great)? Between the two I would take CIS because I don't get the fuel smell though it doesn't have the great looks you can get from carbs. Sorry - I rambled - I swear it was my keyboard (IMG:style_emoticons/default/type.gif) To summarize - are you all saying there is more horsepower from carbs only if the cams are changed or simply because of one of the above other factors ? (I.E. what is the total package?) I don't believe just changing the top end would increase horsepower unless you are saying the CIS is not providing enough fuel/air for the engine to begin with. |
| J P Stein |
Jul 4 2009, 01:38 PM
Just want to throw this out there - since the title says how much HP loss. It's my belief an engine will make the same power on any non forced-induction system providing it is tuned to take full advantage of the air/fuel mixture provided. I realize the path that the air/fuel take to enter, and the point(s) at which it enters also make a factor in detination within the cylinder. So what are we really talking about here ? Camshafts - provide the amount of intake (fuel and air) and how well the cylinder is evacuated (exhaust) - so a CIS engine has lower lift ? shorter duration ? (looking for comparison information). CIS - mechanical fuel injection that is not direct-port that will take aproximately the same path to the cylinders except for within the assemply itself (right?) Carb(s) - The main advantage to be had is the more direct path, thus "getting a good run at it" and the ability to easily change the air/fuel mixture ? Fuel Pressure / Pumps - Carb(s) take less pressure to run, hence need a return mechanism to return the unused fuel. Wouldn't the supply be a bit more dependable on injected vehicles ? Pistons (compression ratio) should be matched to the camshafts providing they don't hit the valves. I had a 2.0 carb'd car (delorto) and now run a 3.0 CIS. A daily run will take me over 4000+ foot change in elevation at high altitude - From 5000 to 9000 feet does a carb display that much difference (mine didn't - it ran great)? Between the two I would take CIS because I don't get the fuel smell though it doesn't have the great looks you can get from carbs. Sorry - I rambled - I swear it was my keyboard (IMG:style_emoticons/default/type.gif) To summarize - are you all saying there is more horsepower from carbs only if the cams are changed or simply because of one of the above other factors ? (I.E. what is the total package?) I don't believe just changing the top end would increase horsepower unless you are saying the CIS is not providing enough fuel/air for the engine to begin with. You've covered a lot of ground there. A good illustration of the possibilities of the 2.7L is the difference between the 165 hp @ 5800 rpms CIS engine and the 2.7 MFI RS engine which is conservatively rated at 210 hp @ 6300. The piston's are different but the compression is the same. The difference is the MFI, the cams and 1mm larger ports on both sides...that's it. The RS pistons have reliefs for the valves at overlap. The RS is freer flowing at intake & exhaust. The cams allow the cylinders to scavenge....actually suck the intake charge into the cylinders at a higher velocity using the departing exhaust pulse inertia. Scavenging is minimal with CIS cams with their lack of overlap and the CIS won't allow it. The overlap pulse screws up CIS operation. My hot rod 2.7L makes 198 hp @ 6300 at the wheels. This is with less cam, more compression (than the RS), and Webers. Peak torque is 190 @3800 ....again at the wheels. A very drivable street motor other than the required race gas. I formerly has street gas compression (9.7:1) and it was a hoot. Humm.... I got off the point also. The big problem HP wise is the CIS itself. There is around 15-18 inches between the butter fly (throttle body) and the valves and the path is convoluted. With Webers that distance is about 6 inches and nearly a straight shot. That is where the extra punch & throttle response comes from even with stock cams. I would hazard a guess that in a 914 with headers & Webers, the HP would be around 180-185 hp at the crank...half of that increase being from the headers. Both let the engine breathe as well as the CIS cams allow. |
| ArtechnikA |
Jul 4 2009, 02:02 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
A good illustration of the possibilities of the 2.7L is the difference between the 165 hp @ 5800 rpms CIS engine and the 2.7 MFI RS engine which is conservatively rated at 210 hp @ 6300. In addition to the differences you listed, any MFI->anything else comparison must include the observation that while CIS and carbs both have restrictions in the intake tract (CIS has the metering vane, carbs have venturiis) MFI doesn't have anything in the path but the throttle butterfly plate. Slide-valve MFI doesn't even have that. Even if you figure that the MFI pump must take some HP to run, it's a big (~10) net gain being able to run without power-robbing restrictions. The price is efficiency - MFI has -no- clue as to engine load - all it can know is throttle position and rpm. |
| J P Stein |
Jul 4 2009, 04:02 PM
A good illustration of the possibilities of the 2.7L is the difference between the 165 hp @ 5800 rpms CIS engine and the 2.7 MFI RS engine which is conservatively rated at 210 hp @ 6300. In addition to the differences you listed, any MFI->anything else comparison must include the observation that while CIS and carbs both have restrictions in the intake tract (CIS has the metering vane, carbs have venturiis) MFI doesn't have anything in the path but the throttle butterfly plate. Slide-valve MFI doesn't even have that. Even if you figure that the MFI pump must take some HP to run, it's a big (~10) net gain being able to run without power-robbing restrictions. The price is efficiency - MFI has -no- clue as to engine load - all it can know is throttle position and rpm. Yeah,yeah, some folks go all gaga over the MFI setup. If someone gave me an RS set up in perfect working condition, I'd put it on my engine, but.....the cost to buy it is 3/4 of the way to an ITB, EFI system which will make more power and run more efficiently. I'll leave the MFI to the Grope R wonks. |
Lo-Fi Version | Time is now: 14th December 2025 - 05:28 AM |
