76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
What's it been? A year since I got Blackie running. I finally get it tuned to a daily driver status and should have been happy as a Lark then but what do I do? I sold the engine (w/90 hour's on the Hobbs) on the last Dawn Patrol GMR run. So I pulled the engine and began preparing Blackie for her transformation.
![]() Before I go any further check out my Jack Stands. Min height 19.5", 12 ton and should hold up to a 6.7 quake or direct nuclear attack. ![]() And out she comes. ![]() ![]() One thing you have to love about these cars is that you can remove an interior in 15 minutes. 30 min's if you have a console. This was one shot before the interior is gutted. ![]() and an hour later I'm scraping tar floorboards. ![]() |
76-914 |
So while I wait for the "correct" size of steel to patch the firewall I thought I would clean up the engine compartment and see if I could find anymore rust. There is a bunch of the old mat stuck to it..........
![]() ![]() ![]() And this looks a little suspicious. Rivets and a rough finish on the panel. ![]() Then there is the matter of this booger by the PO. ![]() So I drill out the rivets and look what I find. Has anyone seen these before. Obviously stamped steel so mfg'd by someone. ![]() Once they're out this is all that was left of the tray. The pedestal was in good shape but I doubt I will relo a batt here. ![]() Couple of pic's while getting cleaned. These holes need to be welded up ![]() And a small patch here ![]() ![]() One booger mostly ground down ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 08:27 PM |
