stephenaki |
Can I get this one dad?? ![]() ![]() ![]() Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None ![]() |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Two things to update today; first is status of crank and connecting rods, second is did some cleaning up of the crankcase and heads.
I called the guys in Santa Ana that Smitty provided the website to and then emailed them requesting a total quote for the crank, a set of connecting rods and shipping. Haven't gotten anything yet; Smitty, I may be hitting you up to go and get what I need from them and arrange to pay you instead. I took the crankcase and heads over to post today to clean them up and planned on removing the valves and springs to inspect the head further. Didn't get to the valve removal, ran out of time. I did get a good amount of the crankcase cleaned up but still have more to go. The cooling fins are a bit rough but not unserviceable. Cleane quite a lot of gunk off the case halves but sill have more to go. Also got a basic cleaning done on the heads and hope to pull the valves off this week. I did notice on one of the exhaust manifolds that I was missing a set of studs and one of those holes already had evidence of a helicoil in it. The other hole was completely baren so will need a new stud put in. No problem, I will do that before I re-assemble the engine. I did a search on media blasting for the case and heads and couldn't find much as most of the posts were on media blasting the car shell. I know that Andy is not a big fan of media blasting, anyone else have any experience? I want to make sure the heads and case are clean enough to eat off of and all the gunk is gone completely and, the solvent tank isn't completely cutting it. Feedback please, thanks. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 09:41 PM |
