where to find MSD wiring diagram |
pete-stevers |
Apr 28 2006, 10:45 AM
saved from fire! Group: Members Posts: 2,644 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
where do i find a wiring diagram for an msd box...?
Mugs914 |
Apr 28 2006, 10:53 AM
"Hey, yellow IS faster!" Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
Right here:
http://www.msdignition.com/1download.htm That page has the instructions for the various MSD boxes. There is more info on the site if you don't see what you need on that particular page. Have fun! |
pete-stevers |
May 4 2006, 03:24 PM
i am looking for specific info on a msd 6200
Aaron Cox |
May 4 2006, 03:27 PM
Aaron Cox |
May 4 2006, 03:30 PM
i am looking for specific info on a msd 6200 is that not just a 6A/L box? this is how ive hooked them up.... Attached thumbnail(s) |
ThePaintedMan |
Jun 25 2013, 09:35 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Ohh buddy am I going to get flamed for this one (digging up an old thread, but hey, at least I didn't start a new one!). I searched but unfortunately since MSD is 3 letters, I didn't have much luck.
I've read through the MSD manual here: http://www.msdignition.com/uploadedFiles/M...upport/WDTN.PDF But I have a more unique setup. I want to wire an MSD 6AL with tach adapter AND to a distributor with a Pertronix/Compufire unit installed. Can anyone point me to the correct diagram in the directions, or even better, clarify what wires should go where? I am a wiring dummy - it's probably the one thing I hate the most with cars. Bodywork, metal work, greasy nasty stuff, no problem. Wiring... I hate. Thank you! (IMG:style_emoticons/default/pray.gif) |
ThePaintedMan |
Jun 26 2013, 04:16 PM
Bueller? (IMG:style_emoticons/default/biggrin.gif)
LotusJoe |
Jun 26 2013, 05:42 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I'm pretty certain you cannot use the MSD with the Compu-Fire ignition module. Assuming that is what your using. Petronix / Compu-Fire are two different types of units.
With the Compu-Fire you do not need any additional units. It is self contained. I was running the Crane Fireball XR700 with the petronix ingition module. On the advise from Fat Performance I replaced both with the compu-fire unit and have no regrets. Timing is spot on with no issues what so ever. |
ThePaintedMan |
Jun 26 2013, 06:58 PM
I'm pretty certain you cannot use the MSD with the Compu-Fire ignition module. Assuming that is what your using. Petronix / Compu-Fire are two different types of With the Compu-Fire you do not need any additional units. It is self contained. I was running the Crane Fireball XR700 with the petronix ingition module. On the advise from Fat Performance I replaced both with the compu-fire unit and have no regrets. Timing is spot on with no issues what so ever. Thanks Joe. Hmm. That I was unaware of. This is a Compufire, but I was under the impression that it worked the same way as a Pertronix, i.e. Hall effect. They're both wired the same way, with two wires (red and black) which correspond to the + and - sides of the coil. Perhaps someone else can verify this though. |
Mark Henry |
Jun 26 2013, 08:13 PM
Page 38
"MSD 6 series to Mallory Unilite", OR if you are handy with wiring you can do "MSD 6 series to Other magnetic Pick-up Distributors" you can buy the connector part from MSD and make you own connector. http://www.summitracing.com/parts/msd-8824 I realize you are talking about a pertonix...wire it the same. BTW with MSD really points would be good enough, you no longer have all that volts going through the points. Think about it.... the points are now just a trigger, they will no longer burn out. |
ThePaintedMan |
Jun 27 2013, 06:09 AM
Thanks Mark.
A quick item I noticed in the MSD instructions - it says for the 12V power and ground, which both connect directly to the battery via 12 gauge wires, to NOT use a fuse. Anyone recommend otherwise? |
Mark Henry |
Jun 27 2013, 06:32 AM
I should have kept going to page 39, "MSD 6 series to Pertonix Kit" (IMG:style_emoticons/default/smile.gif)
The heavy red wire and heavy black go to the battery and are internally fused. The small red wire goes to ignition. |
jasons |
Jun 27 2013, 05:44 PM
Jackstand Extraordinaire Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I made this diagram a long time ago...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i176.photobucket.com-2573-1372376693.1.jpg) You might find more info in this thread.... http://www.914world.com/bbs2/index.php?showtopic=93631 |
jcd914 |
Jun 28 2013, 12:07 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I made this diagram a long time ago... (IMG:http://www.914world.com/bbs2/uploads_offsite/i176.photobucket.com-2573-1372376693.1.jpg) You might find more info in this thread.... http://www.914world.com/bbs2/index.php?showtopic=93631 When Rob and I did his car, we wired it like this except the tach a would not work. Ended up getting rid of the tach adapter and running the tach right off the MSD "Tach Out", worked perfect. Jim |
ThePaintedMan |
Jun 28 2013, 08:49 AM
Thanks Jason and Jim!
I guess I could try running it off of the tach out first, since this would obviously be the easiest. I should have mentioned that this is a '73, with silver dot gauges. I read that silver dots need the tach adapter, but the 75-75 black dots do not. Either way, my tach adapter is #8910, which is triggered by the white wire an only has two wires (red and white). The #8920 is the one with 4, which Jason posted. Guess I'll find out when I hook it all up this weekend. |
jcd914 |
Jun 28 2013, 08:57 AM
ThePaintedMan |
Jun 28 2013, 09:12 AM
Yeah, unfortunately I am an electrical idiot. Bodywork, metalwork, and suspension stuff is more up my alley, but apparently the later tachs use a different signal than the earlier ones. Do the late tachs get their signal from the coil positive, or negative? I know the early ones are hooked to the coil negative, and apparently that's why the #8910 is required to make them work.
michael7810 |
Jun 28 2013, 09:39 AM
Senior Member Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I had to use the tach adapter on my 72 with Pertronix and MSD 6AL. I can poSt a wiring diagram on Sunday when I get home if you need it. I remember using the diagram that came with the MSD but it was confusing.
ThePaintedMan |
Jun 28 2013, 10:01 AM
I had to use the tach adapter on my 72 with Pertronix and MSD 6AL. I can poSt a wiring diagram on Sunday when I get home if you need it. I remember using the diagram that came with the MSD but it was confusing. That would be a huge help Michael! I would really appreciate it. |
Lo-Fi Version | Time is now: 25th November 2024 - 02:52 AM |
