> Solid State Relay Board
Steve_R
post Jul 6 2015, 05:28 PM
Well, it’s been about a year since I finished my 914 restoration, you can read all about it
HERE.
Everything works perfect except for the electrical problems I’ve been having with the relay board. I spent lots of hours trouble shooting electrical issues with the fuel pump. It turs out that my relay board had some bad connections for the fuel pump relay. After searching this site I discovered that the relay board is truly the weakest link in the 914. I tried to remove the epoxy bedding underneath the board and resolder the connections. This worked for a while but the fuel pump would sometimes stop and kill the engine. I finally figured out that the contacts for the fuel pump relay to the board were causing the problem. This seems like a never ending problem. I could buy another 40 year old used board and have the same problems.
So, to make a long story short, I decided to design a new relay board from scratch. I replaced the original electromechanical relays with industrial solid state relays. They have the same connection labels as the stock relays: 85 & 86 for the coil and 30 & 87 for the switch. The relays are available at most electrical parts dealers like Mouser or Digi-Key if one ever needs to be replace. They also use a lot less power than the original 914 relays. Also, since they are solid state and don’t have any moving parts they will last a lot longer and are more reliable. I also replaced the old ceramic fuse with a modern ATC style fuse and added an LED that illuminates when the fuel pump has power. This is great for trouble shooting fuel pump issues. It comes on for a few seconds after the key is turned on and stays on when the engine is running. Also, I removed the connections and plug for the rear window defroster. I used wires soldered to the connectors eliminating all of the riveted connections. All connections are soldered. To make the board I CNC machined the board out of high density polyethylene plastic.
I built a few extra boards to offset some of the development costs. They are quite labor extensive to build so I don’t plan to mass produce them. PM me if you want one. I would like to get $500.00 each. That includes the board with the solid stare relays. It does not include the voltage regulator. I used a solid state one from Pelican Parts. Both the stock and solid state voltage regulators will work.
02loftsmoor
post Jul 11 2015, 11:01 PM
I would like to get with on the relay board. Wes
Steve_R   Solid State Relay Board   Jul 6 2015, 05:28 PM
Jeff Bowlsby   Wow...   Jul 6 2015, 05:35 PM
steuspeed   :agree: :shades2:   Jul 6 2015, 05:44 PM
SirAndy   :trophy: Very nice! Just a FYI, i was able t...   Jul 6 2015, 05:47 PM
jim_hoyland   Thanks for posting; I saw your car at the PCA Conc...   Jul 6 2015, 05:59 PM
McMark   Really cool! :thumbsup: What's the back ...   Jul 6 2015, 06:00 PM
Steve_R   Really cool! :thumbsup: What's the back...   Jul 7 2015, 06:55 AM
McMark   Really cool! :thumbsup: What's the bac...   Jul 7 2015, 10:26 PM
Mueller   [quote name='Steve_R' post='2207091' date='Jul 7 ...   Jul 7 2015, 10:51 PM
SirAndy   What is the diameter of the stock round units? The...   Jul 8 2015, 05:36 PM
N_Jay   Wasn't planning on it. I'm a bit of a nu...   Sep 21 2016, 07:06 AM
Harpo   Very impressive. You have some skills there. Dav...   Jul 6 2015, 06:04 PM
Mike Bellis   I like it! I'm running solid state relays...   Jul 6 2015, 06:09 PM
Mblizzard   Holy crap that is cool! Wish I had the cash a...   Jul 6 2015, 07:08 PM
somd914   :drooley: :drooley: :drooley: Very nice work. ...   Jul 6 2015, 07:12 PM
saigon71   Very impressive - nice work! :beer2:   Jul 6 2015, 08:15 PM
914Sixer   Am I missing it or is there no plug for the heated...   Jul 7 2015, 08:47 AM
Steve_R   Am I missing it or is there no plug for the heate...   Jul 7 2015, 07:47 PM
Mueller   Damn...that is a nice assembly....Tormach mill?   Jul 7 2015, 09:40 AM
thieuster   I take my hat off, sir! Amazing stuff! M...   Jul 7 2015, 09:47 AM
clapeza   Doesn't this belong in the Sandbox? ...becaus...   Jul 7 2015, 12:07 PM
Maltese Falcon   +1 First Class product   Jul 8 2015, 12:20 AM
GregAmy   I'm gonna sound redundant but...that's som...   Jul 8 2015, 06:22 AM
Cairo94507   :woohoo: :trophy: That is some very nice work the...   Jul 8 2015, 06:56 AM
02loftsmoor   Well, it’s been about a year since I finished m...   Jul 8 2015, 08:49 AM
Mueller   r Question for you Looks like they are. Are the...   Jul 8 2015, 01:35 PM
Steve_R   [quote name='Steve_R' post='2206828' date='Jul 6 ...   Jul 8 2015, 04:01 PM
Mueller   Mueller is correct, these are not serviceable. N...   Jul 8 2015, 06:12 PM
Steve_R   Mueller is correct, these are not serviceable. ...   Jul 8 2015, 06:31 PM
jfort   Very cool. Nice work. I assume it won't work o...   Jul 8 2015, 09:26 AM
pete000   Nice blend of modern technology !   Jul 8 2015, 02:01 PM
dangerranger01   I like this a lot. Did you do your own pcb, or how...   Jul 8 2015, 04:57 PM
Steve_R   I like this a lot. Did you do your own pcb, or ho...   Jul 8 2015, 05:40 PM
mr914   :agree: Impressive, got to be in the hundreds of ...   Jul 8 2015, 05:09 PM
Geezer914   That is a work of art worthy of being framed and h...   Jul 8 2015, 05:27 PM
jwc914   This will go very well with my 160 amp alt kit. It...   Jul 11 2015, 02:22 PM
Steve_R   This will go very well with my 160 amp alt kit. I...   Jul 11 2015, 05:17 PM
02loftsmoor   I would like to get with on the relay board. Wes   Jul 11 2015, 11:01 PM
Cairo94507   I wish you made one of those boards for the Sixes....   Jul 12 2015, 07:12 AM
Kalani   Well, it’s been about a year since I finished m...   Jul 13 2015, 10:08 PM
Kalani   Hello Steve, Do you have any left, and has the p...   Jul 13 2015, 10:10 PM
Steve_R   Hello Steve, Do you have any left, and has the ...   Jul 13 2015, 11:18 PM
Zimms   These are beautiful! Worth every cent.   Jul 15 2015, 10:09 AM
Jeff Bowlsby   Drooling over this, I have some observations and q...   Jul 22 2015, 01:41 PM
Steve_R   Drooling over this, I have some observations and ...   Jul 22 2015, 06:37 PM
Jeff Bowlsby   [quote name='Jeff Bowlsby' post='2213570' date='J...   Jul 22 2015, 08:37 PM
Steve_R   [quote name='Jeff Bowlsby' post='2213570' date='...   Jul 22 2015, 09:35 PM
jd74914   However, I think it could be redesigned to be mac...   Jul 22 2015, 09:43 PM
Steve_R   [quote name='Steve_R' post='2213744' date='Jul 22...   Jul 22 2015, 09:58 PM
Strudelwagon   we use these at work...   Apr 7 2016, 10:50 PM
cegallegos99   Any good relay boards for sale? I am asking since...   Apr 17 2016, 09:45 PM
RoadGlue   Any good relay boards for sale? I am asking sinc...   Apr 18 2016, 04:45 PM
Cairo94507   Man, do I wish Steve would make these for a Six......   Sep 21 2016, 07:12 AM
N_Jay   So close, but so far. I certainly understand why ...   Sep 21 2016, 07:24 AM
Whitney Mic   So close, but so far. I certainly understand why...   Sep 21 2016, 06:49 PM
N_Jay   If I can get the pins for the body and engine conn...   Sep 21 2016, 08:15 PM
NS914   Hi Steve, Your relay board is truly a work of art...   Sep 23 2016, 07:47 AM
cegallegos99   Hi I am looking at yours as a new production Do ...   Jan 14 2017, 11:48 PM
Mueller   Steve, If you decide to out source the machining...   May 16 2017, 11:59 AM
Mikey914   We've been spending some time putting together...   May 16 2017, 02:00 PM
peteyd   We've been spending some time putting togethe...   Apr 3 2020, 02:38 PM
Mikey914   [quote name='Mikey914' post='2486779' date='May 1...   Apr 3 2020, 07:19 PM
Spoke   Actually we are working on the board. We decided ...   Apr 3 2020, 08:24 PM
peteyd   [quote name='Mikey914' post='2486779' date='May ...   Apr 6 2020, 06:04 AM
mbseto   I'd volunteer to create an STL file (i.e. a fi...   Apr 3 2020, 03:45 PM
Spoke   What needs to be done on this? Looks like it would...   Apr 3 2020, 05:20 PM
Mikey914   Size is really the issue. They are relitively inex...   Apr 3 2020, 08:54 PM
GregAmy   I suggest that one of the biggest failures on thes...   Apr 3 2020, 09:03 PM
Mikey914   That's where we are going with this.   Apr 3 2020, 09:15 PM
56 User(s) are reading this topic (56 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 8th January 2025 - 12:41 AM
