Rear swaybar mounts - easy to install and sourcing? |
Tdskip |
May 26 2020, 03:13 PM
Advanced Member Group: Members Posts: 3,703 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I have a couple rear swaybars that I will be installing and I don't believe my cars have the ball where the link arm mounts on them.
Any tips on installing and sourcing them? Thanks! |
mepstein |
May 26 2020, 03:22 PM
914-6 GT in waiting Group: Members Posts: 19,738 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Tdskip |
May 26 2020, 04:37 PM
Missed that when I searched - thanks Mark!
Mark Henry |
May 26 2020, 04:53 PM
Hardest part is you have weld in the body bracket mounts.
914e |
May 26 2020, 04:57 PM
Member Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Tdskip |
May 27 2020, 07:08 AM
Bingo! I even loooked at PET before asking, missed it. Thanks Mark Henry as well. |
IronHillRestorations |
May 27 2020, 07:13 AM
I. I. R. C. Group: Members Posts: 6,798 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Brad Mayeur @914Ltd sells the bracket for the body and the reinforcement plates. Everything else is from Porsche or salvage
Mikey914 |
May 27 2020, 08:55 AM
The rubber man Group: Members Posts: 12,745 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We stock his fronts and rears if you need them
https://900designs-container.zoeysite.com/s...sway+bar+mounts Attached image(s) |
bdstone914 |
May 27 2020, 08:56 AM
bdstone914 Group: Members Posts: 4,754 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The 75-76 body brackets were different. Some people drill holes through the trunk and nolt them in due to the diffuculity of welding upside down on a car with the drive train installed.
Tdskip |
May 27 2020, 03:51 PM
Thanks for the responses. Good to know about sourcing option as well.
Any downside to just drilling the trunk to mount via welding from up top? @mb911 I can see where that would be a lot easier. |
mb911 |
May 27 2020, 05:12 PM
914 Guru Group: Members Posts: 7,475 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Thanks for the responses. Good to know about sourcing option as well. Any downside to just drilling the trunk to mount via welding from up top? @mb911 I can see where that would be a lot easier. You could plug weld from the top nothing wrong with that but would need multiple plug welds |
Tdskip |
May 27 2020, 05:39 PM
Thanks for the responses. Good to know about sourcing option as well. Any downside to just drilling the trunk to mount via welding from up top? @mb911 I can see where that would be a lot easier. You could plug weld from the top nothing wrong with that but would need multiple plug welds Think four per mount would be enough? |
914werke |
May 27 2020, 06:45 PM
"I got blisters on me fingers" Group: Members Posts: 11,087 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I have a solution for the EXPENSIVE OE R. shock bolt. (IMG:style_emoticons/default/smile.gif)
Tdskip |
May 30 2020, 06:56 AM
@914werke - I looked at your store and didn't see anything in stock? Are you hiding the good stuff? Grin. |
Lo-Fi Version | Time is now: 8th February 2025 - 12:55 AM |
