6 Pages V  1 2 3 > »
> Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea!
Mueller
post Jun 29 2016, 02:47 PM
914 Freak!
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs)
Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor.
Cam will be a 9600 grind from Rabys old store
Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt.
Exhaust is older European Racing Header.
stugray
post Jun 29 2016, 02:58 PM
you can measure the valve travel without even taking the rockers off.
To actually get at the cam to change it, you have to split the case, now the "what should I replace?" comes down to 1 - your budget & 2 - what you find.
In either order.
You can inspect & measure all the 'pertinents' and decide if anything is worn.
Gunn1
post Jun 29 2016, 02:59 PM
Did you try the search function ?
You will find mucho Grande info on this subject there.
Mueller
post Jun 29 2016, 03:06 PM
914 Freak!
QUOTE(stugray @ Jun 29 2016, 01:58 PM) *
The actually get at the cam to change it, you have to split the case, now the "what should I replace?" comes down to 1 - your budget & 2 - what you find.
In either order.
Not really looking into splitting case, for some odd reason I was thinking cam came out without do that, been too long.
Oh well, I'll still measure it yet chances are it's going to stay unless that camshaft mentioned earlier would really offer some improvements.
JFJ914
post Jun 29 2016, 03:11 PM
Jake doesn't sell parts anymore, only turnkey engines. The Type IV store is now owned by LN Engineering.
Gunn1
post Jun 29 2016, 03:16 PM
I think Jake uses the search function .
Be like Jake.......
rhodyguy
post Jun 29 2016, 03:21 PM
Saw that one coming 1/2 hour ago. Funny. No quotes required.
Mike, have you tried contacting LN/type4 store directly with the cam #s you have? Does the site list a phone #? Edit: I checked. you should call type4 support
Mueller
post Jun 29 2016, 03:48 PM
914 Freak!
QUOTE(John Jentz @ Jun 29 2016, 02:11 PM) *
I'd think he'd still have the specs to the older stuff he sold.
Cam is not listed on Store website. I could call them tomorrow, might be something not usually offered.
Mueller
post Jun 29 2016, 03:49 PM
914 Freak!
QUOTE(OU812 @ Jun 29 2016, 01:59 PM) *
Yes, yes I did...feel free to search 9600 for the specs. I asked after I couldn't find the specs!
rhodyguy
post Jun 29 2016, 04:20 PM
Unless somebody had their NEW cam read, those details are probably proprietary knowledge.
Gunn1
post Jun 29 2016, 05:49 PM
QUOTE(Mueller @ Jun 29 2016, 04:49 PM) *
Just messin with ya
Chris H.
post Jun 29 2016, 06:05 PM
If Jake doesn't see this just call Charles at LN Engineering. He owns the Type 4 Store now. phone: 815-472-2939. Super nice guy.
r_towle
post Jun 29 2016, 06:47 PM
Custom Member
Mike,
Go to Elgin camshafts and look at what he sells.
Lift ramp is most of what you can change .
He has one that will work.
Split the case, it will make drilling out the head studs easier to jig up.
Plus, you cannot replace the camshaft without doing that .
Valy
post Jun 29 2016, 08:44 PM
How long did the motor run with broken head studs?
I would suspect the cylinders are out of round.
Mueller
post Jun 29 2016, 10:01 PM
914 Freak!
Exhaust studs broken, not head studs.....
r_towle
post Jun 29 2016, 10:13 PM
Custom Member
QUOTE(Mueller @ Jun 30 2016, 12:01 AM) *
You are a nice guy to make sure we don't think we are nuts...
stugray
post Jun 29 2016, 10:58 PM
QUOTE(Mueller @ Jun 29 2016, 10:01 PM) *
maybe contact saigon71 and see this thread:
http://www.914world.com/bbs2/index.php?showtopic=248544
Mueller
post Jun 30 2016, 10:57 AM
914 Freak!
I called LN Engineering, they found the specs for the cam I have sitting around...
Lift:
I .335
E .400
Duration:
290 I/E
Duration @ .050:
I 252
E 254
108 Lobe center.
stugray
post Jun 30 2016, 11:23 AM
QUOTE(Mueller @ Jun 30 2016, 10:57 AM) *
Lift:
I .335
E .400
Duration:
290 I/E
Duration @ .050:
I 252
E 254
108 Lobe center.
That is the lift at the cam.
edit - not even sure of that. The #s look wrong. Is that at the cam or at the valves?
While you have his attention, could you please ask what lift he expects with that cam at the valves?
Mark Henry
post Jun 30 2016, 01:22 PM
that's what I do!
QUOTE(Mueller @ Jun 30 2016, 12:57 PM) *
Lift:
I .335
E .400
Duration:
290 I/E
Duration @ .050:
I 252
E 254
108 Lobe center.
The 290 duration number is odd.
Look at the WEB 73 numbers in the link below:
http://vwparts.aircooled.net/Web-Cam-Type-...72-p/00-472.htm
WEB 73 is a FI grind but IIRC it has bit more lift. If you want L-Jet you need an stock based FI grind like the 73.
6 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 22nd November 2024 - 06:05 PM
