boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Have a 1975 1.8 with 2.0 heads, being used as a street driver. Want to install complete carb kits. What are people using?
I will install a 009 distributor, mechanical fuel pump. Looking for ideas. I've seen the Empi 40 and 44 kits on the Samba. Thanks Craig at CAMP |
r3dplanet |
Senior Member ![]() ![]() ![]() Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None ![]() |
Hi there.
First up, skip the 009. The distributor that came with the 1.8 is perfect for carbs. Second, use a rotary electric fuel pump like this one: http://www.cbperformance.com/ProductDetail...roductCode=3193 Third, you'll probably want Weber IDF 40 or Dellorto DRLA 36 carbs, like these which include intakes: http://www.cbperformance.com/ProductDetail...roductCode=6410 Some say that getting a older pair of Italian-made Weber 40 carburetors and rebuilding them are the better way to go. -marcus |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
If the motor has a stock cam in it, then you will not be gaining anything by removing the fuel injection. The stock injection is designed for the motor, the carbs are a compromise. Your performance will drop, and you will get lousy gas mileage.
Now it becomes a whole different story if you have changed the cam. I recommend you get the fuel injection working correctly and drive it the way it is. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If the motor has a stock cam in it, then you will not be gaining anything by removing the fuel injection. The stock injection is designed for the motor, the carbs are a compromise. Your performance will drop, and you will get lousy gas mileage. Now it becomes a whole different story if you have changed the cam. I recommend you get the fuel injection working correctly and drive it the way it is. If you read the whole post a 1.8 with 2.0 heads is going to need a bastardized FI system to start with.... |
7275914911 |
Hummmm!!! ![]() ![]() ![]() Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States ![]() ![]() |
From personal experience w/40idf's on a stock 1.8 IF you ditch the HE for headers there WILL be a seat of the pants difference in performance...
Good Luck... |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
the carb set craig is looking into is the Empi HPMX flavor. same as mike blizzard fought and had to return.
malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
If you read the whole post a 1.8 with 2.0 heads is going to need a bastardized FI system to start with.... Mark, Can you explain more about the bastardization? I may have bastardized mine and called it something different. I have 1.8 heads with 2.0 size valves, L-jet, stock disty, 1911 cc and I like the way it runs. I don't have anything to compare it to, but I like the bastard, if that is what I have... (IMG:style_emoticons/default/shades.gif) |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
He's referring to the runners for 2 liter FI not lining up with the 1.8L FI plenum.
However, longer hoses to connect them are not difficult to make using silicone hose and hose clamps. |
malcolm2 |
He's referring to the runners for 2 liter FI not lining up with the 1.8L FI plenum. However, longer hoses to connect them are not difficult to make using silicone hose and hose clamps. OK, I certainly did not have to worry about that. I tweeked my AFM to get my Air/Fuel ratio fine tuned via the AFM adjustment but that is it. Regardless, I approve of the way it is running, so I must have done something right..... BTW Chris will you ship my CV joints today? Clark |
ChrisFoley |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Craig dont know if this is a (FI) problem seeking a solution or (IMG:style_emoticons/default/confused24.gif)
But both L-Jet & D-jet will run that motor parts combo. I did a 1911 with 2.0 heads & Djet that with some MPS tweaking by Geoff & his LM1 kit ran REALLY well. |
PotterPorsche |
Member ![]() ![]() Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None ![]() |
I like 36 dellorto's with the update kit , If your ever going to build a bigger engine 40 dellortos. Black line racing can rebuild any carbs you find. My brother runs webers both 40 and 44
http://www.blacklineracing.net/ |
dirk9141973 |
Unregistered ![]() |
I like 36 dellorto's with the update kit , If your ever going to build a bigger engine 40 dellortos. Black line racing can rebuild any carbs you find. My brother runs webers both 40 and 44 http://www.blacklineracing.net/ I have been satisfied with Empi 40 on my 2056 engine with magna spark II distributor |
Mark Henry |
He's referring to the runners for 2 liter FI not lining up with the 1.8L FI plenum. However, longer hoses to connect them are not difficult to make using silicone hose and hose clamps. Yep, thanks Chris, a bastardized FI system will work, I was just referring to the logic of why he needs/wants carbs (IMG:style_emoticons/default/shades.gif) If it was me I agree that with a stock cam I would try to make a FI system work. That is if I had had one handy. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:01 AM |
